Don't want to make people behind me mad anymore
Discussion in 'Gen 3 Prius Main Forum' started by SD LOCAL, Nov 29, 2009.
  1. SD LOCAL
    SD LOCAL New Member
    17
    First I want to acknowledge that I know this topic has probably been talked about several times in various other threads and in different ways. But as a new Prius owner I wanted to give my take in a fresh thread.
    Have had my new Prius V for a few weeks now. First, want to say that overall, love the car. And all of my family and friends that see it for the first time think it's very cool and can't believe it's actually a Prius because it looks so good. Thanks to the model V and midnight blue color for that!
    My situation is, I'm one of these people that thought using ECO mode most of the time and accelerating slowly from stops is the best way to get the highest mileage possible.
    Whether or not that's right or wrong in terms of gas mileage, it's definitely wrong in terms of keeping people behind you happy. After a few weeks of people flashing their headlight's at me, making rude gestures at me, honking at me, and literally flying around me only to cut in front of me because they're pissed off I'm "holding them up," I'm done with the slow accelerating.
    And living and driving in a big congested city like San Diego as I do, with so many stressed out people that are always in a hurry, I now realize you simply can't do that technique.
    So like it or not, better gas mileage or not, I'm going to stay in standard mode and accelerate to speed as I did in my previous all gas car. Then I'll try and use more "coasting" techniques once I'm up to speed and keeping with the flow of traffic.
    It's been mentioned in other threads here that might actually be a more efficient way to get better gas mileage based on how the car really works. I'm hoping so because that's the way I'll be driving my Prius from now on.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    JUST DRIVE IT.
    That's been the motto for many of us for years.
    And if you watch the Eco-Meter, the point to keep the duration in the red zone short. Avoiding it entirely is not necessary. Avoiding the use of ECO mode isn't either.
  3. sdleo726
    sdleo726 New Member
    98
    San Diego
    Congrats on the new Prius. On my first tank of gas, I took the same "maximize my MPG" approach to driving. On the second tank, I'm just driving in Normal or Power mode. MPGs are down 2-3mpg, but I'm not making anybody mad, and in Power mode, I'm having a lot more fun! Now get out of my way :)
    The Prius is a car, drive it!
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Be aware that you can (theoretically) get exactly the same results in any of the 3 modes, normal, power, or ECO. What changes is the response of the car to movement of the pedal in about the first half of it's travel. ECO gives you very fine control, PWR quite course, and normal in between. If you push the pedal clear to the floor, for example, in any of the 3 modes you get exactly the same amount of power.
    Which you use most of the time is a matter of personal choice and probably depends on where you live, traffic conditions, etc. I have found I can use ECO with no problems while driving in the city (Portland or Seattle) but I have to push the pedal down a bit further and will put the HSI line over in the red to keep out of peoples way. Others on this forum have switched to normal or even PWR and claim no big difference in mileage. I have noticed when I get out of ECO my mileage suffers a bit.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Like John said, "just drive it". Because my mileage has dropped so much due to winter driving, I just "turn off" my HSI and just drive. It helps reduce stress. Keep up with traffic out of the lights but try to anticipate the stops and coast to them. People seem less sensitive about coast stopping.
    Remember if you do happen to drop a few mpg doing this, your still getting much better than everyone else around.
    Drive on!
  6. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    In the real world you are always going to be going to slow for someone. If you are going so slow that everyone behind you needs to pass you then you might want to go a little faster. Try to find a balance in between that and pleasing everyone which is impossible.
    2 people like this.
  7. fjpod
    fjpod Member
    419
    72
    New York
    The eco meter does have a mesmerizing effect and can keep you from driving properly to keep up with traffic. I keep it in eco and when I need to accelerate faster, I just push the pedal harder to keep people from getting mad at me.
    has anyone else noticed?...that when you are over about 50 mph, that it no longer feels like the pedal is in eco mode?? (which makes sense).
  8. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    you're thinking and worrying about this too much..... and when you do, you make it double!
    drive the car. when you use the ECO mode too much, the ICE kicks in and charges the batt. so beware of this. so-cal people are hotheads....most of them drive like idiots. all of them seem to be in a constant rush. add a bit of rain and it's a cluster F!!! out there.
    be patient, and every once in a while, drive it like you stole it.....helps clear out the carbon deposits..........
  9. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    A few weeks ago my wife and I rode with one of this Forum's Moderators, who is a recognized Hypermiler, and he showed us some tips on extracting good mileage from a Prius.
    My wife also drove in ECO mode, untile we saw how briskly he accelerated away from a stop. His lesson to us was to accelerate away from a stop BRISKLY, quickly reach your target speed, then coast as much, as far and as often as possible.
    As was stated earlier, reach your target speed quickly, then keep it in the ECO area on the HSI as much as practicle, avoiding the Power area.
    There have also been MANY threads on driving in the PWR mode versus the ECO mode, my wife and I are ardent supporters of using the PWR mode. It compliments quick starts from a stop, permitting one to reach the point where coasting can be done more efficiently and for longer periods of time, nullifying any losses incurred by the quick starts. PLUS it's a WHOLE LOT MORE FUN!!!
    Enjoy your Prius!
    David (aka Blind Guy)
    P.S. You have EXCELLENT taste in a car's Make, Model and Color...it's the same as ours!
    3 people like this.
  10. jazzyj
    jazzyj Junior Member
    Kentucky
    I guess Im with others in sayin to just drive it, but not because of those behind you.
    Driving's purpose is to get from one point to another safely - not to please others behind you who have stretched their days so thin that they must make others miserable in order to get where they are going by a certain time.
    Since buying my Prius, i accelerate much slower than before. It's not just a matter of saving money but also safety. There is no need to jump out of your skin when the light turns green. If the other fools act stupid and cause an accident by doing so I'll gladly allow their car insurance to buy me another Prius :)
  11. Jim Calvert
    Jim Calvert New Member
    255
    28
    Worthington, Ohio
    Hi:
    Aggressive driving seems to be on the increase. If one of these ignorant jerks flash their lights at you, or honk their horn, just ignore them - but be careful - don't react. The last thing you should do is allow these incidents to escalate into a violent and deadly road rage event.
    I have the same thing happen to me every day, no matter what vehicle I am driving - and no matter what my speed. I just try to let them pass, or if they really get wild I look for an exit to get away from them.
    Deadly road rage events are in the newspapers all the time. Don't allow yourself to become a statistic.
    Jim
  12. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    It's much more enjoyable driving in pwr mode. Good mpg and fun at the same time. What more can i ask for. Oh, maybe firmer suspension for the turns. :)
  13. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    My advice is always to drive safely. Driving a lot more slowly than other folks is just as dangerous as driving a lot more quickly. When I'm in traffic, I try to be attentive to the way other drivers are behaving.
    However, I see nothing wrong with driving +/- 5mph of the speed limit, which I do, even if other drivers disagree. Other people's rudeness is not my problem so long as I'm driving the way the road is intended to be driven.
    On the other hand, when I have a large stretch of road to myself, I do sometimes accelerate slowly so as to avoid the "red zone" at all. If that means creeping uphill, that's ok with me so long as I am not endangering anyone else.
  14. tumbleweed
    4,067
    692
    Eastern Oregon
  15. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    I just came through the mountains around SD after seeing my daughter in Tucson. I could not believe how foolishly people were driving. Snow on the side of the road, rain, wind and temps just above freezing and I had people weaving in and out of lanes cause they needed to get ahead of everyone else on the road. I prefer arriving late over not at all, many of these people had families in their cars, I cannot understand why they would risk the lives of loved ones driving like that.
  16. Bruno_S
    Bruno_S New Member
    130
    68
    I also live in San Diego and had the Prius since June '09. I drive in ECO mode and my MPG is 50.7 after 4950 miles.
    I have learned to live with the constant harassment from other drivers. On surface streets there is not much problem but on the I-5 freeway I sense the anger when I drive 60-62 mpg even though I am always on the right lane. I am not going to drive faster because other people want to speed.
    You would think that with the CA foreclosure crisis and the very high unemployment rate, people would be driving slower to conserve gas and money.
  17. SD LOCAL
    SD LOCAL New Member
    17
    Thank you for the comments and suggestions so far. I appreciate it!
    I really like the advice of "just drive the car!" and "accelerate away from a stop BRISKLY, quickly reach your target speed, then coast as much, as far and as often as possible."
    That's exactly what I plan on doing from now on. :)
  18. IraS
    IraS Member
    165
    Austin, TX
    No matter what you do, there will always be some idiot behind you that is impatient and will flash his lights, sound his horn, or pass you.
    I have been driving in ECO mode since I got the car. After stopping at a red light, I am often way ahead of the people in the other lanes after starting up when the light turns green. I usually accelerate to around 30 MPH then let the cruise control get me back up to speed. (I have a Prius V and love to use the Dynamic Radar Cruise Control.)
    I normally set the cruise control to 3-5 MPH over the speed limit and let the cruise control keep up with the car in front of me. When I am following a car who is doing below my set speed, the cruise control keeps me about 2 seconds behind him. Invariably, someone has to pass me and fill in the gap. It has nothing to do with my acceleration rate or speed - they just can't stand me leaving a safety zone (as recommended by every defensive driving class I have taken). I even had one guy drive around me on the shoulder to pass when the rush hour traffic was going too slowly for him.
    Just drive the car as you would a normal gas engine car. Accelerate and keep the speed and distance you would if you weren't driving a Prius. As long as you aren't impeding traffic, ignore the idiots behind you who are so impatient they will risk their lives (and yours) to gain 5 minutes during an hour drive.
  19. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    211
    San Diego, California
    On the other hand it is very annoying to be stopped at a light and a big SUV or truck stops about 3 inches from my rear bumper. :censored:
  20. ibmindless
    ibmindless Member
    206
    I drive nice and economically, but not to the point where I impede traffic. That wastes gas, too. It is still appropriate to drive with manners and good sense. If cars are flying past you on both sides (excluding the shoulder), move over to the right - the slower lanes.
    Just yesterday I was driving at the speed limit on a 2-laned commuter or HOV section of the freeway in LA. Another Prius was ahead in the slow lane and an airport shuttle bus was in the "fast" lane. The bus bumper was 3 feet ahead of the Prius bumper as they plowed through the air like an askew marching band. They remained paired like that for a couple of minutes - both doing about 5MPH below the speed limit. Naturally, I couldn't get around them.
    I think it is rude to pair two vehicles alongside each other and block anyone else from passing. I flashed my lights (once) at the bus, but he didn't care. When I changed lanes to get behind the Prius, the driver had the courtesy to slightly accelerate so I could pass the bus on the right. THANKS to the Prius driver.
    Either the bus driver was oblivious, didn't care, or was passive-aggressively enforcing his own agenda. Neither of which is appropriate for public road travel.
