Winter snow and ice cover for front windshield
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by stanleyjohn, Oct 17, 2006.
  1. stanleyjohn
    stanleyjohn New Member
    269
    Higganum,Ct
    Now that winter is rapidly appoaching :( !What do you use to keep the snow and ice off the front windshield? I have a garage but that dosnt help for work.Not looking forward to defrost,brush and scrape.
  2. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(stanlwyjohn @ Oct 17 2006, 04:33 PM) [snapback]334137[/snapback]</div>
    I used to use Rain-X to keep snow and ice from sticking when I lived in a place that saw more winter than Raleigh... It's kind of a pain though, if you don't keep re-applying it every few weeks, you tend to end up with a blurry windshield until it all wears off.
    Before garage, I always used a large piece of cardboard under each wiper so I at least had two pretty good clear areas to see out of in the morning until the defrosters could deal. After I hit that light pole one day, though, I realized that getting up a few minutes earlier to scrape the windows wasn't such a bad idea.
    I've seen those plastic windshield covers with magnets in them to hold them on, but always figured you'd have another thing to drip water into the floor or trunk if you used one away from home.
  3. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    My favorite is Bubble Pak. Get a piece long enough to overlap the windshield on each side and close it in the doors to hold it. To remove just open the doors and shake off the snow and store it in the back til next time. Cheap and very efficient.
  4. brandon
    brandon Member
    771
    Manhattan, KS
  5. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(Beryl Octet @ Oct 17 2006, 04:40 PM) [snapback]334141[/snapback]</div>
    I also used Rain-X for a lot of years. Seems like it was mostly gone after a few hundred miles of driving in heavy rain with the wipers on.
    I now use Aqual-Pel from PPG. It lasts 6 months or more, works better than Rain-X, and doesn't seem to degrade the wipers like Rain-X seemed to. I threw away an unopened bottle of Rain-X when I first started using Aqua-Pel 5 years ago. I apply it every 6 months and it works well to keep bugs and snow and ice from sticking.
    Both products are kind of a pain to put on properly, but with a 6 month lifetime the Aqual-Pel wins hands down.
    - Tom
  6. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(brandon @ Oct 21 2006, 02:25 PM) [snapback]336145[/snapback]</div>
    It looks like thats a daily application (put it on before it snows, wipe the snow off, repeate the next day...)
    <div class='quotetop'>QUOTE(Tom_06 @ Oct 21 2006, 02:39 PM) [snapback]336149[/snapback]</div>
    So, whats the procedure for putting it on, where do you get it, etc?
  7. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
  8. Tom_06
    609
    141
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 23 2006, 09:24 AM) [snapback]336700[/snapback]</div>
    Aqual-Pel can be found at some auto stores (Pep Boys around here in Delaware) or on ebay. Seach Google for a bunch of other sources. It is $5 to $10 per applicator. One applicator will do the windshield and maybe one front door window. I generally buy a professional kit with 24 applicators for around $100.
    Application starts with getting the glass really clean. I use Zaino glass polish and a radom orbital buffer. A couple of passes with invisible glass to finish up. Washing the car followed by glass cleaner is probably good enough. The rest of the directions can be found here:
    http://www.ppg.com/gls_aquapel/ApplyAquapel.pdf
    - Tom
  9. eagle33199
    5,122
    268
    2015 Prius v wagon
    bah, the temp limits (don't apply under 50F) already rule me out for this year...
