1. Offline
    Soylent New Member
    May 2, 2006
    Message Count:
    346
    Miami Beach, Florida
    Your Vehicle Year:
    According to Toyota's website, the solar roof is not available for the Prius 5. Is this true? And exactly why would they do that?
  2. Offline
    claridiva New Member
    May 24, 2009
    Message Count:
    109
    Dallas, TX
    Your Vehicle Year:
    I recommend you do a search as this has been answered multiple times. The short answer is that the weight of the tires (17") on a V in addition to the weight of the solar roof reduce the MPGs enough to warrant a different EPA categorization.
  3. Offline
    Soylent New Member
    May 2, 2006
    Message Count:
    346
    Your Vehicle Year:
    Thanks.... and sorry about a repeat question. I really did do a search, but I didn't see anything in the first few pages of results. I guess I didn't use the correct terms
  4. Offline
    May 24, 2009
    Message Count:
    109
    Dallas, TX
    Your Vehicle Year:
    No problem! I find that the search tool here is not as useful as doing as doing an advanced search through Google and limiting the queries to PriusChat | Toyota Prius Forums, News, and Accessories.
  5. Offline
    donkitchen New Member
    Aug 4, 2009
    Message Count:
    50
    Mt Airy, MD
    Your Vehicle Year:
    I asked my dealer the same question yesterday when I ordered my V. He said there may be some aftermarket options and I told him there would be no way I'd consider that. Sounds like a leak waiting to happen.
    He didn't however have any good reason like extra weight & lower MPG. Just "I dunno" :)
  6. Offline
    Soylent New Member
    May 2, 2006
    Message Count:
    346
    Your Vehicle Year:
    At the risk of this being another repeat question...sorry if it is.
    So does the solar panel option by itself lower the MPG?
  7. Offline
    V8Cobrakid Green Handyman
    Jun 6, 2004
    Message Count:
    3,703
    110
    Your Vehicle Year:
    it's not about mpg.. it's about legal weight of the car. the solar panel option weighs 400lbs. while it shouldn't effect mpg all that much, it will effect the handling of the car.
    the toyota tech me mentioned this problem a few times. in the "odd things about a prius" he mentioned that in early development there was a problem where the moonroof and the leather seats weighed too much together. so... we may think not having leather is stupid.. cuz it's probably only 50 extra lbs of material.. but it makes a HUGE difference when trying to get this car into production. you can't pass it's legal weight limit (as a manufacturer.. as an owner.. bah.. who cares)
  8. Offline
    tumbleweed New Member
    Oct 3, 2005
    Message Count:
    3,797
    551
    Eastern Oregon
    Your Vehicle Year:
    When cars are tested for emissions and mileage they are tested by the manufacturers and the results are sent to the EPA. The EPA retests about 10% of them to double check the data.
    The cars are actually tested on a dyno while being driven by a computer program. Then the CD, vehicle weight, and maybe some other stuff is factored in and they get MPG numbers.
    So Toyota has all the data on their cars and they know exactly how much they can weigh for certain MPG numbers. With the Prius there was a real effort to keep the weight down so they could advertise a combined number of 50 MPG.
    So as previously stated when they decided to have heavier wheels on the V they needed to save by not having a sun roof. There are a lot of other little things they did to save weight and lower the CD. Some of those things probably only gave them a tenth of a MPG increase but they all add up.
  9. Offline
    Soylent New Member
    May 2, 2006
    Message Count:
    346
    Your Vehicle Year:
    Interesting.... so technically, a Prius II with nothing on it should get slightly better MPG than a Prius V or one with a solar panel.
    However, I guess one could say that the solar panel ventilates the vehicle during hot weather, so the A/C might not have to work as hard or as long initially, therefore increasing MPG.
  10. Offline
    joe1347 New Member
    Jun 9, 2007
    Message Count:
    629
    22
    MD
    Your Vehicle Year:
    400 pounds just doesn't sound right for the solar panel option. Are you sure it isn't closer to 40 pounds?
  11. Offline
    Oct 3, 2005
    Message Count:
    3,797
    551
    Eastern Oregon
    Your Vehicle Year:
    Yes I imagine a Prius II would be lighter and therefore get slightly better mileage, but not by much. So I assume they have a weight range to work with because of course all 4 versions are listed at the same MPG numbers. They must also try to keep them within that range so they don't have different MPG numbers for different models of the same car. I have noticed they do the same thing with all of their vehicle lines as long as they have the same engine transmission configurations.
  12. Online
    • Moderator
    Sep 22, 2005
    Message Count:
    5,905
    1,081
    NY
    Your Vehicle Year:
Share This Page
