1. Offline
    Jaay Dee New Member
    Start a Conversation
    Feb 28, 2011
    16
    Chesapeake
    Your Vehicle Year:
    Today, we got a flat tire, so went to put spare on. The jack bent when we jacket it up..so had to borrow jack from neighbor. Once we got the spare on, it made a funny noise..on the way home, it wouldn't drive over 22 MPH, and once we replaced the original tire (got a new one/fixed), the car started to accelerate and brake itself!! It was definitely not normal. And there was no resistance to the pedal or floor mat interference. I believe it was a computer problem? Anyways, when you hit the brake (cause it was going so fast) you could hear the engine strain as it groaned to a stop. Got the car home and in the garage for the night..That was work in itself, not driving it through the wall! Arranged to get the Prius towed to Toyota in the morning..see what they can do. It's intermittent when it does this, and very weird. Any suggestions/comments?
    ALSO, it only did it in gas mode, NOT electric/battery mode!!
    Btw, the spare tire also went flat while driving, with no holes, nails etc..was VERY weird.
  2. Offline
    mikewithaprius New Member
    Jan 5, 2011
    656
    99
    Rhode Island
    Your Vehicle Year:
    Since the spare tire sounds like it was already flat, maybe that's why you couldn't move very well.
  3. Offline
    seilerts Battery Curmudgeon
    Mar 7, 2010
    3,296
    1,414
    Santa Fe, NM
    Your Vehicle Year:
    First of all, what caused your flat tire? Did you run over something? And do you have any ABS/VSC warning lights? I wonder if one of your brake lines got cut, that would only leave pressure to half your system, and give you only half the braking power. And how did you bend the jack? That is very difficult to do. Were you jacking the body at the forward pinch spot, or were you jacking the suspension? Hmm, bent jack, won't go over 22 MPH but "going so fast", you sound like what we call a troll, someone who in their first post writes an impossible scenario or inflammatory material to get the rest of us to waste time.
  4. Online
    uart Senior Member
    Sep 7, 2009
    2,759
    475
    Australia
    Your Vehicle Year:
    Got to admit I was thinking the same thing. The OP's choice a big smiley face icon to represent a post about a really severe mechanical problem also makes me a little suspicious. :eek:
  5. Offline
    Mar 27, 2004
    7,634
    837
    United States
    Your Vehicle Year:
    Never blame malice when stupidity suffices.
  6. Offline
    Jaay Dee New Member
    Feb 28, 2011
    16
    Chesapeake
    Your Vehicle Year:
    Hey guys - Thanks for the reply..I am new to this, as that was my first post. First off, when I chose my "smiley face", I thought it was for my "profile picture", and not as an emoticon to my post - sorry about the misconception..I made this account so I can find out whats wrong with my Prius..Like I said, I'm new here..Ease up please..
    Our first flat tire (on the stock tire) was caused by a nail. So I jacked the car up, and as the car went up, the jack started to bend to the right. As soon as I took it down, the jack re-gained its shape..thought this was very odd. I was parked in a garage, too, so the floor was even.
    As soon as I put the spare on and took off the jack (borrowed a neighbors jack), I checked the spare tire pressure (was 60PSI as it said it should be on the tire). So I drove to work, checked it then, and it was doing fine. On the way home, the car started not letting me go over certain speeds. On the highway, it was 42..then once I got off and stopped, checked pressure (still 60 and full), I continued on..but this time, the car only let me go 22 MPH..for the rest of the way home, so I had to take back roads opposed to the interstate! The "slippery condition" yellow light flashed a few times, but none others..it then went off, and the conditions were DRY and CLEAR. I am puzzled. :confused:
    Then, when I went out about 2 hours later (pickup the kids) about 2 minutes away, it did the same thing (22MPH) and then I heard a loud noise and the car started to rumble. So I pulled over (neighborhood still) and saw I had a flat..so I took it off (still had neighbors jack) and inspected it thoroughly and saw NO holes, nails, creases, tears, etc!! So I used the car pump to pump it up and it held. When I got home, used soapy water for 10 minutes all over and NO leaks, al all. Was VERY puzzled again!! Has anyone else ever had this happen? Am I missing something?
    So I got home, and got my old tire plugged. Put it on the car, and called Toyota to complain about it only going 22MPH and that my jack seemed very 'cheap'. They said to drive the car for 10 minutes and use the TPMS reset button under the steering column to reset the system, and see what the results are. So I did just that..Drove it out and it seemed to work fine..but the second the gas engine kicked in, the car accelerator was like a paperweight (it was useless) as the car stopped accelerating around 18MPH, and just stayed there. Every time I tapped the brakes, they seemed to be strained, as you could feel the engine was still trying to maintain a speed of 22MPH, but I was stopping it. It felt like a car when you try to back up with the parking brake on, but opposite. So I put on my flashers and slammed the brake to the floor. The car slowly came to a stop (not TOO slow, but slower than normal). I could still hear the engine going and could feel it trying to take off. So i put it in neutral, and the engine was still 'racing'..I turned the car off. The second I turned it on, the engine was racing, but a couple seconds later, all noises stopped, and it seemed to be on battery mode. I was in the middle of a street, so couldn't just stay there..I put it in drive and began to drive. It was doing fine, until it switched over to the gas engine, where the car took off. It went WELL past 22MPH. The speed limit on the road I was on is 45, which it reached very shortly after passing the 22 mark. It felt like someone had the pedal to the floor - BUT, as me and my passengers saw, I had NO feet on either gas or brakes. I tapped (pumped) the brakes lightly, shifted to neutral, put on flashers, and came to a stop. When I shifted to neutral, I could still hear the engine racing loudly, as if someone was flooring the car, but the brakes worked fine in stopping me the rest of the way.
    I got the car home by driving slowly the first half of the ride (main road I was on was about 2 minutes from my house), making sure to stay on electricity as long as I could..but as soon as it went into gas mode, I put it into neutral and let it coast as far possible as it could (on my street by this point) because people park on the side of the roads and didn't want to risk hitting anyone else's car..So once I got a couple houses down, I turned like I was pulling into a neighbors driveway, (it only made it up the bottom part about a foot in neutral), and I backed up and drove backwards (I figured out awhile back that when in reverse, 9 times out of 10, the car is in Electric/battery mode)( only a house away) to my driveway, where I backed it up the driveway and into the garage slowly..So called toyota back and they arranged to come tow it this morning..will let ya'll know how it goes in the shop and what the final results are.
    Oh, and 'Seilerts', I was jacking where the Toyota Prius Owners Manual says to (not the big manual, but the little one I got on tire changing, oil changing, and light changing, and "Preventative Maintenance").
    Let me know if anyone has any more questions/help/fixes to my problem that I can tell the dealer to look at while in there. Not trying to 'troll' anyone, just trying to make sure that my car is safe to drive and that my problem is known, in the case that someone else has this problem.
    Thanks for the +'positive'+ feedback!
    2 people like this.
  7. Online
    2009Prius A Wimpy DIYer
    Mar 25, 2009
    2,463
    378
    Your Vehicle Year:
    Ask the dealer to give you all the DTCs and sub-codes and post here for the resident experts to interpret what went wrong. Good luck!
    1 people like this.
  8. Offline
    Mar 7, 2010
    3,296
    1,414
    Santa Fe, NM
    Your Vehicle Year:
    Clearly your car is unsafe to drive and a dealer is your best alternative. Yours is one of the strangest stories I've seen yet.
    1 people like this.
  9. Online
    uart Senior Member
    Sep 7, 2009
    2,759
    475
    Australia
    Your Vehicle Year:
    Yeah it's very unusual. It sounds like the flat tire was just an unrelated coincidence to the more serious problem that has suddenly developed.
    Initially I was wondering if the jack malfunction might have caused to to fall off the jack and damage something. Possible using an incorrect jack point and unchoked wheels on an incline or something like that.
    1 people like this.
  10. Offline
    Jaay Dee New Member
    Feb 28, 2011
    16
    Chesapeake
    Your Vehicle Year:
    I know..the second I called the dealer and told them the problems, they were puzzled. They said the computer could be messed up..and when it fell off the jack, the tire was still on, and I checked everything out and it seemed to work fine. It wasn't till after work when it acted up. They said to pick it up tonight that its fixed, so I will let you know the results. Will also see if I can get them to give me some codes, because ya'll REALLY DO seem to know your Prius's, or 'prii', as they say Haha. Hopefully it is fixed, but knowing by their past, they wait till you get there to tell you the big ticket items that have to be replaced. Will update ya'll soon! Thanks for the feedbacks!
  11. Offline
    SageBrush Senior Member
    Jun 4, 2008
    7,218
    1,158
    New Mexico
    Your Vehicle Year:
    Does this car have a TPMS ?
  12. Offline
    Jaay Dee New Member
    Feb 28, 2011
    16
    Chesapeake
    Your Vehicle Year:
    Yes..and once we got the stock tire back up and on the car, the light went away right away and didn't come on again.
  13. Offline
    Jaay Dee New Member
    Feb 28, 2011
    16
    Chesapeake
    Your Vehicle Year:
    Just got back from Toyota. Picked up the Prius.. :) Went ahead and got oil/filter change, tire rotation, cabin air filter replacement (dirtyyyyy), inspection, brake pad checkout (checked out fine), rotor checkout (checked out fine), alignment, and tire balances replaced.
    They gave me the sheet with everything they did (cause the receptionist doesn't know what they did), so just read it. They replaced my accelerator pedal, and all components going to the engine..they said something in the works was getting kinked, and wasn't letting (something) it open and close (maybe throttle?)..so a whole new pedal assembly, along with a new stopper on the back, to reduce sticking (friction), and a reset of codes to normal codes (everything seemed to check out on their end, but did it just in case, because of all the weird problems we had with it braking and accelerating and not bing able to go over 22MPH.
    It was all under warranty (the pedal and code part). Here is what the sheet says: PRIORITY TOYOTA GREENBRIER, New pedal and added pedal mod for Tundra, Matrix, Prius, Tacoma, Camry, and Highlander, 1262 W93
    Claim Type: SC
    53349 Complete C: Recall 901 c: gas pedal interference r: reshaped new gas pedal and added stopper, complete health check.
    Underneath it says : recommended work upon next visit:
    MISC MOTOR/GENERATOR SERVICE < - - - - - What is this?
    PRIORITY FEUL INJECTION SERVICE < - - - - - ?
    FEA FRONT END ALIGNMENT < - - - - - - - - - - Just had this done today..but I guess they do it every time??
    They also attached they neat little colorful sheet with boxes and checkmarks called : VEHICLE COURTESY INSPECTION CHECKLIST
    And everything got a green check mark. As of now car drives fine!! Will let you know along the way if it STAYS fine! Didn't have any 'near death experiences' again yet, which is very good.
    Thanks for the replies!
    1 people like this.
  14. Offline
    2k1Toaster HID Guru
    Feb 14, 2010
    3,195
    762
    Rocky Mountains
    Your Vehicle Year:
    I must say this is a puzzling one.
    I am glad you got your car back and it is working, but I am disappointed that they took the usual route of replacing parts until it works instead of diagnosing the problem. Probably one loose wire or connection somewhere that caused them to trash hundreds of dollars (thousands of dollars retail to the customer) of parts. 4 figure solution to a 2 cent problem that we will never know what it was...
    1 people like this.
  15. Offline
    Jaay Dee New Member
    Feb 28, 2011
    16
    Chesapeake
    Your Vehicle Year:
    When you really think about it, they DID only have the car for a day and a half. Don't you think something serious should be more cautious and take more time? Maybe call up headquarters and get an opinion and see what the source of the problem is? You would think they would show more effort. I bet if it was out of warranty and I was PAYING, they would hve done a better job, don't you think?
  16. Offline
    2k1Toaster HID Guru
    Feb 14, 2010
    3,195
    762
    Rocky Mountains
    Your Vehicle Year:
    To diagnose, yes. To fix, no. All the parts are modular and are not connected with much more than wires. So it is as simple as popping off a panel, unscrewing the part, unplugging it, and putting in a new one.
    They won't care. They fixed the problem by replacing the parts. Noone can ever know what the source of the problem is.
    They did a fine job doing what they know how to do. The sad reality is that the dealer "techs" are no more than monkeys when it comes to "repairs". It is much much easier to replace a bad part then it is to fiddle with it and make it work again. Just the way things are. When your <electronic device> dies, most people just buy a new one. It takes someone with more knowledge than your average best buy salesman to actually fix it. Same deal here.
    1 people like this.
  17. Offline
    Jaay Dee New Member
    Feb 28, 2011
    16
    Chesapeake
    Your Vehicle Year:
    All of your points are very valid and true! I agree %100. They COULD have worked longer to find the source of the problem, and maybe document it for future reference, if other people start having the same problems..but they seem to have taken the 'easy' way out.
  18. Offline
    Jul 12, 2007
    10,601
    487
    Adelaide South Australia
    Your Vehicle Year:
    You should never use a space saver spare on the front, always change a back wheel then put the back wheel on the front if you have a flat front tyre. Sorry if this has already been said, I have limited time.
    1 people like this.
  19. Offline
    Jaay Dee New Member
    Feb 28, 2011
    16
    Chesapeake
    Your Vehicle Year:
    OH MY GOSH! I never ever in ever would I have thought of that! Is that why it only took me to 22mph? Because it was on the front and not the back? The only thing is I didn't has much time to change it..but I guess I ALWAYS have time to do something right, so I don't get these results again. Thank you SO MUCH for telling me this!
  20. Offline
    KK6PD _ . _ . / _ _ . _
    Mar 24, 2008
    3,572
    611
    Los Angeles
    Your Vehicle Year:
    An entire thread....... and what, no evpv??????
Share This Page
