Yellow exclamation Warning Lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RCapealini, Aug 15, 2011.
  1. RCapealini
    RCapealini
    Expand Collapse
    Junior Member
    Jacksonville, FL
    I was hoping someone could help! I can't seem to find my manual, and I'm not sure if I should drive my car home after a warning light came on during my drive to work. It was a yellow exclamation point within a bracket. Can anyone tell me what this means?
    Thanks in advance!
    Rebecca :confused:
  2. kohnen
    kohnen
    Expand Collapse
    Grumpy, Cranky Senior Member
    317
    48
    Fullerton CA
    (_!_) = One of your tires is low. Check around your car to make sure one of your tires isn't low. When you find the one that is, put air in it, and get it fixed soon!
  3. seilerts
    seilerts
    Expand Collapse
    Battery Curmudgeon
    3,326
    1,445
    38
    Santa Fe, NM
    The yellow exclamation is the brake control warning light. It may go away on its own after a few restarts. If not, it may indicate a potentially serious issue. The wisest course is to visit a shop (dealer or independent Toyota specialist) to get that code read.
  4. NYPrius1
    NYPrius1
    Expand Collapse
    Active Member
    1,172
    124
    Middletown, NY
    I Thinks it's the low tire warning.
  5. seilerts
    seilerts
    Expand Collapse
    Battery Curmudgeon
    3,326
    1,445
    38
    Santa Fe, NM
    There are unfortunately two warning lights that look similar. kohnen's (_!_), where the _ are really squiggles like ~, would be for low tire and/or other problems with the tire pressure monitoring system. The brake system warning is also yellow and looks like ((!)).
  6. Rupert B Puppenstein
    Expand Collapse
    Active Member
    240
    101
    Georgia
    I had this happen this morning. It was unusually cold and within a few minutes, it shut off. I will check my tires to make sure one isn't leaking but does anyone think the cold morning could have something to do with it?
  7. JimboPalmer
    JimboPalmer
    Expand Collapse
    Friend to those who want no friends
    8,945
    2,859
    Greenwood MS USA
    Tire pressure goes down in cold weather. Sadly, air never leaks into tires.
  8. Rupert B Puppenstein
    Expand Collapse
    Active Member
    240
    101
    Georgia
    That is sad. :(
  9. qbee42
    qbee42
    Expand Collapse
    My other car is a boat
    18,040
    2,983
    Northern Michigan
    To be pedantic, air does leak into tires, but it leaks out at a faster rate.
    Tom
  10. Sagitar
    Sagitar
    Expand Collapse
    Junior Member
    59
    Ampthill
    Really? I always thought the rate of leakage was a function of the pressure difference across the void through which leakage is occurring.
    That being so, the internal pressure would need to be less than the external pressure for inward leakage to occur!
  11. qbee42
    qbee42
    Expand Collapse
    18,040
    2,983
    Northern Michigan
    The rate of leakage *is* a function of the pressure difference across whatever membrane or void is in question. That part you have right. What is confusing you is that the rate of leakage is the net result of molecules leaking in and molecules leaking out. Think of it like a shopping mall where some people are walking in and some are walking out. Both happen at the same time, but if more walk in than walk out, you end up with a higher density of people inside.
    Air in tires is essentially an ideal gas. As such, the gas molecules bounce around randomly with very little interaction. Molecules inside the tire occasionally find microscopic holes and escape. Likewise molecules outside the tire also occasionally find the same holes and sneak in. If the tire pressure is the same as the outside (a flat tire), just as many molecules sneak in as escape. The tire neither inflates or gets any flatter. The molecules are going in and out, but the net result is zero change.
    Now if we increase the pressure inside of the tire, we have more molecules zipping around. More molecules means more of them will find holes and sneak out, so the net result will be a loss of pressure. Molecules are still finding their way into the tire, but more find their way out.
    In case you are interested, this is why you can smell a fart upwind.
    Tom
    Reckstar likes this.
