12 VDC battery connector addition
Discussion in 'Gen 3 Prius Audio and Electronics' started by rrolff, Dec 22, 2009.
  1. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Anyone have recommendations for connecting stuff to the battery? Not sure if it has side post threads - or a good way to make multiple connections... I'm adding a 1500W inverter (4 awg wire), a sub (8 awg), and some ancillary stuff (12 awg)...
    Pics would also be great!
    TIA
  2. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    I've got a 1,500 watt pure sine in the trunk, but I believe the battery can only handle about 1,000 watts so I put in a breaker that's underrated relative to the rest of the system. I found Anderson PowerPole connectors satisfactory for connections.
  3. sciguy125
    sciguy125 Junior Member
    CA
  4. rrolff
    1,610
    246
    So Cal
  5. kenmce
    1,552
    525
    NY
    * Where in the car do you want them to be?
    * Will they come and go or will they be installed and stay there?
    I got my plug from powerwerx.com. Specifically I went with two of the 175 amp Powerpole plugs. One plug is wired directly to the battery with 4 gauge multi strand copper wire and goes through a hole into the upper trunk. When not in service it just lays in there with a dust cover on it. When in use, it plugs into a matching fitting that leads into the inverter. When not in use it is unplugged because it turns out my inverter always has a slight draw. The fittings are polarized and it is not possible to plug them together backwards. I'm wondering if the "Chassis Mount"fittings might be right for you, but am a little vague on your exact setup.
