Which fuse controls cigarette lighter?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by larryakoch, Jul 28, 2015.
  1. larryakoch
    larryakoch Junior Member
    82
    Pomona, ca
    Mine has apparently stopped working. I use it to charge my phone on trips. I had plugged in an inverter in an attempt to run a small fridge (for camping) and maybe that blew it out. The inverter didn't work but I could run it directly off the battery terminals. that was too much work and there were bears around anyway so I bagged the project.
    48,946
    bears are an unbearable in convenience.:cool:
  3. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
  4. larryakoch
    82
    Pomona, ca
    Thanks. How do you get them out?
  5. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    There is a fuse puller in the corner of the fuse box. It looks like a cheap plastic mini tongs. You can also grab the fuse with a pair of pliers.
    FYI, there's a few extra fuses in the corner of the engine bay fuse box. ;)
  6. larryakoch
    82
    Pomona, ca
    The owner's manual didn't tell me how to contort myself so I can pull the plug? Should I be on my back laying across the door jamb? Its not self evident. thanks
  7. xliderider
    7,848
    3,102
    Honolulu, HI
    Yeah, that's the way to do it.
  8. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I hate to tell you this but, the cigarette lighter was removed several years ago.
  9. CharlesH
    2,785
    1,152
    Roseville, CA
    I think calling it a "cigarette lighter" just a habit left over from when they actually put a cigarette lighter into the 12V receptacle. Kind of like "dialing" a phone number. :) ( I understand that even a landline keypad can confuse young people today: "Where is the send button?", "I don't know any numbers; how do I pull up the contact list?")
    #9 CharlesH, Aug 3, 2015
    Andyprius1 likes this.
  10. larryakoch
    82
    Pomona, ca
    So I guess I'll have to use e cigarettes then. Thanks. the fuse fix worked.
  11. DLC82SV
    DLC82SV Member
    241
    118
