Gen1, 180,000miles: fix or new??
Discussion in 'Newbie Forum' started by fitjulie, Dec 14, 2009.
  1. fitjulie
    fitjulie New Member
    New York
    2002 Prius
    My beloved '02, with 180,000 miles has a cat. conv. problem. Estimate to replace it is around $1600 (ouch!). Trying to figure out if it's worth replacing, or just trade in for newer one. Trade in is not much because of high miles. It's a lot to spend on any car with 180,000 miles. Are there a lot of gen. 1s out there that are well into the 200s? Any problems w/ batteries? (I would hate to spend the money on the repair & then have something else major go wrong) Any thoughts or advice welcome!
  2. mike lipke
    mike lipke New Member
    89
    MN
    Two words:
    Used. USED!
  3. a_gray_prius
    2,927
    783
    IL
    Pull the cat from a scrapped one!
  4. dogfriend
    7,512
    1,189
    Carmichael, CA
  5. Rhino
    Rhino New Member
    460
    U.S.A.
    Only you can answer this question. I note you drive a lot. Is it on long stretches of highway far from help?
    It is cheaper in the long run to keep fixing it but be prepared for a string of fixes as the car gets older and older. Have you changed the transaxel oil? The water pump? These things will come up.
    Cost is not the only consideration. Later models are safer. If you are in an accident, I would prefer to be in the latest model. Getting stranded in the middle of nowhere is not fun either. Missing a day off of work because your car is not reliable is not cheap.
    Like others have said, get a good used Prius if you want to save money.
    From a pure economical point of view, it depends on whether you have more time or more money.
  6. guru_del
    guru_del New Member
    33
    Lake Elsinore, Ca.
    i need to pull the code on my car but i have 179,000 miles on my 01 and if that is the case, i will drive it until it falls into the ground. I dont mind looking at the cel so i will just run it until it breaks then get a new one. I went to carmax to get a quote and the guy laughed at me (i was lauging too so it wasnt too bad) so i assume it is a part out and scrap only option here for me (or take the 1,000 trade in at the dealer).
  7. richard schumacher
    7,664
    1,045
    United States
    How much would you be willing to spend to buy a different car? Then consider how many repairs that amount would buy on this one. You can't buy much of a car for $4000.
  8. priushippie
    priushippie New Member
    330
    Pennsyltucky
    Check eBay for new or used one. Put it on yourself!
  9. Politburo
    Politburo Active Member
    971
    208
    You might not mind looking at it, but you can't pass inspection with a CEL. The smog check exemption for hybrids expires at the end of the year.
  10. Eoin
    Eoin Active Member
    593
    116
    Long Island
    Trade it. The 3rd generation is much better.
  11. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Buy NEW, NEW!!
    Or Low mileage used.
    What do you expect, a trans axle maybe , battery pack or ??? whats next!
    How much repair do you really want to put into it to keep it running?
    Chances are high something else can or will fail soon.
  12. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    $1600 is an expensive repair, but cars are expensive. Just the carrying costs for one year on a $25k loan is about $1200. If I thought the car was otherwise in good shape, I would repair the G1 Prius.
    btw PriusChat folk, is cat replacement a repair that independent mechanics might undertake ? The Toyota dealer mechanic is likely to be quite a bit more expensive than other garages.
  13. guru_del
    guru_del New Member
    33
    Lake Elsinore, Ca.
    thanks for the info Politburo, didnt see that date on the end of smog exemptions. May be time to see if it is a cat issue or an O2 sensor issue, that code is based on both O2 sensors having similar readings, thus if the front sensor is shot you can get this code as there is no diference in readings.
  14. boppo
    boppo Active Member
    799
    139
    Owego, NY
    If you look at complete coverage for ins and the interest on a loan that would be way more than 1600 not to mension all the goodies you will buy her. I wouldn't have any problem putting 1600 in my 1988 243,000 mile camry because it has many many more years left in Betsy. :)
  15. dogfriend
    7,512
    1,189
    Carmichael, CA
    I provided the link to Art's Automotive earlier. They showed how they replaced the 1st Gen cat with a cheaper aftermarket cat, but they no longer offer the repair since it is illegal in Calif. I have also heard of others replacing the cat with a salvaged one with success.
    I think it is doable, but no one can guarantee that nothing else on the car will go bad. If it were mine and everything else was in good condition, I would try to find someone to install an aftermarket cat. But I am able to do a lot of DIY repairs, so I am not so dependent on the dealer.
  16. fitjulie
    fitjulie New Member
    New York
    2002 Prius
    Thx everyone. So far, I've gotten a couple more opinions from ind. mechanics, & looked at the new 3rd gens.
    Both mechanics would charge exactly the same as the dealership - interesting....
    And the new Prius is SO nice!
    Still deciding - I figure I've got a few months to figure out what I'm going to do.
  17. F512M
    F512M Member
    415
    Laguna
    If you have the time to deal with repairs, then repair it. If you don't have time, then buy a new one.
  18. fitjulie
    fitjulie New Member
    New York
    2002 Prius
    Thx everyone.
    So, I ended up going with a new one (actually a used demo w/ 1000 m.). I was perfectly happy to do the repair & keep driving the '02, but figured it was worth looking. It's a IV & was able to get it at almost the negotiated price on a new III. I pick it up in the morning after I clean all the crap out of mine. I'm really excited - the gen IIIs are so nice!
    And it's got the all weather mats - really good for all my muddy boots, skis & climbing gear!!!
    Happy & Healthy New Year to all!
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
    Enjoy your new car. What happened to the G1 ?
  20. fitjulie
    fitjulie New Member
    New York
    2002 Prius
    traded in
