windsheild washer nozzle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by unfdozer, Jul 30, 2009.
  1. unfdozer
    unfdozer New Member
    JACKSONVILLE, FL
    My drivers side windshield washer is not working/spraying. The passengers side works fine. I thought it maybe due to a loose connection but I am not able to get through the insulation that cover the underside of the hood (without tearing it). I am not able to pull the plastic plugs out either. Any suggestions? I have been looking for a new/used insulation and plugs but I am not sure what their real name is so I am having difficulty searching.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Did you try sticking a pin into the nozzles to see if they are clogged?
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    if you can't find a sewing pin for the nozzles a lot of times a few brushes with a clean toothbrush will do the trick.
  4. unfdozer
    unfdozer New Member
    JACKSONVILLE, FL
    I tried that idea and it still does not work.....suggestions?
  5. FBear
    FBear Senior Member
    355
    Maplewood, NJ
    2015 Prius v wagon
    Get a compressed air canister the type you would use to clean a computer. With the nozzle put it up against the non working unit, spray it in so the air will hopefully clear what ever is blocking the washer nozzle.
  6. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    Check that the hose going to it is not pinched. You can pull the hose off the nozzle under the hood, and see if the fluid squirts out there.
  7. unfdozer
    unfdozer New Member
    JACKSONVILLE, FL
    Pull the hose from the engine side not the hood side correct?
  8. unfdozer
    unfdozer New Member
    JACKSONVILLE, FL
    I am not able to get to the hose that is connected do the hood. There is a barrier (not sure what it is called or what type of material) between the engine and the underside of the hood. The material is held to the hood by round plastic screws. I have not found a way to remove them without tearing the barrier or breaking the screens. Suggestions?
  9. unfdozer
    unfdozer New Member
    JACKSONVILLE, FL
    :eek:
  10. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Here's what little help I can give:
    The piece under the hood is caller the "Insulator" and it goes for
    ~$157, :eek: the plastic screws, "Insulator Clips," for it go for $0.83
    apeice at this parts supplier:
    Wholesale Toyota Parts
    I guess the smart thing to do would be to cut/abrade the heads off
    the clips to remove the Insulator. :p
    Someone with access/a subscription to the Prius Collision Damage,
    Body Repair Manual will have to see what it says about removal/
    replacement.
    Should you want info on the parts of the washer/wiper system, you
    have to push down through the levels under "windshield" in the list on
    the left of the page. The nozzles go for ~$18.
    Hope this helps.
  11. unfdozer
    unfdozer New Member
    JACKSONVILLE, FL
  12. drees
    drees Senior Member
    1,782
    247
    Funny - my driver's side nozzle is slowly becoming more and more clogged as well.
  13. problemchild
    problemchild New Member
    429
    36
    Vinegar and a tooth brush. Make sure to rinse it off the paint after.
