Steering issues with Prius - killed deal for me.
Discussion in 'Gen 3 Prius Main Forum' started by ddtaylor99, Nov 30, 2009.
  1. ddtaylor99
    ddtaylor99 dd taylor
    25
    cincinnati, oh
    Anybody else have issues with the steering on the new Prius? I rented a 2010 Prius for 4 days and I could never get over just hating it. I think it is very bad design. The wheel position and shape are all wrong. It does not come out far enough or come down low enough and it is not shaped correctly to get a comfortable grip on it.
    I also thought the car has way too rough a ride in general. Toyota should have sprung it much more softly. The steering wheel also vibrates more than it should. :(
    (Other than that I just loved everything about the car and was ready to buy one.)
  2. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Sounds like the one you rented had a wheel that needed to be rebalanced or possibly an alignment issue. Mine is rock solid no vibration at all and I can even let go of the wheel on the highway and it tracks straight again without any vibration.
    I think you should try another one especially not a rental that may have been abused or driven over a curbe by some one who did not know how to drive.
  3. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Unfortunately rental cars are often beat up pretty hard. It sounds like the steering was screwed up and not typical for the car.
  4. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    No problem with mine either, although i don't like the feeling of the power steering assist. Somehow I still can't get used to it yet especially at hwy speed.
  5. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Mine feels great. I really like the steering wheel shape and texture. At first I thought the oval shape to the wheel would be odd, but I actually think it relieves some driving fatigue when using it. The steering itself feels as good as any car I've ever owned, and much more responsive than some.
  6. Acre
    Acre New Member
    104
    Woodside, CA
    No problems with mine in that department. You do know that the steering is adjustable if you don't like the position of the wheel? Maybe the driver before you had it adjusted to an unusual position.
  7. LeeB
    LeeB Junior Member
    99
    Henrico, VA
    The first time I drove a 2010 Prius, I really disliked the steering wheel position. I wanted the wheel come down lower and to telescope further out. The second time, I made sure the wheel was down and telescoped out as far as possible, then I adjusted the seat so I was comfortable relative to the wheel. It feels fine now (although I still wouldn't mind if the wheel were just a tad lower). I don't have any problem with the shape of the wheel and don't feel any vibration.
  8. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    mine is fine also
    try raising or lowering the seat
  9. eldiee
    eldiee Member
    118
    17
    Iowa on Mississippi River Bluffs
    We have had no problems like you are describing in your thread. Ours is so much better than our Gen II that there is no comparison in how it drives and handles on the highway.
  10. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
    Hey guys, the Prius (like any other car) can't satisfy everybody's unique desires. Clearly ddtaylor99 objectives aren't met by the 2010 Prius. Good thing he rented a Prius for a couple of days. Probably the best thing for ddtaylor99 is to try a lot of other cars before he buys one.
    Good Luck,
    Keith
  11. cbo111
    cbo111 Junior Member
    Calif
    Mine rides just fine, but I agree the steering wheel is hard and doesn't fit my hands. But after 10000 miles, I've averaged 51.5 mpg (my calculations). So I can live with the steering wheel.
    cbo
  12. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    You probably want a Camry/Buick if you want a softer ride, the Prius is pretty much a noodle compare to other sport sedans. How much softer do you want?
  13. fuzzy1
    10,404
    Did you check tire pressure?
  14. djasonw
    djasonw Active Member
    961
    123
    Coconut Creek, FL
    You should test drive one at a dealership. I bet the rental unit was beaten to death and had overfilled tires.
  15. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    My "Test Drive" on the other hand was all I needed to do, to make a decision to buy the 2010. It handled very well, rode well, and the comfort is far surpassed from my previous 2007 Honda Civic Hybrid.
    Was NOT a deal breaker for me, just the opposite.
    Steering wheel adjustments are perfect and move where I need it, and the seat adjuster makes it even sweeter. :)
  16. eyePod
    eyePod Classic Silver
    39
    Santa Barbara, CA
    The steering wheel on the IV is adjustable - did you try adjusting it's position?
  17. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Wish the steer wheel did come out forward
    Also wish the wheel was leather warped because my hands are so delicate :D
  18. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    Mine is great for me. It looks like it is not the car for you.
  19. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    First time I've heard of any steering issues. The gen III I tested was rock solid, no vibrations in the wheel whatsoever. Same with my gen II. I liked the steering and the ride, but that's just my personal opinion :).
    BTW, Japanese cars generally have harder suspension than others, as far as I know. Appearantly, they are used to better roads over in the Japan :).
  20. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Now go to a dealership and drive a new one with balanced tires. :rolleyes:
