Why do I need to accelerate downhill?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by RooRocks, Jan 23, 2014.
  1. RooRocks
    RooRocks Junior Member
    2014 Prius Plug-in
    I'm a little confused on how the Prius PIP functions on declines. There are areas that in every other car I drive that will allow the car to gain speed with no increase in throttle but in the PIP I lose speed.
    Does the PIP auto brake?
  2. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    Foot off the accelerator is designed to emulate same in automatic transmission car (regen in lieu of engine braking).
    To remove that effect, slightly depress gas pedal.
    Also, check tire pressure and make sure no brakes are dragging (in neutral, you should not feel any negative g's as you glide).
    'Normal' cars vary in how they coast. Prius regen's noticeably unless you fix it with your right foot.
  3. retired4999
    2,652
    625
    Eau Claire, Wi.
    As it does this it is regenerating, sending electricity to the big battery. Or as stated above lightly put foot on gas peddal and help it glide.
  4. RooRocks
    2014 Prius Plug-in
    Awesome thank you for the help. I am still working on getting use to the car but I am having a blast trying new things.
    I found I was getting better gas mileage if I left EV mode on while driving on the freeway. I was turning it off and then using it again when I got off. I was averaging 300ish mpg using EV on the freeway going 75mpm and dropped down to 160ish when I turned it off.
    My commute is almost 22 miles and when I arrive to work I still have about a 1/2 mile of EV to go.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    To put it simply, yes. When your foot is off the pedal, the car uses some of your momentum to regenerate the battery. Just about all plug-ins and hybrids do this. Regular cars don't do this as they have no battery to regenerate so coasting is more fuel efficient.
    iPhone ?
  6. RooRocks
    2014 Prius Plug-in
    That Fuelly App is nice! I'm going to start tracking.
  7. CharlesH
    2,785
    1,152
    Roseville, CA
    When you let off the throttle in a conventional car, you slow down in part due to compression breaking; the engine compresses the air, but with little fuel (essentially at an idle level). When the air is compressed, it heats up, and that is where the energy goes (wasted). With hybrids, the engine can just be turned off, and the motor-generator put in generator mode to put charge into the traction battery, which can later be used to move the car. Pressing lightly on the throttle tells to control system back off on the generator, so you coast. The throttle is just an input the control system telling it how much power you would like, and has no mechanical connections to anything.
    ftl likes this.
  8. markabele
    5,084
    1,782
    Nebraska
    I agree that it varies widely in "regular" vehicles. Seems like a good rule of thumb is that the bigger/heavier the vehicle the easier it coasts. (ie. my truck coasted a lot better than a little 4 cylinder I had)
