1. Offline
    wigwag Junior Member
    Start a Conversation
    Jul 8, 2010
    CA
    Your Vehicle Year:
    Given the high price and "lifetime" claim for WS atf I assumed it was synthetic. I bought some for a change and found a MSDS in the bottom of the box. The salient point: "mineral oil concentration by weight- 80-90%" To me this means dino oil. Viscosity is given as 23cSt@40c and 5.45cSt@100c. Make that really thin dino oil. The only synthetic I find in the marketplace that is recommended by it's maker for this application is Red Line D6 with a viscosity of 30.7cSt@40c and 6.4cSt@100c. Does anyone know of any other suitable synthetics?
  2. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    18,043
    2,916
    Northern Michigan
    Your Vehicle Year:
    You are talking about transaxle fluid for your Prius? In that case use the stuff recommended by Toyota. In the Prius it also serves to insulate and cool the MGs; do that wrong and you have a very expensive repair bill.
    Tom
  3. Offline
    6lark5 New Member
    Dec 6, 2011
    28
    San Jose, CA
    Your Vehicle Year:
    The transaxle is a very expensive part to experiment with.
    ATF WS isn't expensive. Its about $30 for 4 quarts from the dealer.
    I change mine every 30k to 40k miles (about every two years). No problems.
    Its a simple DIY job. Remove and replace. Done.
    My last Toyota lasted 22 years before I sold it. I find simple preventative works best.
    Its cheaper NOT to experiment.
  4. Offline
    The Critic Resident Critic
    Oct 28, 2005
    1,926
    329
    Marina, CA
    Your Vehicle Year:
    Synthetic or not synthetic is not the main concern. The main concern is whether the fluid is the proper one for the transmission. In this case, WS is the only fluid that has been tested to work correctly.
  5. Offline
    Feb 26, 2007
    7,464
    1,038
    Carmichael, CA
    Your Vehicle Year:
    There is at least one person using D6, I think he finally published a good UOA result.
    I'm using WS on a 30k change schedule.
  6. Offline
    tumbleweed Senior Member
    Oct 3, 2005
    3,966
    615
    Eastern Oregon
    Your Vehicle Year:
    There may well be some fluids that would do the job just fine but as 6lark5 mentioned the transaxle is to expensive to experiment with.
    There are some fairly high voltages in the transaxle due to the two motor/generators. We do not know how well any of those other fluids would insulate.
    I have had two UOAs done and 30K seems to be a good change interval. Maybe the first change could be done a bit sooner.
  7. Offline
    seilerts Battery Curmudgeon
    Mar 7, 2010
    3,296
    1,414
    Santa Fe, NM
    Your Vehicle Year:
  8. Offline
    jdcollins5 Senior Member
    Aug 30, 2009
    3,267
    646
    Wilmington, NC
    Your Vehicle Year:
    Agreed. Every 30k miles is about every two years for me. At $32 every two years, I see no reason to experiment with any other fluid with this expensive transaxle with the MG's.
  9. Offline
    Mar 7, 2010
    3,296
    1,414
    Santa Fe, NM
    Your Vehicle Year:
  10. Offline
    El Dobro A Member
    Jul 12, 2011
    2,094
    494
    Your Vehicle Year:
    Synthetic or not, after what I got out of, maintenance on this trans is a veritable bargain.
  11. Offline
    spiderman wretched
    Jul 5, 2009
    6,744
    1,170
    Alaska
    Your Vehicle Year:
    do tell... any pictures?
  12. Offline
    El Dobro A Member
    Jul 12, 2011
    2,094
    494
    Your Vehicle Year:
    I had a VW with a DSG transmission and the service is at every 40,000 miles. The dealers charge anywhere from $300 to $600 plus to do the service. For a do-it-yourselfer, about the cheapest I've found the maintenance parts alone is $129.00 plus shipping. You need a special tool to add the fluid and you also need something to monitor the fluid temperature during the service. I made the tool myself for around $10, but if you want to buy the official tool, I heard it's over $200 now. From what I've seen of the Prius trans, it's a piece of cake to service.
    Here's the kit for a DSG change.
    DSG Service Kit 40k - IDParts.com
  13. Offline
    hlunde Member
    Dec 22, 2009
    248
    24
    Mendham, NJ
    Your Vehicle Year:
    Prius does not have a torque converter to generate high shear and heat, and it doesn't have to deal with the clutch wear particles. The only mechanical parts are gears and bearings. But insulation resistance of the oil could be a factor so don't deviate from specification!
  14. Offline
    2,713
    394
    Greater Vancouver, BC, Canada
    Your Vehicle Year:
    ATF-WS is by no means expensive comparing to Honda's CVT fluid, which costs $16~20 in Canadian funds, for US Quarts.
    Also, I don't think there's anything inherantly better in a fluid being synthetic.
    Also, the conscensus around here is it's better to change it periodically, regardless of Toyo's claims.
  15. Offline
    xs650 Senior Member
    Jul 2, 2010
    4,414
    1,297
    Northern California
    Your Vehicle Year:
    Synthetics don't normally shear to a lower viscosity as fast as regular oil.
    For a "lifetime" oil there would be some advantage to that.
  16. Offline
    32kcolors Senior Member
    Jul 14, 2009
    4,906
    680
    Redondo Beach, CA
    Your Vehicle Year:
    So the transaxle fluid is supposed to last for the life of the car according to Toyota and yet it's not synthetic?
    Or is only the original transaxle fluid synthetic and Toyota's recommended stuff (since it's meant to be replaced periodically) not synthetic?
Share This Page
