UOA on OE Toyota oil- 998 miles.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jm1515, Aug 28, 2009.
  1. jm1515
    jm1515 New Member
    51
    24
    Columbus OH
    Changed my oil @ 998mi just because....:rolleyes:
    Here's what BlackstoneLabs reports....
      File size:
      94.5 KB
      1,492
  2. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Silicon was high, silicon is dirt of course. I doubt it's from an ineffective air filter or dirt intrusion from another source. Most likely something is sand cast and there was sand left on the casting. I would say you did not waste your money changing oil so early, others may differ
  3. tochatihu
    tochatihu Senior Member
    9,797
    3,772
    Kunming Yunnan China
    2001 Prius
    Very nice. I was just hoping that someone would do this. Previous early first oil changes in Prius have not shown nearly that much Si, so please make sure that your engine air filter is doing its job well. Consider another UOA, with the obvious hope that the Si will plummet. Then we can treat it as 'built' into the engine.
    edit: PriusTeam, please pass this one along to your friends in Japan :) I doubt it's what they expect to see either.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Thanks for posting that, my car is at about 1400 miles and I'm going to change oil and filter tomorrow.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Agreed.
  6. dogfriend
    7,512
    1,190
    Carmichael, CA
    I think its probably more likely that sealants and sand cast residue are the source of the Si (as noted in the report). I found a similar high Si when I changed and had a UOA done on the ATF in the transaxle @ ~10k miles. I drove another 10k with the replacement ATF and did another UOA and the Si level dropped to less than half of the previous level.
  7. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Finally the answer I was looking for in my other post. Consensus in changing the oil before 5K miles. Someone has pointed out what we are really seeing in the UOA.
    EDIT, Posted UOA over at BITOG
    Looks like this original fill is a break-in oil.
    The high silicon could be a purposeful wear in agent.
  8. a64pilot
    771
    62
    Albany Ga.
    The high Molybedum (sp)? yes certainly maybe a break -in additive, Silicon, no way. Silicon = bad
    On edit, Moly was maybe an assembly lube, probably camshaft. Any body replaced a cam before? remember the black grease you were supposed to smear on the lobes?
  9. jm1515
    jm1515 New Member
    51
    24
    Columbus OH
    A big +1 on this.......:rockon:
    I like to do an early change...just to get the 'whatever' out of my engine.
    We'll see how M1 0w/20 stax up in the additives vs the OE after 5k miles...........
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    As far as Mobil 1 0W-20, I had excellent results in my 2004 Prius, using the dealership oil filter and 10,000 mile intervals. With my FJ Cruiser, the 0W-20 performed poorly (Low TBN, high nitration, high oxidation, it thickened to a 30, etc) after only 4,000 miles
  11. a64pilot
    771
    62
    Albany Ga.
    Your molybdenum being ten time average could explain the color. Molybdenum is of course a lubricant that would have been added, it is not normally something you would find from wear.
  12. bottomfeeder
    bottomfeeder New Member
    Chicagoland
    True.
    Without an analysis of new unused factory fill oil, most (all?) of the rest is pure speculation.
  13. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    Here is my first UOA from Blackstone @5100mil
    Very similar numbers more metallic thing indicates a little more wear.
    Most surprising is the OIL Type. I wrote that I do not know the oil type and Blackstone indicates 5W20 ... factory fills that but requires 0w20 in the manual and on the cap??!!! Pretty suprising!!!
    And of course I had big "misunderstanding" at the first oil change... invoice again shows 5w20 and when I "protested" they said that is just a misprint and they of course used the 0w20 (at the cheaper price yeh right!!!)
    Here it is.
  14. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    Don't worry, Blackstone does not know that it was a 5W-20 or a 0W-20 oil, they are guessing. What they do know is that the oil matches the 100C viscosity for a 20 weight oil. They are also mistaken about the engine size, showing that you lost 0.3 liters of displacement (the 2010 engines are 1.8L, not 1.5L).
    In order to tell a 0W oil from a 5W oil, one has to bring the oil down to -30C, -35C and -40C and measure the cold cranking viscosity as measured by the test ASTM D 5293 and measure the cold pumping viscosity as measured by the test ASTM D 4684. Here are the differences:
    0W Cold Cranking: 6,200cP @ -35C Cold Pumping: 60,000cP @ -40C
    5W Cold Cranking: 6,600cP @ -30C Cold Pumpling: 60,000cP @ -35C
    There is no way Blackstone did these tests on your oil without you paying them to do so, assuming that they have the proper test setups and cold box to do them in.
  15. szgabor
    994
    175
    Oceanside NY
    Thanks for the information on the cold cranking ... looks like the 20 part is the real important anyway... where I live -10C is a rarity anything colder than that happens once in every 10 years .... (my car is in a garage all the time although not a heated one).
    As far as the engine thing goes. I think I did not write it on the slip and they just guessed it (perhaps few 2010 Prius owner sent in samples...) I make sure next time I correct it ...
    I surmise that it makes no difference in their analysis whether the engine 1.5 or 1.8 L :)
  16. szgabor
    994
    175
    Oceanside NY
    Here is my UOA @40k
    The only worries is that now Blackstone indicated 5W30 ... dam I hope Toyota puts the right kind in the car (but I had no real mpg hit as a matter of fact it was better the earlier period)
  17. Former Member 68813
    3,524
    983
    US
    LOL.
    One page of answers on Si and ALL of them wrong.
    High Si levels in break-in oils is from silicone sealants:
    Silicon Doesn't Always Mean Dirt
    If this was indeed dirt (silica) it would be combined with high wear elements (Fe, Al, Cr, Pb).
