we have decided, permanently, that we are no longer making these harnesses. thanks for your interest. _____________________________________________________________________________________ just wondering if anyone's interested in pre-made wiring harnesses for installing a factory EV switch. DH is collecting materials to make one, and we thought we'd see if anyone else was interested while we're at it. **this is mainly to enable people who don't feel comfortable doing this on their own, if you're technically inclined you can easily do the mod without this kit.** [edited for clarity] this would include: -automotive grade (toyota) wiring -all pins needed already soldered on to the wires -a scotch-lok to tap into a power source -and a set of instructions [attachmentid=3428] with all you need is the actual switch and housing (which come together), and the time and tools to pull your dash apart. price would be $20 shipped to your door via USPS. i'll get a picture of the next one we make before we send it out, they turned out much prettier and more organized than this- but to give you an idea: [attachmentid=2884] note: the white connector shown is the housing, it comes with the ev kit and we do not include it. we also bundle the wires together so that they're easy to sort out and not a jumbled mess like this when you get them </span></span>
edit: the pin size for the 06 is different, so we'll have to wait on those. but with the right size pins, yes, it can work on the 06.
Does this require an add on part (such as coastal tech chip) to work with the switch, or will the switch itself transform the car into the Euro, Japanese version? I'm a little confused over this, but I noticed in all your posts you listed "factory ev".
nope, no chip needed. you buy the switch, use the wiring harness to connect it to the ECU and a power source to illuminate the button, a couple grounds, and it's ready to go.
<div class='quotetop'>QUOTE(IsrAmeriPrius @ Apr 8 2006, 10:18 PM) [snapback]237029[/snapback]</div> I'd be interested in one also.
<div class='quotetop'>QUOTE(IsrAmeriPrius @ Apr 8 2006, 11:18 PM) [snapback]237029[/snapback]</div> if you fly us out and put us up for a couple of days, sure
<div class='quotetop'>QUOTE(galaxee @ Apr 8 2006, 11:34 PM) [snapback]237048[/snapback]</div> Ok, I'm confused. What exactly are you sending folks? I thought you had some sort of plug and play module here but from the picture it just looks like a bunch of wires. Getting and plugging in the pin to the ECU is very easy, tapping to ground is easy, the hardest thing is finding connectors and soldering them to wires for the button itself, but you don't include that. I guess I'm just not clear on what you're sending anyone that will make installing the EV button any easier.
<div class='quotetop'>QUOTE(efusco @ Apr 9 2006, 12:01 AM) [snapback]237088[/snapback]</div> The factory EV switch does not come with the wiring harness, it only comes with the white plug. You have to solder your own retainer sockets to wires (or pull them out of an old computer like I did) and attach them to the white plug before wiring them to the ECU and dimmer switch(optional). In the picture posted by galaxee the long wire goes to the ECU, blue wire goes to ground and the green wires go to the dimmer switch.
<div class='quotetop'>QUOTE(galaxee @ Apr 8 2006, 07:00 PM) [snapback]237059[/snapback]</div> Will you drop by Hawaii while you're at it? B)
<div class='quotetop'>QUOTE(efusco @ Apr 9 2006, 03:01 AM) [snapback]237088[/snapback]</div> actually, yes we do. and that's the whole point. ready-to-go wires with connectors we aren't including the white connector shown there because that's the housing, and it comes with the EV switch kit. no need to buy something twice. and the pin for the ECU isn't way oversized so you don't have to go trying to jam this huge pin into a too-small hole like many have had to in the past- also easier to remove if need be.
<div class='quotetop'>QUOTE(galaxee @ Apr 9 2006, 11:01 AM) [snapback]237162[/snapback]</div> Ok, I get it. Might I suggest including the wire taps for tapping into the power source and ground...that would truely save everyone a trip to Radio Shack.
<div class='quotetop'>QUOTE(efusco @ Apr 9 2006, 12:10 PM) [snapback]237164[/snapback]</div> evan, evan, evan.... in the original post: "heck we'll also throw in a scotch-lok to make the connection for the illumination." and we ground to a screw inside the dash. i formally intruduce a new board acronym: RTWFT (read the whole fine thread) :lol:
So these are the general types of connectors that'll be attached to the ends of the wires and these snap into the white plug that comes with the EV button. Everyone should know that while this will speed the process of installing the factory EV button a bit and save time from running around trying to find the correct connectors and digging the pin from the steering column that it is still a relatively involved installation that involves significant dash disassembly, tapping into at least 2 wires (and a ground which is most easily accessed by tapping another wire as well.) And then you've gotta run the long wire behind the dash to the ECU and plug into the proper socket. Worth $20? Probably if you don't have the time, energy, whatever to run around and find the parts or if you don't have a soldering gun and stuff... I definately spent close to $30 on stuff when I did the original EV button install. That said, I've used the soldering gun for many other home projects and Prius projects since...so that was a worth while investment for me. I'm NOT trying to talk anyone out of buying this from Galaxee, I just want to make sure everyone knows what they're getting into. You should definately read both of the following articles to be absolutely certain you know what you've going to have to do realizing that some parts won't be necessary since the pin, wires and connectors to the EV button are included with Galaxee's harness. Original EV Button Installation Article Factory EV Button Install One last question for ya Gal...will you guys include instructions with photos of which wires go where on the connector and which wires tap into which wires on the dimmer and where the pin goes and how the dash is disassembled? Or will folks need to reference the articles above? <div class='quotetop'>QUOTE(galaxee @ Apr 9 2006, 11:20 AM) [snapback]237169[/snapback]</div> Sorry, shoulda figured that our...never heard the term scotch-lok before
<div class='quotetop'>QUOTE(efusco @ Apr 9 2006, 12:29 PM) [snapback]237172[/snapback]</div> yes, you will have to disassemble the dash to do this project, but we only tap into one wire. we ground the illumination and EV on a screw in the dash. it's less intrusive on the electrical system that way and leaves less evidence if you want to remove the switch. yep, step by step instructions, and all wires on the harness are going to be labeled for clarity. photos where necessary to be absolutely clear.
<div class='quotetop'>QUOTE(cdavid @ Apr 9 2006, 08:41 PM) [snapback]237310[/snapback]</div> It would be *great* if all this stuff -- the new harness & connectors, plus OEM switch, and whatever other componets are required -- came in one plug & play assembly with instructions.
