Won't start without key
Discussion in 'Gen 2 Prius Technical Discussion' started by jaybird, Apr 5, 2009.
  1. jaybird
    jaybird Junior Member
    East Hampton, NY
    Recently my 2008 is not starting unless the key is in the ignition. Very annoying and unusual. Any thoughts?
  2. jayman
    jayman Senior Member
    13,439
    639
    Winnipeg Manitoba
    You mean, the fob must be inserted into the slot on the dash? Is the SKS completely dead? Can you use the smart entry feature? Did you check the SKS button under the steering column?
    Your car is new enough not to need a new fob battery. However, a handful have been known to fail early. If the dealer won't check it out, a new fob batter can be picked up at any place that sells watch/calculator/hearing aid batteries, should be under $5
  3. jaybird
    East Hampton, NY
    Yes the fob must be inserted and I can't get into the car either without clicking the fob. I will check the SKS button under the steering column. I am not familiar with that button but will look. Thanks!
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The button needs to be in the 'out' position for the SKS to work. It's easy to bump the button getting in or out of the car. My bet is on the button being pushed in.
  5. nooaah
    nooaah New Member
    380
    Philadelphia
    I had the same problem as the author of this thread several months ago. The button was in the correct position and I didn't have a spare key in the car. I depressed the button several times and started/restarted the car. Eventually it began functioning correctly again and I haven't had a problem since.
  6. RobH
    RobH Senior Member
    2,369
    978
    70
    Sunnyvale, California
    I think the SKS system is designed to shut itself down after several days of non-use. This is done to conserve power in the 12V battery. It should restart as soon as you get the car to Ready mode, although that may require putting the keyfob in the slot in the dash. This is written up in the technical manual about SKS, but I don't recall the exact details.
  7. TonyPSchaefer
    14,816
    2,496
    66
    Far-North Chicagoland
    So where is jaybird? I'm waiting for a resolution.
    Though I would like to suspect the SKS I am interested in case it's not.
  8. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Maybe he locked himself in the car & can't get out.
  9. boppo
    boppo Active Member
    799
    138
    Owego, NY
    LOL, good one jimn
  10. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    Needs to call BlondeStar?
