Why not drive on Neutral Gear?
Discussion in 'Gen 2 Prius Technical Discussion' started by AllenZ, Jul 26, 2010.
  1. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    I wonder what's the difference between Stealth (no arrow on display at all) and Neutral Gear? The reason I ask is, Neutral Gear is much easier to maintain than Stealth.
    Also, when I break moderately hard, it seems like the CVT gear is put to low, so for every yard I travel, more rotation on charging motor. Since Toyota did a great job on transition between regeneration and brake pads, I can't tell when brake pads start to work. Any indications?
    Thanks!
  2. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    When in neutral there is no regenerative braking, 100% friction braking. This is actually a method of cleaning the brakes if needed since they rarely get used for the majority of owners.
    Also driving in neutral is illegal in most states, provinces, and countries.
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    "No arrow glide" actually still uses some HV battery power to propel the car forward, I suspect "neutral glide" is, well, "pure" neutral glide. Hope this helps. :)
  4. blades
    blades New Member
    24
    Frankfort, KY
    If I'm not mistaken (I'm a n00b, so I very well could be mistaken), there is no charging of the batteries in neutral, as I observed the other day on a long downhill run.
  5. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    That's correct. As for the hill in neutral, it is because there is no regenerative braking in neutral.
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
  7. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I have driven quite a bit on long downhill rolls in neutral, there seems to be no savings in fuel consumption. The best consumption is cruise control, excluding hypermilers. The charged green battery comes in handy on the next uphill portion.
  8. richard schumacher
    7,663
    1,038
    United States
    Shifting into neutral lets one of the motor-generators spin uncontrolled. If you do this at a high road speed there is some danger of damaging it with too many RPMs.
