Why?
Discussion in 'Gen 3 Prius Technical Discussion' started by Wolfstar, Apr 15, 2014.
  1. Wolfstar
    Wolfstar Junior Member
    Why does my 2010 Prius have a harmonic balancer that is designed for a serpentine belt when the car does not have one?
    Silly question, please discuss...
    48,969
    what it is?
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  4. Wolfstar
    But why is the outer portion of the harmonic balancer on my Prius
    machined to accept a serpentine belt...
  5. fuzzy1
    10,043
    Did they just re-use an existing part, rather than create a whole new one?
    KennyGS likes this.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I suspect it is cheaper for Toyota to carry one part number than two part numbers. They certainly use the engine block in many cars.
    en.wikipedia.org/wiki/Toyota_ZR_engine
  7. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    How about, why couldn't the OP come up with a more descriptive thread title? :p
    SCH-I535
    WE0H and Mendel Leisk like this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    That would be my guess. If they already have a vendor or vendors that create them in mass? Why create a whole new part that needs to be produced? 99.9% of the people are never going to know, or care that The Prius's harmonic balancer is machined to accept a serpentine belt it doesn't even have....
    If it works...it works...
  9. xliderider
    7,848
    3,102
    Honolulu, HI
    So you can run a supercharger? ;)
    SCH-I535
    elementnomore, WE0H and vskid3 like this.
  10. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The title is perfect to ensure you read it. ;)
    This has been brought up before. Not sure if a search would find it though.
    The belt part is there for sure to avoid making another part. The engine in the Prius is used in other Toyotas with some different parts to give a longer stroke/sudo Atkinson cycle. I suspect you would find the part number of the balancer the same as in a Corolla, for example.
  11. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Thats for the optional front PTO used for supporting Kubota implements including front loader, snowblower, blade, and rotary sweeper.
    xpcman, milkman44, WE0H and 2 others like this.
  12. El Dobro
    El Dobro A Member
    6,972
    3,209
    It has grooves 'cause it's in a groovy car. :p
    milkman44, WE0H and orenji like this.
  13. ETC(SS)
    6,493
    Inertia.
    One part. Several cars.
    Some of these cars require belts.
    Why the wonder?
    Now....if you want to wonder about something in a G3-II, ask why there is a photocell on the dash under the smoked plastic cover for a car that lacks automatic headlamps. :)
  14. El Dobro
    El Dobro A Member
    6,972
    3,209
    Are you sure that's not the sun load sensor for the HVAC system?
  15. ETC(SS)
    6,493
    Could be....
    After all they probably have a vehicle tilt compensator for the fuel gauge.
    A gauge that does not measure the bottom 20-percent of the tank! :eek:
  16. El Dobro
    El Dobro A Member
    6,972
    3,209
    Ok, I did some checking and couldn't find a sun load sensor, so that should be the light sensor. There's an interior temp sensor under the start button.
  17. orenji
    orenji Senior Member
    5,884
    3,486
    If its a light sensor, what does it do in the dark? (n)
    WE0H likes this.
  18. WE0H
    WE0H Senior Member
    3,247
    527
    My Prius has a rain sensor. If it determines there is a chance of rain that day, it refuses to leave my garage [​IMG]
    Mike
    jdk2 and orenji like this.
  19. Former Member 68813
    3,524
    981
    US
  20. WE0H
    WE0H Senior Member
    3,247
    527
    I like that blower idea [​IMG]
    Mike
  21. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    And here I thought it was equipped with a light sensor that wouldn't let it even start unless it detected 15 hours and 30 minutes or more of daylight :D
