Diesel and Hybrid Newbie
Discussion in 'Newbie Forum' started by Viking Heavy Diesel, Nov 24, 2009.
  1. Viking Heavy Diesel
    Viking Heavy Diesel New Member
    25
    Oklahoma
    Most of you already hate me but this is my formal introduction.
    I have an 07 Honda Civic Hybrid ( I know, not a Prius) and a '99 F250.
    Just saying hey.
  2. higuys
    higuys New Member
    46
    WI
    Wow big trailer I want it
  3. Viking Heavy Diesel
    25
    Oklahoma
    Thanks, it gets the job done.
  4. dalton2
    dalton2 New Member
    maine
    :welcome:to prius chat
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,360
    67
    Yokohama, JAPAN
    It looks there is a huge imbalance among track and trailer.
    Wonder if there is a safety regulation in the US.
    Ken@Japan
  6. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    No hate, just caution...you may have noticed that you
    e one of the only ones from that site you came from who can still post here. Remaining polite and civil and you can continue to be welcome here.
    It is interesting, though, where dalton2 chose to make his first post.
  7. IdahoSparky
    IdahoSparky New Member
    Boise, Idaho
    Simple solution. Sell the Honda, buy a Prius. Remove hatchback, mount 5th wheel there. Put truck inside trailer, hook trailer to Prius. Drive. :eek:
  8. dalton2
    dalton2 New Member
    maine
    not gona lie Im from powerstroke.org im not here to stir the pot.
    just watchin
    not my first post ether you blocked my old account...
  9. Viking Heavy Diesel
    25
    Oklahoma
    I assure you that I am perfectly legal.
    No comment on dalton.
    Thanks for the understanding welcome though.
  10. efusco
    19,891
    1,192
    Nixa, MO
    hmmm, so you wanna 2nd chance...let
    s see how it goes.
  11. Viking Heavy Diesel
    25
    Oklahoma
    Dont think thats the best idea. According to Wiki the average Prius weighs about 2900lbs. The trailer empty weighs9800lbs and on this particular trip the trailer and truck together weighed in at 41000. I know I was legally over weight but dont tell anyone.
    Although I would be intrigued to see what kind of mileage a Prius could get pulling that if it could.
  12. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Just how heavy is that trailer? I'd want a one ton dually - not lifted - for extra stability
    Back when I was licensed for it, I used to tow upwards of 30,000 lbs loaded trailer, using a Ford F-600 with air brakes. It was built for it
  13. jayman
    13,439
    640
    Winnipeg Manitoba
    Quite frankly, I don't care if somebody drives a Prius, a lifted pickup, or a minivan. Most drivers on the roads these days are ignorant a-holes
    Back when I had to do a lot of driving for my consulting business, the Prius made financial sense. But it was all a write-off too.
    There is no way I'd plunk down upwards of $40,000 into a toy with no possibility of depreciation, expense writeoffs, or tax breaks
  14. Viking Heavy Diesel
    25
    Oklahoma
    Mine wasent particularly built for it but it works. I am looking to get an F450 in the future.
  15. jayman
    13,439
    640
    Winnipeg Manitoba
    Yes, the F-450 has a heavy duty rear axle with integral housing and removable third member. A much better choice for HD towing
    I saw one up north of the arctic circle, at a methane hydrate test site a couple of winters ago. It was used to tow up a research trailer for us engineers
    Somebody made the foolish error of not draining the plumbing in that research trailer before it left Calgary. Guess what happened to the plumbing once it was exposed to -50 F?
  16. dalton2
    dalton2 New Member
    maine
    I bet a prius could pull half decent not 10k lb but electric motors have great torque, almost instantly too and with the cvt no bangin gears ether
  17. jayman
    13,439
    640
    Winnipeg Manitoba
    Yes, at LRA rating, an electric motor can provide 100% torque at 0 RPM. That's why diesel rail engines, stevedore shipping container cranes, and a lot of industrial process use (Pumps, conveyors, agitators, etc) use electric motors
    AC variable speed - variable frequency - electric motors allow infinite torque/speed adjustment. However, the motor winding has to be specially designed and insulated for this duty.
    If you have come across the term "inverter duty" that means an electric motor designed for variable frequency speed control. Otherwise, the rapid changes in frequency can cause arcing in the motor winding
    Oshkosh Defense is doing very serious research into per-wheel electric motor hybrid propulsion
    Oshkosh HEMTT A3 ProPulse hybrid drive, diesel electric vehicle Keywords
    I see this sort of military vehicle as having primarily a logistical advantage: instead of needing separate generators, you can leave the HEMTT in "Ready" much like a Prius. The engine will cycle on and off to maintain constant voltage in the capacitor bank
    If you watch the video, they use the example of running the airport lighting at Oshkosh Wittman Regional by plugging into the HEMTT.
    The fact the HEMTT can still move the big loads, with less wear and tear on the motor, with no transmission or driveshafts to maintain, while using less fuel: win-win
  18. Viking Heavy Diesel
    25
    Oklahoma
    I can imagine. (Couldent find a laughing smilie.)
  19. dalton2
    dalton2 New Member
    maine
    is it posible to burn up the electric motor by over loading it in a light duty hybrid (prius,escape, civic)? or do they have fail safes?
  20. jayman
    13,439
    640
    Winnipeg Manitoba
    No, all routine operation the motors - there are actually two of them M/G 1 and M/G 2 - are protected from thermal overload.
    There are thermisters in the winding that the PCM (Actually many different computers on CANBus, but for the sake of easy discussion lets just call it the PCM) that monitor temps
    You get plenty of warning before things get too hot
    The motors are actually liquid cooled. In this cutaway
    you can see the cooling jackets. The inverter/converter is also liquid cooled. It's thought the weak point is the electric coolant pump for this loop. But again, there should be enough advance warning that the average driver would take notice
    But, just as there are folks who keep driving with an overheat or low oil pressure warning light, there will probably be Prius drivers who will keep driving with the warning triangle on
