The Windshield Sprayers are AIMABLE!!
Discussion in 'Gen 2 Prius Main Forum' started by TonyPSchaefer, Jul 3, 2005.
  1. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    I am one of the many who complained early on that the windshield washer fluid sprays just an inch or so above the folded wipers. Thus, the outer reachs of my wipers are merely smearing the dry dirt around.
    Yesterday, bored to tears, I decided to take a closer look. I've attached a picture. I apologize for the crudeness of the picture. You can see that each sprayer is split in two with each side containing a rotatable sprayer housing of two spouts. (I'm having difficulty coming up with descriptive words). Using needle-nosed pliers, I managed to move one higher. So high, in fact, I believe it was spraying over my car.
    BE CAREFUL*
    I managed to mangle my passenger sprayer though it still works. Do not attempt to aim the sprayer by grabbing the vertical tab. Oh it's deliciously attractive and looks like an awesome way to aim the sprayers. You WILL regret it.
    What worked for me was to put one end of the needle-nosed pliers under the rotating sprayer and the other on the outside of the housing. Ever so gently I was able to move the sprayer up. It was a little harder at first, presumably because it hadn't moved before. Once I have initiated movement, I got the tiniest screwdriver I had and could push the spouts around.
    Once I got the hang of it, I was able to aim them all higher and strategically place the streams exactly where I wanted them. I did use what seemed like a good deal of washer fluid, but feel good knowing that my windshield now cleans TONS better.
    Note that there are actually eight streams that shoot at your windshield and some cross paths before hitting your glass. With some tinkering, you can make them hit exactly where you want.
    The ones in the back do not seem aimable.
    *I assume no responsibility if you squish, mangle, or otherwise negatively affect the function of your sprayers.
  2. Tideland Prius
    16,538
    Congrats on your find!
    Hmm, I just want the rear to spray a bit better. All it does is just release liquid in two directions. I could've let the rain do that.
  3. Sufferin' Prius Envy
    3,998
    Having the sprayer out on the hood where it can drool washer fluid on the hood and clog from a wax job doesn’t make sense to me.
    I like the system on my 1984 GMC pickup truck better. The sprayer is on the under side of the wiper arm itself. The spray is applied exactly where need . . . not on the car driving behind you! (That is unless the car behind is tailgating . . . then large dosages are called for :p )
  4. Gen2
    Gen2 Member
    319
    All I can say is, Thank You!
  5. jimofdg
    jimofdg New Member
    533
    DG, IL, US
    <div class='quotetop'>QUOTE(TonyPSchaefer\";p=\"103740)</div>
    Sounds like Tony has found a way to keep the Hummers from following too closely! Great work!
  6. dgw
    dgw New Member
    Mill Valley, CA
    I had to laugh because I had the exact same experience. Eventually I settled on a large slot screwdriver to encourage the nozzle head to move in the direction I wanted. Minute adjustments yield surprisingly large results on the windshield! I also found the best result was to cross the streams from adjacent nozzle heads so they overlapped as symmetrically as possible (note: not easy to do). One more thing, aiming a little lower than you might think is optimal will give better coverage, because on the upstroke the fluid spreads outward along the edge of the blade towards the end.
  7. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    <div class='quotetop'>QUOTE(dgw\";p=\"104622)</div>
    I thought crossing the streams was baaaad?...
  8. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    It'll kill her, AND US!
  9. ml194152
    ml194152 Member
    135
    Katy, TX
    I've been aiming windshield washers on my cars for years. All you have to do is insert the sharp end of a safety pin into the washer hole and turn the safety pin to your hearts content.
  10. LewLasher
    LewLasher Member
    244
    66
    Cambridge, Massachusetts
    2019 Prius
    XLE AWD-e
    I've been away from PriusChat for a few months, so pardon the untimeliness of this, but:
    When I saw this thread topic (among the 47 pages of "view posts since last visit"), my first reaction was that Tony was so enamored with the windshield sprayers that he lapsed into French for some reason and was exclaiming generally that the sprayers were REALLY NICE!!
  11. TonyPSchaefer
    14,816
    2,500
    66
    :cool:
    Originally, I meant to type that they are amiable. Once I realized my typo I figured that I'd might as well create a post to go along with it.
  12. Anonymous
    Anonymous Guest
    I must say that I was rather surprised when I tried the front washer for the first time yesterday. Maybe it's just having a new car in general, but the feeling was not unlike replacing my old shower head with a new supersoaker massaging unit.
  13. mdh
    mdh New Member
    48
    Sorry to bother you about such a simple question. I would like to move the washer streams higher on my car. You mentioned inserting a pin into the hole and turning it? I assume you mean "move" rather than turn? Do you do this for each hole or just move the whole unit? Can you adjust each stream?
    tks much and sorry to ask just a basic question.
  14. patsparks
    10,664
    567
    Adelaide South Australia
    If you use 2 pins you can rotate the nozzle but the 2 streams from each ball nozzle will still be the same distance apart. So by turning them a little you could make one squirt higher than the other. You might play with one of each nozzles streams on the top of the screen and the other just above the wiper.
  15. mindbash
    mindbash New Member
    Stockholm, Sweden
    I have been using pins for aiming washers for years as well. Works on most cars.
    A safety pin gives a good grip, but could be a bit thick. Ordinary pins does the job. Just grab one from the next shirt you buy.
    In my experience pins is the best method. I tried using pliers once. That felt quite crude and more likely to break someting compared to the pin method.
  16. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    By using a pin, you can rotate the nozzle in any direction you want. you don't need two pins. Just stick the pin in and use it like a joystick..... but be careful a little goes a long way. Like the other person said.... Been using that method for many years. Sometimes they get stuck and take alittle to get them to move, but DON'T use pliers or screwdrivers. All you will do is ruin the nozzle.
  17. hill
    8,775
    Being the consummate prankster, I can't wait 'till I get home. Aim one towards the sidewalk, while waiting for the green light. Aim the other straight up in the air to squirt the tailgater behind you on the freeway. :D
  18. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Hill,
    +1, but why not use one/both of the nozzles for the hatch window for the tail gater?
  19. mdh
    mdh New Member
    48
    thank you everyone.... my stream also does not look very strong.... should i just use my air compressor? Any recommendations? My friend's prius is much stronger.
  20. Scummer
    Scummer Eh?
    174
    29
    Munster, IN
    Darn, you beat me to it. Only that I used a pinhead needle.
