Windshield wipers not activating straight away
Discussion in 'Prius v Technical Discussion' started by JohnRobinson, Sep 18, 2014.
  1. JohnRobinson
    JohnRobinson Junior Member
    99
    29
    Norway
    Hi all
    Curios problem with my car. When I spray washer fluid quickly the wipers do not start. I can literally empty litres of fluid on the windshield and they still will not activate. Now on other cars I have had you can play chicken and pull quickly on the lever and this I can do a off a couple of times without activating the wipers but not constantly. I had it in for service and the mechanic said he has never seen this problem before and does not even know how to fix it. So any ideas anyone out there? It does get annoying that you have to waste a lot more fluid to activate the wipers "auto" function by holding it on a few seconds longer than needed.
    Thanks in advance.
    Kind regards
    John
    48,977
    if they don't know how to fix it, they have to call toyota. the issue is proxy a circuit board, but it could be in the stalk. try another dealer, that's one of the more ridiculous answers i've heard.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,600
    4,457
    Texas Hill Country
    On mine a quick squirt does not start the wipers. Sometimes I will do the quick spray a few times first when the windshield is really dirty to avoid dragging dry blades across and risking scratches. It also allows the fluid to soak for a period if desired. If I hold it for an extra second it does start the wiper motor.
    kithmo likes this.
  4. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    ^^^^ What RJ said ^^^^
  5. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Ditto, I found it a bit annoying at first but I've gotten used to it.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    Yep....the delay is pretty much how mine works.
    And I've never felt it was a defect or flaw.
    Sometimes I might end up with more fluid on my windshield than I want or need, BUT the alternative or converse is worse.
    Wipers activating early, or with a dry windshield with debris on it, can lead to scratching the glass. I'd much rather waste a few ounces of fluid, than end up with a scratched windshield.
  7. nsfbr
    nsfbr Member
    112
    30
    Northern Virginia
    2013 Prius v wagon
    The OP seems to have a situation that is somewhat different than the one experienced by the responding posters, in that he can "can literally empty litres of fluid on the windshield and they still will not activate." If this were the good old days that would sound like a bad resistor or capacitor (probably a leaky capacitor) in a simple delay circuit. It may be that is still the case. The problem that I see is in knowing where that part is and how to get it (the capacitor) replaced instead of the typical dealer/manufacturer approach of replacing the board that carries it. The part is probably 50 cents at most in quantity 1. So, you really do want to have the dealer help you getting the needed infor from Toyota. Then you can probably replace it yourself if you can learn how to get to it. It will probably be a surface mount part, but that shouldn't be an issue.
    I'd help you out and do it for you if you got me to Norway somehow :)
  8. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    I think he may be exaggerating a little with "litres of fluid". Although it is probably only around a second delay, it does seem a long time when you are travelling quickly with a dirty screen.
