Automatic head light leveling system warning light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mmirman, Aug 6, 2007.
  1. mmirman
    mmirman New Member
    I have Prius 2005 with about 46K miles.
    I started getting the warning light come on, and on the screen I get :problem" and the symbol meaning -- according to the manual -- head light leveling system warning. It usually goes away after a while, but lately it often stays on longer and comes on more often than in the past.
    The manual says, take it to the dealer.
    I actually did not look at the manual before taking the car to the dealer, so I only told them I had had the red triangle with the "Problem" message on the screen.
    At the time I took the car to the dealer the message was not there. They did not find anything.
    Can anyone suggest anything?
  2. ceric
    ceric New Member
    1,114
    Fremont, CA
    <div class='quotetop'>QUOTE(mike.in.sudbury @ Aug 6 2007, 08:43 PM) [snapback]491631[/snapback]</div>
    I think the auto-levelling sensors on the rear suspension are going bad.
    You just have to bring it to the dealer when the warning shows up.
    Or simply tell them to check specifically the levelling sensors. :(
  3. Neicy
    Neicy Member
    834
    Wakefield, MA.
    Hi Mike.in.Sudbury,
    Welcome. Glad to see another New Englander here. Lots of good info and helpful people. Check out the local New England thread and come to the next local gathering.
  4. mmirman
    mmirman New Member
    <div class='quotetop'>QUOTE(Neicy @ Aug 6 2007, 11:20 PM) [snapback]491674[/snapback]</div>
    local gathering? interesting... how do i figure where and when it happens?
    --m
  5. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    <div class='quotetop'>QUOTE(mike.in.sudbury @ Aug 6 2007, 06:43 PM) [snapback]491631[/snapback]</div>
    Is this a newsworthy event that warrants being posted in the "Prius and Hybrid News" forum ???
    Keith :unsure:
  6. fred s
    fred s New Member
    67
    Coram, NY
    <div class='quotetop'>QUOTE(Tech_Guy @ Aug 9 2007, 12:04 AM) [snapback]492832[/snapback]</div>
    Keith,
    I think a simple
    OFF TOPIC
    would have sufficed.
    Yeah I noticed the moderators are a little slow in here at catching OT/wrong category threads.
  7. kimaug
    kimaug New Member
    Sycamore, IL
    I have been experiencing this same thing with my Prius. The headlights seem to be working fine, and I just want to know how to reset the warning light. We don't want to take it to the dealer if it is working fine!
    Another odd thing is that the tank will not fill up. Although the gastank is 11.9 gallons, I can only fill it with around 8 with the low fuel light lit. During the first year we owned the car I could fill it up but something happened and I cannot put in more than 8.5 gallons now. Anyone else experienced this?:confused:
  8. Tideland Prius
    16,623
    Well if the light is on, then your headlights are not adjusting according to load level and you should have it checked. It has nothing to do with whether your headlights work or not.
    Your 2005 Prius has a flexible rubber bladder inside the standard metal fuel tank. As such, you'll find it hard pressed to fill a full 11.9 gallon tank. (The most I've pumped is 40 litres so just about 10 gal and that's only in the summer. In the winter, it'll be down to 8-9 gal max).
    P.S. I think your 2005 has a different package (not a navigation package as listed in your profile). 2005 packages were labelled with numbers. If yours was the top of the line, then it's most likely a #6 IIRC.
    Check here to see what package you have
    http://priuschat.com/forums/knowled...andard-optional-equipment-some-countries.html
  9. TheForce
    3,461
    537
    Wheelersburg, Ohio
    A restart of the car 3-5 time might reset the code.
    I would print out this document http://priuschat.com/forums/attachm...us_headlight_height_control_sensor_repair.pdf and take it to your dealer. After reading the document they should replace it. Thats How I how mine fixed.
    The gas take is a bladder and will shrink in the winter so thats normal.
  10. momstoys
    momstoys New Member
    35
    Our 05 had the same warning. Dealer replaced the headlight sensor for 422.78 out of our prepaid service agreement (extended warranty :)) Still don't see how Toyota lacks so little skill that they can't make longer lasting sensors or protect the ones that are installed from corrosion.
  11. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    I declined to have mine replaced as it was out of warranty. its really not that big of a deal, just manually adjust the headlights with a large phillips head screw driver. I don't have excessive loads in the back of my vehicle so I don't worry too much about blinding anyone. $400+ is not worth it IMHO.
  12. kenmce
    kenmce High Voltage Member
    1,551
    524
    NY
  13. pvandrew
    pvandrew Junior Member
    Manhattan, Illinois
    Does anyone know where the Automatic head light leveling Sensor(s) are located? It is possible only the pins or socket are corroded and be cleaned with the proper tools.
  14. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Its located behind the driver rear wheel. When I opened mine, it had 3 small copper springs (like that you'd find in a push pen) that were all corroded. I tried replacing them but it didn't work because the plastic "dog bone" piece was missing from the apparatus when I bought my prius.
    The sensor looks like similar in shape to a digital stopwatch, only twice the size.
  15. kenmce
    1,551
    524
    NY
    If I have a spare "dog bone", do you want it?
  16. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Really? Well at first I was peeved about the headlights but now that I manually adjusted them, they are on point. I rarely carry a heavy load in my hatch so I don't know if I would really need it. Plus, I'm not sure if I am missing other pieces besides the dogbone or if changing the springs will work either. Do you know what other parts might be required and if changing the springs works? If its rather seamless, I would be interested in taking you up on that offer.
    Thank you for the help!
  17. kenmce
    1,551
    524
    NY
    You might want to review this thread. My experience is towards the end. I swapped mine out becaue I didn't trust the old one. It turns out that the mechanical parts were fine, just the sensor was bad. I went down in the basement just now and found it. I have the slightly "J" or "L" shaped bracket that holds the sensor, the straight arm that comes off the back of the sensor, and the "dogbone" that attaches to the straight arm. The sensor is attached to the bracket with three phillips head screws, it looks like an easy swap if you have a good sensor.
  18. edh53
    edh53 Junior Member
    ohio
    I'm having the same problem. Note that if it is not fixed the headlight levelling system eventually seems to default to the lowest position leaving one with an unsafe level of lighting on the low beams. I am going to try the fix noted in the link above. $500 is ridiculous--no more HID lights for me (am glad I did not get them on my RAV).
  19. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    It is quite easy. Just make sure you get ALL the corroded bits out of the holes the springs sit in. I thought I had, then put a little bit of fine steel wool in the holes and twisted it with a very small Phillips screwdriver to make sure the contacts were clean. A full circle of the old spring came out. I was amazed that there was 1 'like new' spring and 2 'totally corroded and gone' springs in my unit. They sit in holes only 1/16" apart - the width of the plastic that separates them. You would think that if two were totally corroded, the third would be hit pretty hard as well.
    If anyone DOES need the whole unit, get it cheaper (about $270 I think I found) by not going to the Toyota dealer ($390 uninstalled). Install it yourself, you only need to take out 2 bolts to remove the upper bracket from the car and 1 nut on the articulating piece that connects the plastic dogleg to the lower bracket on the rear axle. Shouldn't take more than a few minutes unless the bolts or nut are seized. I was concerned mine would be given I live in snow and salt country. They were somewhat rusty but I sprayed a little WD-40 on them first and they came right out.
  20. LarryC568
    LarryC568 New Member
    St. Louis, MO
    I'm a disabled vet in St. Louis with an '05 displaying this red warning light all the time. At night it's a real distraction, and the headlights seem low. I've read all the posts, but I wonder, Is there any get-around fix I can pay my local garage to do without shelling out $500 to my Toyota dealer, just to get the lights up where they should be and disable that warning triangle? I'm not very mechanical, but is there some way I can just disable the darn thing and have the garage manually adjust the lights?
    Feel free to e-mail me if you wish. Many thanks for any help.
