Felt the brake cut-out thing.....
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Acre, Nov 26, 2009.
  1. Acre
    Acre New Member
    104
    Woodside, CA
    ....for the first time about two hours ago driving through Golden Gate Park on the way home from a Thanksgiving dinner. Ran over a pothole while breaking and for some fraction of a second the brakes stopped working. I have to say, it is very disconcerting. I had the same reaction as when I narrowly miss a deer that bolts in front of me, or when a cop pulls in behind me and I'm just certain he's going to light me up - and then he pulls around me. Absolutely nothing for about 15 seconds, then a sudden queasiness in my stomach and pain in my thighs. Guess I'll get used to it. Nothing to trigger it on the routes I typically drive. Glad I read an account of it here before this happened because yes, you do have the illusion of accelerating rather than merely ceasing to decelerate and knowing that it was an illusion helped.
  2. dogfriend
    7,512
    1,190
    Carmichael, CA
    It is a bit disconcerting the first time, but it actually takes less than 1/2 second before the friction brakes kick in.
  3. gmalis1
    gmalis1 New Member
    134
    Northwest 'burbs, Chicago
    I have had this occur on my previous 2005 Prius AND my current 2010 Prius.
    Personally, no other vehicle I own or have owned have ever had this response.
    And, I don't care whether it is a 1/2 second or whatever for the brakes to engage, I don't like it one bit.
    My two biggest gripes with the Prius...the brake cut out going over a pothole, and the damn rattle in the "skybridge" console which I can't get rid of.
  4. dogfriend
    7,512
    1,190
    Carmichael, CA
    But you bought another one. :madgrin:
  5. gmalis1
    gmalis1 New Member
    134
    Yah, next time I think about buying a new Prius I need to find a street riddled with potholes to I can check and see if the brakes cut out when I go over one.
    What a ridiculous statement "you bought another one".
    Toyota needs to fix this problem, as it has persisted from one generation to another. As I mentioned before, this doesn't happen in any other vehicle I have ever driven. It is specific to Prius'.
  6. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    We have streets made of bricks. It has happened to me many times on several cars. Isnt it called anti lock brakes?
  7. dogfriend
    7,512
    1,190
    Carmichael, CA
    You didn't notice the goofy smiley? :madgrin: That's what I use to indicate that I'm not being serious.
    However, the reason that it doesn't happen in any other vehicle that you have driven is because the others probably don't have regenerative braking + ABS.
  8. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    Exactly my words :). Prius is not an off-road car.
  9. Sho-Bud
    Sho-Bud Member
    190
    Amsterdam, Netherlands
    It behaves about the same as my previous car with ABS.
  10. jim256
    jim256 Member
    317
    69
    Eastern NC
    Absolutely--ABS releases pressure on the wheel that is locking so it will not skid, and then re-applies braking pressure to that wheel in pulses to maintain some degree of deceleration without lockup. If you have a locked and skidding wheel(s) you have lost some or all of your steering capability; ABS helps you maintain steering and braking by avoiding lockup. How many years has this had to be re-explained? Adding in regenerative braking hasn't changed the concept although it adds a second system that is being controlled.
  11. fjpod
    fjpod Member
    419
    72
    New York
    I felt it the other day. The road was a bit wet, and I was braking, and I happened to go over a manhole cover that was not level with the road. It felt scary,...it teaches you to control your speed when it is wet out.
  12. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Well I can ASSURE you the Honda Civic Hybrid does exactly the same thing...Maybe that's why this wasn't earth shattering for me, because I am used to it. I traded in a 2007 Honday Civic Hybrid for my 2010 Prius V and It has only happened to me over a bump or similar and am used to it. The first time reminds you, then you realize .....
    I use the analogy of slippery roads and the ABS kicking in, that's another scary momentary Stomach Wrenching experience (snow/Ice). But you learn that as well. I just don't tailgate and at least know what to expect....
  13. richard schumacher
    7,664
    1,046
    United States
    Every car with ABS (which is all of them, for some years now) does the same thing. The Prius has the added jolt of cutting power to the wheels momentarily to protect itself. That sickening feeling is nature's way of telling you that you're driving too fast for conditions. Slow down.
  14. TopJimmy5150
    TopJimmy5150 Junior Member
    55
    Gillett, PA
    I've had ABS in every car I've owned since the early 90's. I've felt the pulse and noise of ABS going off over a rippled surface. What my Prius does in similar circumstances is nothing like my prior cars with ABS. The brake just don't work for a second and the car actually seems to speed up. It is frightening.
  15. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Jimmy,
    The two most pertinent words are "seems to" -- in fact, it does not speed up at all. I know about that of which you speak vis-a-vis "disconcerting", having felt the same phenomenon myself. However, knowing it's a sensation and not an actual issue (much like the sensation of the car "moving" when the ICE engages while the vehicle is in P), just means that I need to adapt myself.
  16. sdleo726
    sdleo726 New Member
    98
    San Diego
    For what it's worth, I have experienced that feeling in my Jetta GLI and Honda S2000. When driving quickly over a pothole, sometimes the ABS thinks that is wheel slippage since there is no road underneath the tire for that 1/2 a second.
    If you were braking when driving over that pothole, the ABS disengages the brakes on the affected wheel to prevent the pseudo-skid that the car believes is occurring. (IMO)
    You can also feel this happen when driving an ABS car with summer tires, in the snow.
    I haven't experienced the brake cut-out thing in the Prius yet.
  17. bac
    bac Active Member
    863
    52
    Pennsylvania
    Ding, ding - we have a winner! ALL ABS systems work this way on EVERY auto. It has NOTHING to do with regen or the Prius. My favorite comments are ones like this:
    "The road was covered with snow and ice, but when I hit the brakes, the car didn't stop!"
    Advice: Learn just a little bit about how automobiles work before banging on the keyboard. :rolleyes:
  18. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    I do think the car companies are more than a bit at fault here-pretty much all of them--for public misunderstanding of ABS and how it works.
    ABS advertisements always make it look as though ABS helps you stop more quickly, and in a shorter distance. That's simply false. It's not even what ABS is designed to do.
    ABS is designed to keep you in control when braking in slick conditions. It does that, as others have noted here, by releasing pressure on the brakes during slipping, and then reapplying them automatically. Obviously, that cannot result in shorter braking distances than on dry roads, but it does prevent many skids.
    I felt the same weirdness about it when I tried ABS out on gravel roads in my then-new 91 Subaru Legacy. Since I had never been told that ABS doesn't stop you faster, and didn't really understand it, I was a bit disappointed and disconcerted how it worked. (It was only when I burrowed deep into the owner's manual that I found any reference to the fact that it might result in INCREASED stopping distance--or at least increased stopping distance vs. normal stopping on hard, dry pavement.
    Some years ago (but some years after ABS was introduced) insurance industry studies indicated that ABS didn't really cut down the number of accidents. At the time, I attributed it (without any evidence whatsoever, so sue me) to public misunderstanding of ABS--you still had to maintain at least the same distance between vehicles as you ever did. But that's not how it was--and is--sold.
    I don't know what such studies would show today. But given that we see this misunderstanding continuing even among folks with above average interest in cars (given that we all waste so much time on Priuschat)--I'm going to bet that the actual benefits of ABS have not really been what they could have been had advertising for them been accurate from the beginning.
  19. Phonon
    Phonon New Member
    Ottawa
    Actually, you're wrong - there are two separate issues I found with my 2010 Prius.
    First, when the brakes are wet, the Prius over-compensates. I used to own a Corolla, and when the brakes were wet they would not work well for a few seconds until the discs dried off - then they engaged normally. I knew what was happening so I wouldn't over apply - I would gently increase the pressure until they worked, and then released pressure when they engaged, achieving a relatively normal decelleration. With the Prius, on wet days I get no decelleration or complete lockup as I back out of my driveway - like a drunk school kid on his first drive. This may continue one or two stops after, and then it's alright. This is not ABS - it has to do with wet discs and the car's software.
    Second, I experienced this three times already (only 6K on my Prius at this moment) - sometimes when decelerating on bumpy roads, the breaks give AND the car suddenly revs up and accelerates! This lasts only a second or two, giving the car a jolt forward - and is very disconcerning when you're trying to slow down. Thankfully, I've only had this happen on the same local road just shortly after starting the car - I have never seen this on major roads (maybe because they're not bumpy?). I'm a little worried about driving the car in the winter (with all the ice and snow in Canada)... this needs to be solved.
  20. Acre
    Acre New Member
    104
    Woodside, CA
    Sounds like the Prius suffers somewhat more from this phenomenon the do must other cars with ABS. Maybe this is how they got it to 50mpg - if you try to drive it at mpg-killing speeds, it scares the b'jeezus out of you :D ABS adds weight (and it is now cropping up on motorcycles as well - there this behavior would scare me even more) so if the benefits are minimal to none I really wish manufactures would get rid of it. I'm sure the public perception of anti-lock = safer will make that difficult even if it adds cost and weight for no net safety benefit.
    The console rattle annoys me a bit but since, as I mentioned elsewhere, I insist on playing all my old cassettes with a Walkmen accompanied by a battery charger the rattle of tapes now masks the other rattle so it's all good :) I have now mastered the skill of reaching over to open the thing and flip a tape with one hand without ever taking my eyes off of the road - I'm SO proud!
