Battery dilemma
Discussion in 'Gen 3 Prius Main Forum' started by gene4655, Dec 19, 2009.
  1. gene4655
    gene4655 Junior Member
    51
    I have a '06 and a '10, and I think the same dilemma applies with a battery problem. On the '06, I left the door not closed completely, and the battery ran down. Called AAA, got a charge, wanted to take it to my Toyota Dealer to get a new battery, the AAA guy warned me not to let the engine die on the way. When I got to a stop light and stopped, the engine died. Had to call AAA again to get going. Tried to coast to the next stop lights, did so successfully, got to the Toyota Place, pulled up to the Service area. Stopped. Motor died again. Wouldn't start. Was pushed into the service area, got a new battery. SO, the question is, is there a better way to get to the dealer, stopping at lights, without letting the motor die? Be easy on me. I'm not very smart.
  2. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    How far did you get before the engine died? The traction battery should have recharged the 12 volt in a pretty short time. I suspect the battery in the 06, probably the original was done for and this would not happen with a good 12volt battery.
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    There is a problem with the charging system. The car can run quite some distance with a defective inverter, as the 12V battery can operate the computers. But without the inverter transferring power from the high voltage traction battery to the 12V battery, the 12V battery will discharge to the point that the computers don't work.
    I suspect that the inverter coolant pump has failed. Without cooling, the inverter overheats and drops out. If it overheats too much, then it's totally destroyed, but we don't know if that's happened yet.
    Don't drive the car over 2-3 miles at a time until you can get the pump checked. If the inverter is still functional, it will charge the 12V battery until it gets too hot, and then drop out. Short trips will work ok, but longer trips will draw down the 12V battery to the point that the auto-start function will no longer function.
  4. richard schumacher
    7,664
    1,046
    United States
    gene, if the 12V battery were merely drained, after a jump start you would have been able to drive it normally to the dealer. Something else/worse is wrong, and the only good way to get it to a dealer would have been to tow it.
  5. mike lipke
    mike lipke New Member
    89
    MN
    Or maybe it is just as simple as the 12 volt battery is toast, and the new one is fine and it will never happen again. I believe there is a 10 minute shutoff on the interior lights, so you may only think it discharged the battery. The battery could have reached the end of its life and the light just pushed it over the edge. If you don't have issues in the next few days, you are probably just fine.
  6. alokeprasad
    alokeprasad Member
    162
    Ohio
    IMO, the Prius should be able to diagnose such a major failure of an important part (like the overheated converter) and display an appropriate msg on the display.
    Come to think of it .. does the car display any diagnostic messages (in plain English) on the display (the same one that greets me so nicely with a Welcome when I start the car)? That would be a good application of the display.
  7. gene4655
    51
    Once the car was started by AAA, there was no display message at all....looked as normal. Thanks for these replies. I think maybe the battery had just gone bad, because since it was replaced with a new one (about $135!), no problems at all.
  8. ceric
    ceric New Member
    1,114
    Fremont, CA
    You're kidding, right?
    $135 for a Prius battery? Does that include labor at Toyota?
    Did you DIY?
    I called around and found $185 to be the best price to replace the 12V battery of my
    2005 Prius. Nothing was wrong, but I figured that it was about time. I never let
    battery interrupt my trips. They always die at the most inconvenient times.
  9. RobH
    RobH Senior Member
    2,385
    991
    70
    A functioning inverter provides about 14V the entire time that a Prius is in Ready mode. A dead battery would not normally shut down the car like reported here. You would expect the normal starting and stopping of the engine to continue even with the 12V battery dead. I suppose a shorted battery might be enough of a drain that the inverter couldn't keep up, but that seems very unlikely.
    There was a long, involved story about a pump failure that I can't locate just now. The pump failed, which allowed the inverter to overheat after quite some time. It was something like 10 miles of travel. When the inverter overheated, it dropped out, leaving the 12V battery to run everything. That was good enough to go another 5 miles or so. The result was that 15 mile trips worked fine, but add a few more miles and the 12V battery went flat. In this case, the P0A93 code didn't show up, even though it would be expected. Given the cold weather this time of year, a similar failure might go totally undetected with short trips and a brand new battery.
    The inverter coolant pump was upgraded late in the 2006 model year. And the 2010 has an improved pump control system that should improve the life of the pump.
    You can check if the pump is functioning ok by taking the cap off the inverter reservoir and seeing if the coolant is moving. Play the video at the end of the blog post at Luscious Garage | Blog | Prius Code P0A93: Inverter Water Pump Failure
    See also the tread http://priuschat.com/forums/gen-ii-...g/36513-inverter-coolant-pump-takes-dive.html
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Gene, are the displayed voltages within spec on the 12v? If not, I'd return it to the dealer under warranty.
  11. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    I wonder if the 12v battery was completely shot. When he stopped the car, the gas engine shuts off. The 12v simply didn't provide enough spark to get the engine re-going. I guess the question is, is there anyway for us to keep the gas engine on?
  12. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    The traction battery provides the power (via the inverter) when the engine is stopped so the 12V battery is not really required at all once the system is started.
    There is no need to keep the gas engine going.
    kevin
  13. qbee42
    3,079
    The only way this becomes an issue is if the 12V battery is shorting the 12V bus. It's very uncommon, but a shorted battery would drag down the 12V bus and cause any number of weird problems.
  14. garygid
    garygid Senior Member - Blizzard Pearl
    379
    Orange County, CA
    As I recall, one can see the voltage of the 12-volt system using the "hidden" menu.
  15. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    Quick test to do:
    1. boost and start the car in READY mode
    2. disconnect the 12V battery, (-) side
    3a. if the car quits READY mode ("dies"), the problem is at the inverter, not simply at the battery
    3b. if the car continues to run, it may simply be the 12V battery
    Can someone confirm the logic? Usefulness of this test?
  16. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    first off, what kind of car do you have?
    in a Pri, the engine does not die. it does cycle on and off depending on the state of the car. but after the car is started, it does not use the 12 volt battery, so having a dead one is not likely to cause your car to not run after its started.
    if this is true, it sounds like you have a major traction battery failure along with several monitoring systems since your dash should have lit up like the tree on the lawn at the Kennedy Center
