What is function of sensor on dashboard
Discussion in 'Gen 3 Prius Technical Discussion' started by hvanwersch, Nov 27, 2009.
  1. hvanwersch
    hvanwersch Junior Member
    Can anyone tell me what the purpose is of the sensor behind the windshield on the right-hand side of the dashboard of my 2010 Prius V?
    This Prius model does not have daytime running lights nor an automatic setting for operating the headlights. Therefore I am at a loss to explain the sensor.
  2. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    I was told it has to do with the SR venting...
  3. lunabelgium
    lunabelgium Member
    269
    Belgium (Liège)
    For the air-conditioning !
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It's for the climate control system.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    Tells the climate control ECU when the sun is on the window and the ECU increases the cooling.
  6. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I think if it detects the sun coming in through the windshield it will pump more air out the top vents vs the bottom.
  7. Judgeless
    Judgeless Senior Member
    1,821
    255
    Cleveland, OH
    It’s a photo diode. It detects light and will give feed back to adjust the temperature of the car
    For Prius cars that have auto head lights it is also used to turn the lights on and off. In the US it is not an option. There is a thread that shows how to modify the car so enables auto head lights.
  8. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    It is also used to regulate the light intensity of the dashboard. If you turn the headlights on during the day, the dashboard does not dim at all. You run into a tunnel, it does dim. At least on the versions sold in Europe.
  9. AussieDave
    AussieDave New Member
    Melbourne Australia
    I believe it is a combination of all the above depending on what equipemnt you have.
    I have an Oz Itech which means it
    feeds into the climate control system
    feeds into the panel lights to dim the lights, HUD and the sat nav screen
    controls the auto headlights
    in my car if I go under a bridge and thus into shadow the panel lights, HUD and sat nav dim down as it must be night time. There is a setting somewhere to set the sensitivity of this but I have yet to find it.
    David
  10. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    The light sensitivity is an dealer customisation option or you need Toyota Techstream SW and the interface.
  11. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    What are the choices on the dealer customization?
  12. AussieDave
    Melbourne Australia
    I had that one on my list for the dealer to do but they said they could not find all on my list as it was from the US model. It is in the Oz manual however.
    David
  13. hvanwersch
    _________________________________
    Can you tell me where I find the thread you refer to?
    Thanks a lot,
  14. hvanwersch
    ____________________________________________
    On the US models this is not the case. There is a separate button on the panel left of the steering wheel which regulates the intensity of the dashboard lighting.
  15. dwhutch
    dwhutch New Member
    Los Angeles
  16. jayvee
    jayvee Member
    341
    89
    WA
    http://priuschat.com/forums/gen-iii.../64812-automatic-headlights-9.html#post953788
    Start at Post #87 - this is where the auto headlights using factory wiring really starts. Posts prior to #87 include using an aftermarket method - but I was able to add them pretty inexpensively. My method is described in post #87.
  17. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Has anyone in the states had this customizable feature for the dash brightness sensitivity set by their dealer? What are the pros and cons of doing this?
    I am going to my dealer tomorrow for my first 5K service and was thinking about having them set mine to use this sensor sensitivity feature. From what I have read from the Europeans, this seems to be a nice feature.
  18. jayvee
    jayvee Member
    341
    89
    WA
    The default settings seem to be pretty good, but I think I would like to perhaps have the display and nav go to "night" mode a little later (when it gets a little darker outside) and return to full brightness a little earlier - these are the first two settings on page 591 in the owners manual. I believe the the first would be -1 (less sensitive) and the second +1 (more sensitive).
    I tend to like bright displays, though. Others may not.
  19. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    Can you direct me to this thread? Thanks.
  20. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    Same in Canada.
