SmartKey not unlocking rear door or hatch
Discussion in 'Gen 3 Prius Main Forum' started by alokeprasad, Dec 6, 2009.
  1. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    We are just going to have to agree to disagree. But even in your scenario they are still painting the spoiler, whether they hang it and paint it when the car is being painted or whether "painting in black separately".
    Toyota admitted one of the goals moving forward with the new Prius was to reduce production costs. Seems easy to me that logically the Generation 2's had color matching spoilers and "magically" now the 3rd Generation all have one single generic spoiler, that it was a cost cutting measure. I find it hard to believe that behind the scenes someone would say, " You know, it's going to cost a little more, but let's make all the spoilers look the same".
    But it's not a big deal to me one way or the other. I honestly like the color matched spoilers better. On a Black Generation 3 or On the Blizzard White Generation 3 I think the Generic looks good. On all the others I'd personally like a color matching spoiler. But it's not a make or break issue, just an area inwhich I think Toyota cut costs. If you want to think a one spoiler fits all was NOT a cost cutting measure...I have no behind the scenes connections I can't prove it costs more or less for either...but personally I like color matching better.
  2. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Actually that feature is programmable by the owner, dealer does not have to do that one. Check your owners manual.
  3. jmp
    jmp New Member
    27
    Socal
    Someone should revisit the manual. It is programmable by owners who have the smart access key with entry function i.e. Prius IV/V owners like you. It is not programmable by owners who have the smart key without entry function i.e. Prius II/III owners like the OP and me; hence, we need to go to the dealer to have this done.
  4. anniea
    anniea New Member
    59
    Atlanta
    Hi--No, actually, the earlier post is accurate when it says the following: "Ok, to have it unlock all the doors when you touch the drivers door handle your do so by holding both buttons on the key fob while inside the vehicle for 5 seconds give or take."
    I just now did this on my III, and it worked fine.
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Door handle SKS can be self programmed using the method I described at the top of the thread to have either just the drivers door unlock or have all the doors unlock.
    Key fob programming must be done at a dealer to have one press of the unlock button unlock all doors instead of having to press the unlock button twice.
    Hope this helps clear things up a bit.
  6. dzongrila
    dzongrila New Member
    24
    Tucson, AZ
    My wife doesn't like this feature that the car unlocks itself if you have the key in your pocket and approach the car. Is it possible the disable this? We asked the sales guy and he said that it can't be done. But I think there should be a way to do this. Thoughts?
  7. IraS
    IraS Member
    165
    Austin, TX
    It doesn't actually unlock the car when you approach it.
    The SKS will arm itself when it detects the key fob near one of the sensors (i.e. the driver's door and, on the models IV and V, the passenger's door and rear hatch). Once the system is armed, if you touch the sensor on the door handle, it will unlock the doors you selected. For the driver's door, you can either have it unlock only the driver's door (which is the default), or you can change it to unlock all doors. For the passenger's door and the rear hatch (only on the models IV and V), when you touch the sensor it unlocks all doors.
    But, again, you have to actually touch the sensor to unlock the doors. Just approaching the car only turns on the interior lights and prepares to unlock the doors.
  8. dzongrila
    24
    Tucson, AZ
    Well, the sales guy did a demo. I had the key in my pocket and came pretty close to the car. He was standing near the driver door and opened the door for me. My wife is worried that she may come too close to the car without intending to open the door and then leave without actually locking it again. Will the car lock itself if I leave without locking it again?
  9. carrot2006
    carrot2006 New Member
    Davis, CA
    The car won't be unlocked until you put your hands on the handle. So if you get closer but do not touch the door, the car should not be unlocked.
  10. Joe166
    Joe166 New Member
    720
    97
    South Florida
    I don't think that's true. Today I was waxing my car and the doors kept unlocking when I got quite close to the handle. My wife's Lexus had a problem with not being sensitive enough and the Service Manager told her to replace the batteries in her remote because he had several people whose doors unlocked whenever they got within a few feet of the handle.
    BUT, I thought I remember reading that the door will relock if it is not opened within a certain time. Maybe a minute or two? It should be easy to test that.
  11. web1b
    web1b Active Member
    817
    52
    Even so, waxing the car is not the same as just walking nearby without touching the car.
    I wonder how many people were just assuming the car was unlocking because the interior lights turned on when they got near the car.
  12. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    While the decision to put non color-coded spoiler on non-Solar Roof Prius may have been a cost cutting measure, it's designed to coordinate with the Solar Roof look. In fact, Japan sells color-coded Gen 3 spoiler as an accessory. It'd be a cool mod here if you have a non-SR Gen 3 (except black of course).
  13. The Electric Me
    9,083
    5,801
    That's interesting. But if that logic was true, and not primarily a cost cutting measure you'd have color coded spoilers on all the non-solar roof Prius. From a #'s standpoint, they still sell far more non-solar roof Prius. I don't buy the logic that Toyota would coordinate the entire Prius line based on The Solar Roof Package and then just decide without "savings" involved, to employ it on ALL 2010 Prius.
    Even if I owned a solar roof I think I'd still want a color matched spoiler...but I'd have to take a closer look.
    Nice to know color coded spoilers are available.
    PS. I'm sorry this has gotten off track severly for this thread.
  14. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I agree it's a cost cutting measure, in favor of the SR. Just like the dummy fogs in favor of the V.
    It'd break up the flow and look disconcerting.
  15. Joe166
    Joe166 New Member
    720
    97
    South Florida
    Yes, it will. At least mine did. I tried it last night and after about a minute if you haven't opened a door, the doors locked again.
  16. dzongrila
    24
    Tucson, AZ
    Thanks Joe. Now that I've got the car and reading the manual, I can verify them. This is from the manual:
    Security feature
    If a door is not opened within approximately 60 seconds after the vehicle is unlocked, the security feature automatically locks the vehicle again.
  17. dzongrila
    24
    Tucson, AZ
    I see a lot of references of 'Mechanical Keys' in the manual in case the wireless key is not working. Did anyone get a 'mechanical key'? I didn't.
  18. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    It's built into the fob. There is a button you press on the side and then the bottom part where the rind attaches to the fob for say your house keys slides out of the fob and there's a mechanical key on that.
    this picture is from a Gen II (2004-2009) key fob but it's the same type of thing...
  19. dzongrila
    24
    Tucson, AZ
    Great. Got it. Thanks.
  20. qbee42
    3,081
    dzongrila, you should update your profile. It shows you driving an "other non-hybrid", which is confusing when you ask questions about the Prius.
