Fuel Filler Neck
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TopJimmy5150, Nov 30, 2009.
  1. TopJimmy5150
    TopJimmy5150 Junior Member
    55
    Gillett, PA
    I've had my Prius IV for a month or so now. One weird thing I've noticed when I'm filling it up with gas...the fuel filler neck (the gas cap screws onto) is loose...it almost feels unattached.
    Is this normal? Sorry if this has come up before, but I did a search on Fuel Filler Neck and only came up with 2nd Generation TSBs.
    -Jay
  2. TopJimmy5150
    55
    Gillett, PA
    Good to know I'm not the only one. I'm wondering why it's that way.
  3. SF Prius
    SF Prius New Member
    San Francisco, CA
    Me too... I'm always worried that the whole thing will fall apart when filling the tank and I'll have gas going all over the place!
  4. TopJimmy5150
    55
    Gillett, PA
    Everyone has to get fuel once in awhile...please chime in.
  5. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    i think it may be rubber mounted. Mine feels loose when i have the gas pump handle in it.
  6. MikeDS
    MikeDS Member
    298
    Los Angeles
    Mine is loose too...figured it was by design.
  7. dwhutch
    dwhutch New Member
    Los Angeles
    Mine is the same way. It hasn't been a problem so far.
  8. krajesj52
    krajesj52 New Member
    Connecticut
    I have a 2010 GenIII Type 2 and my filler neck is not loose.
  9. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    I'd say the filler neck is "flexible," rather than "loose."
    The neck is also not totally metal. This is by design. There's a weight consideration, since a heavy, rigid, totally metal filler neck would be heavier, and require sturdy metal brackets to connect to the filler door housing. I was surprised, when the filler neck on my old Honda Prelude corroded, the new part was heavy, about 10-12 pounds! And that brings up another point: the Prius's neck will not be likely to corrode since it isn't all metal!
    It's interesting to see how Toyota designers fit the filler tube into the Prius. There isn't much room for it!
  10. Ledge
    Ledge Junior Member
    33
    Pueblo West, Colorado, USA
    Two Eco
    I also have a 2010 Prius II, and my filler neck is not loose.
    Seems nice and solid.
  11. fly navy
    fly navy Ex Jet Driver
    Bellingham, Washington
    My II has less than 5,000 miles and the filler neck is rock solid. If I press real hard I can feel very slight "give" as if it has a rubber shock mount, but nothing remotely loose.
  12. thbjr
    thbjr Member
    326
    63
    Phoenix
    I see this is your first post.
    Welcome to the PriusChat Herd...
    Click here for details;)
  13. danep
    danep Junior Member
    San Francisco
    I think we're arguing semantics here. The neck on my 2010 Prius III definitely moves around a lot more than anything I've seen on other vehicles. You could call it loose, though I understand why some people wouldn't, since I think it has a negative connotation and implies that it's not by design.
    One thing I have noticed is that because of this flexibility, the pump handle tends to rest much closer to horizontal than I'm used to. I've noticed that this caused a lot of pumps to automatically shut off while filling, which can get REALLY annoying. Anyone else noticed this?
