Anyone having cold weather milage hits?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FishHawk, Dec 11, 2009.
  1. FishHawk
    FishHawk New Member
    176
    My milage in the cold weather has take a big hit but this happens every year . Anyone having the same experience. FishHawk
  2. richard schumacher
    7,683
    1,066
    United States
    Yes; everyone who drives in cold weather.
  3. qbee42
    3,081
    Is anyone not? That's a better question.
  4. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I'll whip out my chart again. Notice the similar trend between average temperature and tank mileage.
    3 people like this.
  5. qbee42
    3,081
    Said in Tony's best Blazing Saddles voice: "Let me whip this out."
  6. Jim Porta
    Jim Porta Junior Member
    86
    17
    Louisville, KY
    Thanks for the chart. I have noticed a big hit in mileage since the temperature dropped into the low 30's (from 50mpg to 40) and the traction battery in the green more often. I assume the hit is the ICE running more to stay hot and charging the traction battery while it's at it.
  7. qbee42
    3,081
    That's it exactly.
  8. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Block the lower grill, man.
  9. ksstathead
    1,244
    245
    Kansas
    Well, for Gen2 2004-2009 block the upper grill, I suppose.
  10. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Yep, but the grill blocking method works.
  11. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Grill blocking, engine block heater, and only planning on longer trips during cold weather (consolidate all your errands into one mega-trip, instead of several short trips) will help.
    Our MPGs are abysmal this time of year.
  12. raholco
    raholco Ailurophile
    51
    I went from 42 down to 33.
    This is my first winter with a Gen II 2009 in Minneapolis/St. Paul.
    After I get my haircut, I'm off to get some pipe foam to block the lower grill.
  13. F8L
    19,011
    4,083
    Grass Valley, CA.
    Did you already block the upper grille?
  14. raholco
    raholco Ailurophile
    51
    Haven't blocked anything yet-I'll start with the upper as most of my commute is highway.
    Mind you that this is my first season with this car, having come from a Ford Five Hundred AWD that just tore into snow like butter.
    I'm thinking about ditching the stock Turanza's and getting Nokian WRG2s, rather than having to buy two sets of tires and doing the season swapping.
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    Ok good deal. I was checking because the GenII and GenII blocking procedures are a bit different due to the location of the inverter cooler. :)
  16. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    It's not only the cold weather that does it, but the winter blend gas (higher Ethanol content) has less energy content and reduces gas milage on a Prius as well. In the winter I notice a significant change as I travel from NY to other states.
  17. N3FOL
    N3FOL Member
    891
    Stewartstown, PA.
    Here we go again. Winter is back. My mpg is down 2 to 3 mpgs as expected.
  18. mike lipke
    mike lipke New Member
    89
    MN
    Fuel blend is the same year around in MN. My Prius gets the same as the other MN poster, 32-35 in the winter, 42-50 in the summer. Oh, winter figures are with the grill blocked. Actually, I don't block the grill for mileage, I block it so my wife can get the cabin warm and toasty. She can do warmish w/o the grill block, but toasty requires the block.
  19. tedroberts
    tedroberts Junior Member
    Edina, Minnesota
    Block the upper and lower grills on a 2004 - 2009 Prius.
  20. tedroberts
    Edina, Minnesota
    I block the upper and lower grill on my 2005 Prius in Minnesota.
