Kind of Awesome: STi Pulls Semi Out Of Snow
Discussion in 'Fred's House of Pancakes' started by a_gray_prius, Dec 28, 2009.
  1. a_gray_prius
    2,927
    783
    IL
    Kind of cool if you like performance cars:
  2. fuzzy1
    10,588
    Cool, though I'd hate to see the clutch afterward if the truck had been seriously stuck. I won't risk trying to pull that thing out of any ditch with my Subaru.
  3. Mjolinor
    Mjolinor New Member
    229
    Greece
    2002 Prius
    I did that once with my Land Rover. I had to snatch it an inch at a time with a chain and it stretched the chassis, none of the doors would shut afterwards, I had to bungee them together till I could get back to the garage and reposition the rear body forward a bit. :)
  4. patsparks
    10,664
    567
    Adelaide South Australia
  5. Mjolinor
    Mjolinor New Member
    229
    Greece
    2002 Prius
    It is actually a regular thing on series 1, 2 and 3 land rovers, pre 1972 or so when you were pulling big loads because of the way the door catch worked, it was just like a normal house door so if you moved the bulkhead forward or the back body box back the doors didn't reach the catch.
    It was rated to tow 3 tons but would actually pull around 25 in FWD before the transmission trashed.
  6. Gasitman
    Gasitman New Member
    118
    Washington
    I find that very hard to believe. I had a wrx, and yes they are capable in the snow, but not for towing, especially a semi.
  7. Tideland Prius
    16,602
    interesting.... the truck must've been helping or that's one hell of a chassis from Subaru!
  8. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I was most impressed by the guy riding by on the bicycle.
  9. fuzzy1
    10,588
    It looked and sounded to me that the truck was still doing most of the work, and the Subaru was just adding some boost. It wasn't dug in or seriously stuck.
