I'm confused about S4 mode ????????
Discussion in 'Gen 2 Prius Technical Discussion' started by uart, Nov 21, 2009.
  1. uart
    uart Senior Member
    4,220
    1,211
    Australia
    In these forums I often see people talking about getting the Prius in "full hybrid" or "S4" mode for maximum efficiency, but when I looked it up I found it a little confusing.
    From what I've read the only way to get into S4 mode is to be in S3 mode and stop with the ICE running and then wait 5 to 10 seconds until it shuts off. Then apparently you're in S4 mode.
    My question : Is there really no other way to get into S4 mode other than stopping like that? For example, if I drive non stop for 100 miles on a warm day do I really never get into "full hybrid" S4 mode.
    I've seached the forums and googles but so far I haven't found any other description of how to gt into S4 mode other then the following :
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    If your driving non stop you don't really need to be in S4. S4 is only really useful if your in city driving or your trying to pulse and glide.
    And yes the only way to get into S4 is to come to a stop and let the engine run for 10 seconds.
  3. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    It seems there isn't. I tried many times. You can drive 100 or more miles and warm up your engine to the edge of explosion, but you won't get into the S4 ops unless you stop with the engine running and wait until it stops. I don't know why it is implemented this way, and I asked here at the PC and the techs in the Toyota dealership - nobody was able to give me a valid answer.
    Apparently, the gen III Prius behaves differently, if I can judge from a test drive I had - I didn't notice that behavior. Perhaps the gen III owners could tell us how their cars behave?
    I would be really grateful if anybody could ever explain me why is the S3-S4 transition working the way it is, as it really annoys and puzzles me all the time I have to drive wastefully in the 3a mode, unable to stop because of the traffic... :confused:
  4. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    You should note that S1-S4 is not Toyota terminology, it is our terminology. So Toyota people won't know what you are talking about if you say S4 to them. Toyota won't say why and no one here is figured it out why the S3-S4 transition is the way it is.
    So there is no why, it just works that way in the Gen II.
    If you would install an EV switch, you can force the ICE to go out below 34 MPH just like you are in S4 anyway.
  5. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    Well, I would dare to respectfully disagree. I often find myself diving wastefully in the city in the 3a mode, unable to stop for a relatively long time because of the traffic. It is really annoying. Especially when I finally come to a stop at lights and the green shows *before* the engine stops - that really makes me mad, as I have to go because of the cars behind me before getting into the precious S4 stage...
    If I feel the transition is just about to occur, I even wait for that additional second or two when the green shows up, making the drivers behind me mad, not knowing what am I waiting for :D.
  6. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    I didn't tell them about the "S4", I just explained them what I meant and they knew what I am talking about, but also didn't know the reason.
    There *is* why. This simply puzzles the engineer in me - I *have* to know :p. This car is an engineering marvel, there *has* to be a reason, however bizarre :).
    I have the EV switch (it is a standard feature here in the Europe), but it is not helpful when I want to P&G...
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    If you're driving below 34mph during the 100 miles trip, you're always at S3a and the ICE continues to run.
    If you're driving above 34mph, you're at S3b and it's identical to S4.
    If your coolant temperature is above 66C(150F), following sequence will reach you S4 instantly;
    • power off
    • wait for 5 seconds
    • power on
    However, it's hard to accomplish the sequence during non stop driving. :)
    Ken@Japan
    2 people like this.
  8. hill
    8,916
    Yes . . . remember in Detroit? Otsuka-san, the chief engineer looked like we were from mars when the S3-S4 transition topic came up ... and the 'why' question was asked. I thought that would be the defining moment in understanding what that is all about ... to no avail.
    :confused:
  9. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    Well, my own experience is a little different. If I was driving faster than 34mph and I slowed down, my car would maintain the S3b until the ICE has to run. So, for example, if I am in the s3a, accelerate and get into the S3b and then slow down again, I can run on electricity under 34mph as long as: a) I don't stomp on the accelerator, forcing the ICE to kick in, b) the SOC doesn't drop below a certain level. Only when the ICE kicks in for whatever reason, the car engages the S3a again - that is how my Prius behaves.
    Well, as you said, this procedure does not help much, does it :)?
    Ken, you know the Prius forward and back and have a lot of insider info. Do you possibly know what are the technical reasons behind this? It is torturing my curiosity since the day I drove the Prius for the first time :).
  10. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    Oh, looks like we'll never learn the truth then... This is one of the PRINCIPAL questions that have been torturing the humans from the very beginning! "What is the Purpose of Life?" "Is there a God?" "Who *really* killed Kennedy?" "Why is the S3-S4 transition in the Prius implemented the way it is?" :D
  11. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    The idling check is done for 5-10 seconds during slowing down on the gen III, so the gen III does not required a complete stop for the S3->S4 transition.
    You're a good candidate for the following DIY hack. :)
    http://priuschat.com/forums/gen-ii-prius-modifications/36342-another-thermistor-hack.html
    In our group at the Detroit event, Otuka-san clearly explained it's idling condition learning process to calibrate sensors.
    I think your experience is same as mine, but you explained more detail.
    Ken@Japan
  12. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    Arigato gozaimasu, Ken-san :)
    I am aware of the thermistor hack, but I still have some mixed feelings about it... It's a little dirty solution. If only the Prius was sold under the GNU-GPL licence :D! Then we could all play around with the firmware freely... I want an open source car :D!
    So sensor calibration... Interesting. I'd *love* to know more details, but I guess I am asking too much :). Still, thanks a lot, Ken!
  13. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Thanks to everyone for all the good info, it's really helped. :)
    I started looking into this a few days ago because I couldn't understand why sometimes my prius wouldn't glide even though all the things like temperature and SOC should have been perfect for gliding. Then I realized that it only ever happens when I'm going fairly slow when I try to start my glide.
    For example there's one route I travel that has a section where I can get a really long glide of nearly 4 miles! (It's a long windy downhill but not very steep, just perfect for gliding all the way). Last week I got caught by a slow truck just before cresting this section and to my disgust the ICE just kept running and running and running - grrrr it was so annoying. Anyway it made me think about the times when this happens (ICE keeps running even when you'd think it shouldn't need to) and I started to think there might be something wrong (like a stuck open thermostat or something) with the car. At least I now know that it's not just me that this sometimes happens to.
  14. hill
    8,916
    Yes but I still to this day can't understand what impact it would have on emissions if S4 were simply achieved via temperature ... without stopping / restarting.
  15. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    I think no one asked question about the emission impact in our group.
    Ken@Japan
  16. reeed
    reeed Junior Member
    30
    Singapore
    I found this trick by accident ! It even seemed to work if the interval is just 1 sec.
    Another thing I noticed: S3 mode with battery SOC >60% behaves like S4, but falls back to S3 behavior once SOC falls below 60%.
