service menu 12 volt
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Russ33, Dec 15, 2009.
  1. Russ33
    Russ33 Older Junior Member
    Long Neck, DE.
    I've just replaced my 12v battery with much help from the forum.
    Now I would like to be able to find the Service Menu to keep a watch on the voltage to be able to replace the battery next time before being stranded.
    I think at one time I had found the Service Menu, but now can't.
    Not able to get MFD in the Maintenance mode.
    What is the routine to, please?
    Prius '07, no NAV system, Package #2.
    Thanks - Russ
  2. Pdub
    Pdub Junior Member
    Phoenix, AZ
    Here you go...
    You can test the car's 12V battery using this procedure (thanks to jdenenberg):
    - Without brake pedal, press the Power button once and release to enter ACC mode
    - Press and hold the MFD Info button while turning the headlights on and off three times to enter Maintenance mode; release Info button
    - Press "Menu" (on screen)
    - Press "Display Check"
    - Press "Vehicle Signal Check" - the battery voltage is shown and should be about 12.4 to 12.8 Volts (normal for an unloaded battery)
    - Again without brake pedal, press Power button and release to put a current load on the battery - the voltage should stay above 12.0V (if less than 12.0V the battery is not well, or there is a fault or unusual load somewhere)
    - Press brake pedal and press Power button once to enter "Ready" mode - the battery is now charging at about 14V (if less than 13.6V or more than 14.4 there is a problem, possibly with the charging circuit)
    - Turn car OFF to leave Maintenance mode
  3. Rest
    Rest Active Member
    1,210
    CA
    I know this is an old thread but, I tried that procedure for our 2006 Prius and it wouldn't go into maintenance mode. Any suggestions? That procedure worked find with our other Prius, a 2007.
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Try this other method and see if it helps (claimed for [FONT=arial, helvetica]2004 to 2010 Prius[/FONT]):
    http://priuschat.com/forums/gen-ii-...out-switching-headlights-off.html#post1095046
    Good luck and let us know whether it works. :)
  5. jdenenberg
    jdenenberg EE Professor
    3,946
    1,942
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 sometimes requires 4 or 5 cycles of the headlights while holding down the MFD "info" button to go into "maintenance" mode.
    JeffD
  6. Patrick Wong
    18,210
    6,511
    I'd avoid the headlight on-off cycling method if your car has HID headlights.
    Gas-discharge lamp - Wikipedia, the free encyclopedia
    "Factors of wear come mostly from on/off cycles versus the total on time. The highest wear occurs when the HID burner is ignited while still hot and before the metallic salts have recrystallized."
  7. 2009Prius
    2,705
    512
    63
    Yes I believe any light using hot filaments will suffer from thermal shocks from on/off cycles. That's part of the reason I prefer this other method:
  8. XxDarkSidexX
    XxDarkSidexX New Member
    Orange County
    I would agree if the bulbs are cold and haven't been run sense the previous day, and you on/off 3 times first thing. But if you let the lights be on for a few seconds they will get warm. This also explains the color change in the bulb as they come up to operating temp, as the light spectrum gets charged into range one will see the color change. You can also verify this by being in 'maintenance' mode and watching this, but during this 'warm up or charge up' of the HID bulb that is when the battery will dip the most, and soon after warming up the voltage will go back to where it was at before we demanded the extra juice to warm up the HID's to normal operating temperature. But if you try just leaving lights on for a few seconds to 'warm up the bulbs' then the shock of on/off is greatly decreased and has no effect IMHO. I have worked with HID's on multiple other cars (installation and customizing), the warming the bulb tech. seems to work across the board for HID's. Only time I have seen HID's go out is if someone touched the bulb before install, other then that I have seen many more projection bulbs blow before HID's. Hope this helps some people out there, it is just my experience. I just wish I could run my radio while in maintenance mood, I want to see the drain with my radio, o well.
    Rant for Wong............ACTION!
    I did the Trans Fluid, Inverter Fluid, Hydroedge pumped up to 50psi, changed oil, capped off brake fluid, cleaned MAF/throttle body and the PVC valve (just removed and cleaned), on my 115k 04. Saved a TON of money from going to the dealer so thank you, if you ever come to So Cal please PM me for a nice treat. She's still getting used to the changes but man what a difference in response and general ease feel. Not really seeing huge increases in MPG but I completely notice the feel of the car, it feels like its doing the same amount of work but with MUCH less effort. Car rides smooth like new again. Thanks you so much. Up next will be shocks, and turning the front rotors, checking rear drums assembly, rotating tires, and I am getting very curious to see the condition of the battery vent in the back (read a few crazy stories). I also did the battery test through the vehicular signal, seems to be within acceptable operating range but is a little on the low side and could definitely be explaining my MPG drop. I'm thinking about the optima yellow (the famous kit) sense the OEM cost to replace is almost just as much anyways. Also I did some reworking of the intake system for some fresh air, and I am thinking about getting a K&N filter, though I have read some posts saying not to. I have run K&N on all my cars with Zero issues. Anyone worried about oil going into the engine has never properly learned who to install one, let alone maintain one properly through cleaning and reoiling. A quick note the PVC line was an easy clean w/o brake cleaner, just rip or cut a piece of towel and damp it with aqua and slip through to clean.........and scene.
  9. Rest
    Rest Active Member
    1,210
    CA
    Our 2007 has HID headlights and I got into the service menu on the first try and I cycled them when they were cold.
  10. Patrick Wong
    18,210
    6,511
    Glad that you registered success with your work.
    I've previously posted on replacing the front struts and rear shocks.
    http://priuschat.com/forums/gen-ii-...ts-regarding-replacement-2g-front-struts.html
    http://priuschat.com/forums/gen-ii-...oubleshooting/74531-replaced-rear-shocks.html
    When you work on the rear shocks, that would be a good time to look at the traction battery vent.
    Unless you notice pulsation when you depress the brake pedal, your rotors may not require attention. Their thickness when new is 22 mm and min thickness spec is 20 mm. I measured the front rotors on my 2004 recently and they were at 21.5 mm (measured when the car had ~100K miles.)
    I lived in south OC for nine years and enjoyed my time there. Still visit 4x per year as my daughter is a student at UC Irvine.
  11. Rest
    Rest Active Member
    1,210
    CA
  12. kocho
    kocho Member
    134
    Maryland
  13. 2009Prius
    2,705
    512
    63
    I don't have nav so I don't know. Did you mean a virtual button on the screen? Does that button cover the entire lower left corner of the screen without any boarder? If there is any boarder space I would try pushing there. Good luck!
  14. AzWxGuy
    AzWxGuy Weather Guy
    1,061
    544
    Tucson, AZ
    2021 Prius
    Concerning cycling headlights three times, I read somewhere in these pages that you don't have to go all the way to headlights. Cycling to parking lights three times will work. And sure enough, I just did it and it works. Save those HID's !
  15. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Yes I have a 2008 with nav and it has always worked for me.
  16. kocho
    kocho Member
    134
    Maryland
    Where do you press on the lower left? On the "Info" screen I got a "Consumption" button there, but maybe I was in the wrong screen... I'll check again tonight to make sure I follow the directions right. The headlights method works but with the HIDs I'm reluctant to use it too often.
  17. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Search on here for Service Menu and you can find a video where someone shows how to do the "finger dance".
  18. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Press where the numbers "1" and "2" are marked on the attached picture.
