Ideas needed for playing FLAC files
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by zenMachine, Dec 25, 2009.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    I have just received for Christmas the Beatles Remastered Stereo USB apple, in 24-bit FLAC format (as well as the lowly and ancient MP3). It is one awesome sounding collection of some not-so-bad music. Very convenient too. Just pop the USB stick into my laptop and put on my headphones.
    Now I wonder what is the best way to play these lossless files in the car. The only thing I can think of so far is to buy a media player that supports FLAC (like a Cowon iAudio) and plug in through the Aux port. But that would still require converting and loading the files to the player.
    Would be so much nicer if you could just plug the USB stick into the head unit directly somehow. Any ideas/suggestions?
    Thanks, and merry Christmas to all!
  2. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    Try a SanDisk Sansa:
    SanDisk Sansa Clip+ (4GB, red) MP3 player reviews - CNET Reviews
  3. a_gray_prius
    2,927
    783
    IL
    I'll refrain from going on about how much the Beatles suck and suggest you simply transcode the files into higher quality MP3.
    Transcoding everything to everything with MediaCoder | Internetspotter
    1. Mediacoder is free software (as in speech and beer)
    2. By not buying yet another consumer electronics crap device, you're helping to save the environment just a little bit
  4. uart
    uart Senior Member
    4,220
    1,209
    Australia
    I don't agree that the Beatles "suck" but +1 on the transcode idea. I recommend using a high quality variable bit rate encoder that gives about 200kbps or higher average bit rate.
    Contrary to what marketing people will tell you the fact is that even under the most ideal listening conditions and even with the most discerning listeners, they generally can not distinguish between 16 bit and 24 bit formats under blind testing conditions.
    BTW. A car is far from an ideal listening environment. Even in a prius there is enough noise from road and wind and other traffic that you will never be able to tell the difference between high quaility mp3 and 24bit lossless flac.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Plus there are more than "enough" distortion introduced by the entire audio system and the cabin environment, unless you custom build the sound system. ;)
  6. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    And sound-proof your cabin :)
  7. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    If you are going to go this route, I would suggest the Sansia Fuze (8GB) instead. It also has a micro SD slot so you can add another 8GB. I have one (& love it). Only "issue" with this (or most any similar device) is that you can't use a cigarette lighter type charger and play the device at the same time (there is a conflict between the ground of the charger and the audio ground of the aux in).
  8. Bob64
    1,540
    93
    Virginia
    There's a TSB out for this that fixes the issue. Toyota will fix it for free if your within the warranty period of 3 years and 36000 miles.
    http://priuschat.com/forums/toyota-prius-service-bulletins-tsbs/46700-noise-aux-port-06-08-a.html
    They'll install a ground loop isolator for your aux input that'll fix the problem.
  9. dhancock
    357
    40
  10. Bob64
    1,540
    93
    Virginia
