Will Hog Ring Pliers like these work fine on the Prius seat?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cycledrum, Nov 29, 2009.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Just wondering if hog ring pliers like these will work fine on the Prius seat. Is it necessary to have both the straight and the angled pliers?
    http://www.tooltopia.com/kd-tools-3...&utm_term=KDT3702&utm_campaign=googlebase_18u
    I bought a $50 electric carving knife and it cuts through foam really well. I'm going to do some shaving of the seat bottom foam myself, after I get the seat bottom cover off.
    I don't know of any kitchen knife that will cut through foam, but the action of dual blades with the electric knife goes right through foam.
  2. dogfriend
    7,512
    1,189
    Carmichael, CA
    I just used plastic wire ties to put the bottom back together. IIRC, you should be ok with just the straight pair of hogring pliers - you have pretty easy access. You may want to buy some hogrings - I found that it was easier to cut them off than to try to bend them to get them off.
  3. snijd
    snijd DIY or die
    243
    52
    PNW
    That's the set I have, and they've worked fine. I could have gotten along with either pair, but it was nice to have the choice of using the offset pair when that was more convenient. I'm not sure all hog rings are created equal, though. I've read of some folks encountering difficulties when using rings not intended for upholstery.
  4. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Those are the ones I used to install my leather upholstery. I felt I could have done fine with just the straight ones, but having both was handy in a couple of places. Use hog rings from an upholstery shop, not from a farm supply. Others had good luck with tie wraps, but I suggest the hog rings. Use a heavy duty wire cutter to cut the existing hog rings.
