Beloved Prius vs a 4WD
Discussion in 'Newbie Forum' started by dimiH, Dec 10, 2009.
  1. DaveFDEMS
    DaveFDEMS New Member
    97
    WI
    Not trying to be a dick or anything here but being from California you wouldnt understand. You dont see much bad weather. Even with snow tires on a prius with the average snowfall here you would not get anywhere.
  2. aapoppa
    aapoppa formerly known as "Popoff"
    142
    NC Mountains
    I know there's others out there who share my awful experience with TC on slick surfaces but most just don't participate in these interchanges since they know the usual reaction, which we are once again seeing here. I've been stuck, absolutely powerless, just on a slightly inclined gravel driveway.
    As I said in my previous post, my preliminary experience on an icy hill is that the Gen III TC is much improved.
    I've said my piece and am backing out of this thread. :rockon:
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Right. Because the Sierra Nevada range never gets snowfall. Learn your geography man.
    Nothing I stated is incorrect. The Prius with proper tires works fine for those who do not experience off-road conditions. Those who live in areas that dump huge amounts of snow for long periods should consider a different car/truck that fits their needs. It's quite simple.
  4. qbee42
    3,081
    We get just a tad more snow than you, and we find we do quite well with our Prius. I seem to recall one PC member who drives a Prius for mail delivery over on your side of the lake.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    I've been there and done that. I own an '05 and run high performance 17" tires which hate thick gravel and ice. The point is, if you drive in these conditions regularly then you should look into another car like I stated in my post.
    I've also done the same thing in my old Mustang GT and ended up in a ditch and had to have my 2 friends push the front side of my car so I could complete a 3-point turn without the car sliding in the wrong direction. It's not just a Prius thing. It's a passenger car with the wrong tires or horrible conditions thing.
  6. qbee42
    3,081
    I've been there. It was a bit more than slightly inclined, but stuck I was. A Gen II Prius combined with gravel and OEM tires is not a happy mix.
  7. DaveFDEMS
    97
    WI
    Yeah you know alot about snowfall being from Sacramento:D
    Taken from Wiki
    Snowfall is exceptionally rare in Sacramento (at an elevation of only 25 feet (7.6 m) above sea level). The all-time record snowfall was 3.5 inches (9 cm) and occurred on January 4, 1888. Dustings occur every 5–10 years, with up to an inch accumulation in outlying areas. During especially cold winter and spring storms, intense showers do occasionally produce a significant amount of hail, which can create hazardous driving conditions. Significant snow accumulations occur each year in the foothills located 40 miles (65 km) east of the city.
  8. Jim Calvert
    Jim Calvert New Member
    255
    28
    Worthington, Ohio
    Just buy a used 4wd for your ski trips. Look for one in mechanically good condition that is about 10 years old. They are inexpensive - and your Prius will be reserved for regular driving.
    Jim
  9. qbee42
    3,081
    My wife used to drive a 1969 Camaro. It was fun to drive, but that beast was a horror in the winter. No weight in back, rear wheel drive, wide tires, and *way* too much torque. It was like driving a hover craft.
    With a cold start, the fast idle setting on the carb would make the car go 40 mph without touching the gas. If you touched the brakes to slow down, the front wheels would lock and you would lose all steering. The only option was to shift back and forth into N and D. I don't miss it for winter driving.
  10. vahrn
    vahrn New Member
    66
    Parma, Italy
    Since I had to trade in a Porsche I ordered both a Prius and a Rav4 diesel. The Rav4 diesel is supposed to be a clean diesel (159 grams of C02 per km). My advice is to keep your Prius and buy a used and inexpensive 4WD car (even a Fiat Panda 4x4 if you get them in the US, or a Suzuki Swift 4x4). These small cars beat several preminum SUVs in terms of snow traction (even uphill) because of the narrow tires and low weight and can achieve great mileage.
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    Yup and I never have to travel into the foothills and Sierra Nevada for work where our nature preserves are located. I just stay at home Sacramento (technically Rocklin at the base of the foothills) every day of my life. You're acting like a %$^&^*idiot. Tell me where what I posted is wrong instead of trying to attack my knowledge of harsh conditions without knowing anything about me besides a location description.
  12. dimiH
    dimiH New Member
    New York, NY
    Highlander is too big for me. Plus, I do think that hybrid SUV technology will evolve is coming years. Right now, I think I can get better fuel economy with a 2010 Outback than with Highlander. Ideally, I'd like either a hybrid Rav 4 or a hybrid Outback (or a Prius SUV!).
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Three thumbs up, Justin !
    Well placed cursing does have it's merits :)
    The guy isn't listening to you, he is hearing his stereotype. Tell him how TC is awesome on the beach, and he'll believe you.
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    *In general*, are RWD or FWD vehicles better in the snow ?
    I ask because obviously snow country has been auto country for a lot longer than AWD SUVs have been around.
  15. dimiH
    dimiH New Member
    New York, NY
    So, thanks for the opinions! Several points on this:
    1. I can't have two cars, as I live in NYC and park on the street. Parking with a second car will become a part-time job. Adding a small AWD to the Prius would be ideas, but...
    2. I looked at a later generation Prius as well. One thing that it has going for it is that is have more combined power. That, coupled with snow tires, is a definite advantage over the 2005 Prius. In terms of buying it -- after the trade-in, I will still need to spend more then 10K. That may be ok, but I think I'll be sorry when Toyota or Subaru come out with a small hybrid SUV that matches my needs better than Highlander. This, I think, will happen in 1-3 years.
    3. I looked at FEH seriously. While I am ok with it, in general, I am a uneasy about long-term reliability. Anyone has opinions on this? Also, I don't know what its trade-in value will be in 3-5 years, when there are more economic hybrid SUVs on the market. Finaly, after the trade-in, I am still looking at spedning something like $25K here.
    4. Life in NYC does not warrant a true off-roader, unless, of course, you spend every weekend driving up mud roads upstate. We do get serious dumps here several times per winter, and they proceed to freeze immediately overnight. I have, so far, successfully gotten my Prius out of sevevaral freeze-ins after doing some serious shoveing. Obviously, I'd only done it several days after the dump.
    5. I am leaning towards buying snow tires and seeing how far this takes me.
  16. richard schumacher
    7,682
    1,064
    United States
    FWD. The weight balance favors FWD for traction, and they're less likely to oversteer (fishtail, spin out, etc.).
  17. F8L
    19,011
    4,083
    Grass Valley, CA.
    The fact you can't/don't want to have two cars make the choice easy. If you truly feel you need more off-road ability than the Prius can provide then look into a Subaru. Most of my friends that live in the foothills or higher in elevation (2,000-7,000ft.) drive Outbacks and they love them. You don't sound like you need a fullsize 4wd truck so the Outback may be your best best. My friends are avid outdoors people like you seem to be so whether for work (biologists, botanists, geologists, ski resort workers, etc.) or play they keep buying Outbacks.
  18. fuzzy1
    10,658
    You obviously have not tried to get to Sacramento from nearby Reno or Lake Tahoe, at one of those times when Tahoe's weekly snow is measured in yards, not inches. When the orange chain-checkpoint man standing in the middle of I-80 going up Donner Summit is turning back 90% of the already sparse traffic. When Hiway 50 from South Lake Tahoe is simply closed.
  19. qbee42
    3,081
    There is another snow issue unique to metropolitan areas. In a big city, regardless of what sort of tank you drive, you aren't going anywhere after a big snowfall. You may be able to drive through the snow, but you can't get around all of the other stuck cars.
    I found this out the hard way when I moved to the city after years in Northern Michigan. I was driving an old Jeep C-J5. A Subaru was a mere toy when compared to that beast. Regardless, it didn't matter. The first joker with bald tires snarled up traffic and no one went anywhere.
    As a city dweller, take a long hard look at your transportation needs. If you don't drive much, fuel mileage is not much of an issue. On the other hand, don't base your decision on 1% of your needs (or perceived needs), which is a mistake made by many. Very few SUVs are ever used off road, and even fewer are really needed. Ultimately only you can make this decision.
  20. dimiH
    dimiH New Member
    New York, NY
    You are correct about the 1% use pattern. That's why I am not yet rushing out to buy a new car. However, with NYC and big snowfall in the mountains it's a bit different -- it may be dry or rain in NYC, and seriously snowy in the mountains upstate. Of course, when NYC gets a real blizzard, there is no talk of getting out for several days -- many cars parked on the street are buried under the crust.
