Why?
Discussion in 'Gen 3 Prius Technical Discussion' started by ImeanGreen, Mar 11, 2012.
  1. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Why was the vents for the battery on a gen 3 prius located lower instead of being placed higher? Looks to me that the design flaw can be blocked easily if occupants on the back are not aware of the vents or specially one who never owned a prius before. :(
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I don't know why they do what they do. But yes, you need to be careful especially if you have a coat or blanket in the back seat.
  3. ImeanGreen
    547
    73
    Somewhere out there
    Met a friend last week with the gen 2 prius and the vents where higher. I think close to shoulder level.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    probably because cooling is more important than heating for the battery and cool air sinks. Just a guess though.
    garglo likes this.
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    If the vents were higher the passengers and posters on this forum would complain about the noise. ;)
  6. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Does it draw air in from the back, near the spare, or from the front, by the back seat?
  7. ImeanGreen
    547
    73
    Somewhere out there
    That I really don't know. Maybe someone can chime in on that.
    Has any gen 2 prius owner complained about the noise?;)
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Air is drawn in at the vent, right-hand side lower seat-back. After is passes over the battery, it is vented out the car through vents at the rear of the car (spare tire area).
    There is also a variable speed fan to assist. That is what causes the noise if warm climates. I have never heard the fan myself. :)
  9. tumbleweed
    4,067
    692
    Eastern Oregon
    I have owned both a Gen2 and a Gen3 and the noise is not a problem at all for me. In fact I probably wouldn't have noticed it if someone on here had not mentioned it.
  10. boopie
    boopie Are we there yet?
    47
    Starbucks
    Speaking of the vents, I have no problem driving around in an uncomfortably hot car. I know she can take care of herself and shut down when she gets too hot, but should I be a better owner and keep the cabin cooler?
  11. tumbleweed
    4,067
    692
    Eastern Oregon
    In the hot part of the summer I usually set the AC for 78 or even 80 and sometimes don't use it all. I think our batteries will survive fine.
  12. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Yeah, road trips with the kiddos in back can be a little stressful when they want to snooze with their blankets. I had to keep checking the blanket wasn't covering the vent.
  13. ImeanGreen
    547
    73
    Somewhere out there
    Hmmmm. Do you think it will drain the battery more when setting the temp at 78 ot 80 degrees? Reason I'm asking is that, looks to me that the battery is draining more at this setting because the AC is powered by the battery plus adding the amount of electrical drain when using the heater part. AC + heater = more electrical drain than just the AC. I was thinking that having the temp set at the lowest setting with the fan set at it's lowest setting could probably have the least amount of electrical drain. Just throwing a different line of thinking here.
  14. Former Member 68813
    3,524
    983
    US
    IMHO, the vent should be lower, like under the seat and near the floor.
  15. richard schumacher
    7,682
    1,064
    United States
    If you're comfy then the battery and its controlling electronics are also comfy. But if you ever hear the battery's cooling fan running through that vent then it is too hot, either because you should be using the AC and are not, or because the fan is clogged with dog hair or whatnot.
  16. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Just comment, lots of folks asking 'Will it get too hot' who do not have a city and state in their profile. Without knowing if you live in Nome AK or New Orleans LA, there is no meaningful answer.
  17. tumbleweed
    4,067
    692
    Eastern Oregon
    Sorry my comment wasn't to clear. I usually have the temperature set at 70 to 72 when I am using heat and 78 to 80 when I want AC.
    When I mentioned "battery survival" I was commenting on battery ventilation which draws air from inside the car. Some posters thought having the AC running on hot days would give the battery cooler air and maybe make it last longer in terms of years, not state of charge. My thought was that the battery would be fine even without AC.
    You are certainly correct about battery life in terms of state of charge. A lower the heating temp and A higher AC temp means less energy will be used.
    Actually I think it would be nice if our ventilation systems had separate thermostats for heating and AC such as the ones in most houses.
  18. PruisAz
    PruisAz Member
    140
    34
    Mesa, Az
    When the battery fan is off or when the car is vacant/fan off, what would keep the battery fumes being introduced back into the passenger compartment. I would think there should be some sort of fume check valve or something.
  19. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    The battery is sealed.
  20. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    211
    San Diego, California
    Never had a problem
