White screen of death (quick reply problem)?
Discussion in 'PriusChat Website Questions' started by moxiequz, Feb 9, 2009.
  1. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    I can reproduce this "hang" with one of my machines running XP SP3, and Firefox 3.0.6. Page stays white, at the bottom the status bar "Stopped"
  2. jayman
    13,439
    639
    Winnipeg Manitoba
    On the XP Pro SP3 machine, with FF 3.0.6. Will try Post Quick Reply again
  3. jayman
    13,439
    639
    Winnipeg Manitoba
    Danny
    Ok, still get the white screen freeze. Here are the messages from Error Console
    Error: vbmenu_register is not defined
    Source File:
    http://priuschat.com/forums/priusch...white-screen-death-quick-reply-problem-3.html
    Line: 0
    Error: Permission denied to get property XULElement.accessibleType
    Source File:
    http://priuschat.com/forums/clientscript/vbulletin_quick_reply.js?v=381
    Line: 11
    Source File:
    Line: 11
    Source File:
    Line: 11
    Source File:
    Line: 11
    Source File:
    Line: 11
    Warning: Empty string passed to getElementById().
    [Note: the above warning repeats about 50 times]
    Warning: Error in parsing value for property 'filter'. Declaration dropped.
    Source File:
    http://w.sharethis.com/share/css/share.css
    Line: 1
    Warning: Cannot specify value for internal property. Error in parsing value for property '-x-system-font'.
    Source File:
    Line: 1
    Warning: Use of getBoxObjectFor() is deprecated. Try to use element.getBoundingClientRect() if possible.
    Source
    File: http://priuschat.com/forums/priusch...white-screen-death-quick-reply-problem-3.html
    Line: 0
    Hope this helps
    jay
  4. windstrings
    windstrings Certified Prius Breeder
    6,278
    373
    Central Texas
    Jeezz... Mine works fine now... running FF 3.05 on win XP... but I'm only running sp2 on both of my machines "not sp3"
  5. jayman
    13,439
    639
    Winnipeg Manitoba
    I'm not sure why both my Ubuntu machine and my XP Pro SP3 machines are having the same problems with the White Screen.
    I was running Ubuntu 8.10 with FF 3.0.5. The package update I applied today was for gnome, and brought FF to 3.0.6. The only difference is that instead of claiming "stopped" in the status bar, it claims "done" but still a white screen freeze
  6. Syclone
    Syclone Member
    540
    I think Windstrings would agree -- the problem is cured immediately by installing a BT Tech Stiffening Plate under your motherboard! :focus:
  7. Fibb222
    Fibb222 New Member
    1,499
    99
    When I used the quick reply with firefox is says: "waiting for GreenHybrid.com...." at the bottom of the window.
  8. windstrings
    6,278
    373
    Central Texas
    LOL!.. Hello Cyclone... that reminds me.. I need to go find that thread!
  9. jayman
    13,439
    639
    Winnipeg Manitoba
    :doh:
    Oy, don't you start now ....
  10. jayman
    13,439
    639
    Winnipeg Manitoba
    Could be what you embedded in your signature. Windows? Linux? FF or IE? Versions??
  11. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    Ok, I'm getting the same problem now....
    I post in the QR box, hit "post quick reply" screen turns white and seems to get 'stuck'. If I hit the back button then reload the page my post went up properly.
    Only big thing different now than before is that I'd shut down and restarted the laptop I usually use whereas before I'd just sleep/hibernate it when I was done using it. So there may be something to do with the restart and/or caching.
  12. Danny
    Danny Admin/Founder
    7,093
    2,100
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Ok, quick reply should be working again. It was a problem with the "ShareThis" code. I'm going to work on getting that to work, but at least now the Quick Reply works!
  13. windstrings
    6,278
    373
    Central Texas
    FF now has 3.06 out... the release notes vaguely indicate there could be a fix for this type of problem too.
    Most of the webpage stuff is not in my league.
  14. richard schumacher
    7,663
    1,038
    United States
    Now how does a thing like that get broken? Was it a bug? Presumably there is not a configuration option "Hang On Quick Reply" :_>
  15. jayman
    13,439
    639
    Winnipeg Manitoba
    FF 3.0.6 was also having the hang, except the status bar displayed "done" instead of "stopped"
    I was able to replicate the problem on an XP Pro SP3 machine running FF 3.0.5 and 3.0.6, and my Ubuntu machine running FF 3.0.5 and then FF 3.0.6
    Galaxee suggested scripting exceptions, which I tried and worked. It's a bit of a drag to manually edit, so I downloaded NoScript from the Mozilla site. This works very well, but in default setting is too strict
  16. jayman
    13,439
    639
    Winnipeg Manitoba
    You just never know
    eg
    "If <url=http://www.priuschat.com>/quickreply = true, then hang"
  17. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    Seems all fixed now.
  18. windstrings
    6,278
    373
    Central Texas
    Mine was fixed right after I first mentioned it.. but I only have windows XP service pack 2 while Jay who still had issues was running sp3.
    Hopefully its resolved now with sp3 also.
  19. jayman
    13,439
    639
    Winnipeg Manitoba
    Ok, did a Post Quick Reply with my XP Pro SP3 machine running FireFox 3.0.6
  20. jayman
    13,439
    639
    Winnipeg Manitoba
    It works fine now
