Why do my Windows Fog up so Much???
Discussion in 'Gen 3 Prius Main Forum' started by PriusBull, Apr 11, 2013.
  1. PriusBull
    PriusBull Junior Member
    42
    Chicago, IL
    I am new to the priuschat. I just wanted to know why the windshield and windows fog up so much. I know if I put on the air it will clear the window up but as soon as I stop it starts to fog again. When it is cold outside or rainy this happens a lot. I try not to use the fans to save on the gas and get the best MPGs. Anyways I had a 2009 Honda civic and never had such an aggressive problem with the windows fogging up. Is there a reason for this or is it just me???
  2. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    Not using the fans is probably your problem. The windows are fogging up because there is a temperature differential between the outer and inner glass. Venting in outside air will help.
    Also, keep the inside surfaces clean.
    PriusBull likes this.
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I'll rephrase your question: why is the humidity high enough, and heat inside the car low enough to fog up the windows ?
    If you know the outside humidity and heat, your inside cabin temperature, and think about anything people in the car are doing to add water to the air, your answer may be answered. E.g., a new habit of taking hot coffee into the car would do it.
    Short answer: crack a window.
    Sort of short answer: Some people ignore the physics and just apply rainX to the inside window. I gather one possible downside to this approach is an increase in glare in certain situations.
  4. PriusBull
    42
    Chicago, IL
    Thanks for the feed back! I do crack the windows and I know the heat in the car starts to go up causing the fog but I am just confused on why it is happening more in the Prius than my Honda Civic. Maybe I gained a few extra pounds and I am breathing heavier causing it to heat up faster...lol...but that is not the case...I think the prius maybe releasing some heat throw the ventilation system...not sure!
  5. kbeck
    kbeck Active Member
    420
    274
    Metuchen, NJ
    Um. Two possibilities:
    1. It really is that humid out.
    2. You've got the AC button turned off.
    The Prius, with the environmental controls set to Auto, will cycle the AC on and off when it thinks it should, and that includes when it's cold or humid out. But it will only do that if the AC button is lit.
    I'll say that it works, kind of, although I've found that in the right kind of snowstorm the car will sometimes have to be put into defrost manually in order to clear the windows.
    But if the AC button is off the windows will fog up lots more often. Leave it on.
    KBeck
  6. bisco
    48,987
    maybe the vegetable plastics give off more humidity than civics.
  7. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    To some extent AC use is addictive, since it leaves moisture on the evaporator coil that gets airborne when you use the system next.
    Don't be stingy with the blower fan. In the big picture (blower fan vs. vehicle traction motor use) its effect is miniscule. After it stops raining (and it *has* been raining lately) make it a point to put it on windshield/floor setting and bump the fan speed up to 3 or 4 bars for a while to allow things to dry out.
  8. kbeck
    kbeck Active Member
    420
    274
    Metuchen, NJ
    Back in the day I owned a Datsun B210. Lousy car, decent gas mileage, bought it used, it had had a blown engine and wasn't put together Quite Right, etc. The original buyer got it without A/C. But, geez, put the fan on high and the blame thing would blow you into the back seat, so even 100 F days wouldn't make you too hot.
    I've had a Civic. Its blower isn't in the same class as that B210, but it's definitely better than what the Prius has. Better air circulation plus the fact that the auto mode in the Prius tends to turn the fan speed 'way down means that the Civic's windows stay clearer.
    Like I said: keep the A/C button on.
    KBeck
  9. SageBrush
    11,627
    2,530
    Southwest Colorado
    By the way, cracking open one window will not let much air circulate. Best are two windows, diagonal from each other.
    Just mulling over possible differences between a Prius and a Civic, I wonder if the front window of the Prius is more sloped and that makes it easier for water to condense there.
    Les_PL and PriusBull like this.
  10. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    The climate control has buttons which let you choose between outside air and inside air (recirculating). This operates even when the fan is off.
    My guess is that you have it on recirculating. Tap the button for outside air, and keep it there. That should clear up your condensation problem.
    xpcman and PriusBull like this.
  11. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Use the ventilation blower. Even if you ran it on high all the time, it would not drop your fuel economy by 1/10 mpg. Even using the Defrost setting where the AC runs a bit to dehumidify the air, uses very little power.
    Keep the windows clear and be safe.
  12. Stangar
    Stangar Active Member
    174
    173
    Palmdale, CA
    That's the ticket. "Rebound" has it correct.
    Rebound likes this.
  13. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    Here in Vermont, I have to run the HVAC in windshield/floor setting most of the time for most of the winter. I'm no stranger to managing windshield fogging, but there is just so much glass and with our particular climate, I'm having to get air onto the windshield frequently. I also never (quite literally never) run the air in recir, it's always bringing in fresh air.
    The thing I don't like about this is that, no matter what, if a Defrost setting is chosen the AC compressor WILL run. And that does hurt efficiency (though it's good for defogging, obviously). Pretty much every modern car works this way, the AC is coupled to defrost settings to dehumidify.
    I wish I could just run fresh air to the defrost vents, I think it would do the trick 9 times out of 10.
    daspi and PriusBull like this.
  14. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    I have this problem too, but have found a solution. Prius is a chick-magnetic and having all of those hot, steamy bodies in your car causes the windows to fog. Locking all doors quickly, before they get into your Prius, should prevent this nuisance.
  15. Rebound
    3,961
    2,609
    Portland, OR
    The button next to the Fresh/Recirculating button lets you direct airflow to the windshield; it has a Defrost icon. Using this will not engage the AC, and it will remain in effect even even the fan is off. The two other Defrost buttons control Front and Rear defrost. Only the Front button will engage the AC.
  16. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    The MODE button? Sorry, but you are mistaken, if you choose the feet/defrost position there the AC compressor WILL cycle on. The Big Defrost button on the far passenger's side below the fan speed buttons will as well.
    If you choose face only, feet only, or face/feet the AC compressor won't come on unless you hit the AC button.
    I've played with this extensively for over 2 years. If there is a Defrost icon lit (either in the Mode window of the big Defrost button) then I've found no way to keep the AC compressor from running.
    At least that is how it is in my 2010.
    More discussion: Does A/C automatically run in defrost mode? | PriusChat
  17. PriusBull
    42
    Chicago, IL
    Thanks everyone for the friendly input! :) I will try a couple of these tricks and see which one is the best. Also I am reading a lot about the fans can run on high with no AC on or heat and it wont turn on the engine. What degrees does it need to be set at and where should it blow to help cool or heat me depending on weather and defrosting the windows best? Thank You for the great feed back guys!
    mad-dog-one likes this.
  18. Les_PL
    Les_PL Active Member
    317
    248
    Gdynia, PL
    I don't know how it is in Civic but certainly this is one of the main reasons.
  19. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    The only setting for no AC or heat is LO, with the mode set to something not directly involving the windshield. Any temperature set above that has the potential to cause the engine to run when it otherwise wouldn't before it's warmed up. The exception to this is FAN OFF but unless you're moving enough to force air thru the stationary fan it's effectively "system off". Of course if you're driving above 30 mph or so things will be warmed up enough within a mile anyway.
    It's really dependent on what's needed to keep windows clear for safety and on your personal comfort level.
    I dress warmly enough to have the temperature set to LO with the mode on windshield and floor for my first 3 miles at just about any temperature above 15 degrees. But I'm unusual.
    Don't be crazy--just experiment with your options from day to day. It'll be a moot point in another week or two even up here in the Great Lakes. Spring is coming soon.
