Why is my cruising range so low?
Discussion in 'Prius c Fuel Economy' started by priusea, Aug 9, 2013.
  1. priusea
    priusea New Member
    22
    I generally average north of 50mpg on a regular basis. Yet, my cruising range is always somewhere around 300~ miles for a full tank.
    You can see here, at half a tank, my range states 123 miles. The math doesn't seem to add up for me.
    If I regularly average 50mpg, shouldn't a full tank be around 450 miles cruising range at minimum? Am I thinking or doing something wrong? Is this generally an unreliable stat?
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Your average MPG is what it is, not what the display says it is. That said, the range displayed is based on the current average, and will reset itself every time you shut the car off. Your gauge says you have 1/2 tank left, so your true range is whatever 1/2 tank will get you.
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Just because it shows half a tank doesn't mean a half a tank. It is only truly at half the very nano second it blips down to that bar. After that, good luck.
    After my refill, mine shows around 489.
  4. ufourya
    ufourya We the People
    1,258
    336
    42
    From what I can gather by keeping track on only a few refills, the 'cruising range' is calculated based on recent MPGs ( I can't figure out exactly what - last tank or two or something less) and the amount of fuel in the tank MINUS the reserve (approx. 1.3 gallons ) that is still in the tank when the last bar flashes.
    In the heat of summer here in Tx filling to first pump click and averaging only in the high 40s MPG, my cruising range is between 417 and 435 immediately after fill up. I will experiment some over the next few fills and see if I can pin it down any further.
    minkus likes this.
  5. priusea
    priusea New Member
    22
    I never fill my tank up after it initially clicks off. Could that be why? You guys going past the first click?
  6. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    no, it's the computer calculating your mpgs for previous tanks. keep filling and driving. it'll calibrate.
