A story and two DTC codes.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by andydrew39219, Dec 3, 2008.
  1. andydrew39219
    andydrew39219 New Member
    on an island off the coast of Maine
    Ok, I a am junior (11th grade) at a small school on a small island off the coast of Maine. For our alternative fuels class we chose to purchase a wrecked 2004 prius (with factory NAV) and repair also doing some modifications. about a year ago we purchased it and have stripped a lot of stuff off of it but being that the class is twice a week its hard to get alot of work done. for my part of the project my teacher found something that would be useful for our prius, its called CAN-view (for more information about CAN-view go to the CAN-view website, just google CAN-view it should be hybridinterfaces. something, i would directly link it, but this is my first post so i am not aloud to directly link things ). one useful thing about CAN-view is that it detects all the DTC codes, our prius has two DTC codes, that i can not seem to find anywhere I look, i can find the two codes for other cars made by different manufacturers but not the codes from toyota or prius specifically. The two codes are P0111 and P1800. I have determined that it is an engine problem and I am almost sure its to do with the powertrain (hence the P infront of the 4 digit numbers) but im not sure. Any help would be appreciated, hopefully someone will know these two codes.
  2. dogfriend
    7,512
    1,189
    Carmichael, CA
    I looked for both codes but neither one is listed in my 2007 Prius Manual. I am attaching a listing of all of the P (Powertrain) codes listed for the 2007 Prius.
  3. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Did a Google search on P0111 and across a couple manufacturerers it comes up as a problem with intake air temperature sensor.
    Not too much luck on the P1800 code, but what I did find was a valve position switch circuit.
    Hope this helps.
  4. pvandrew
    pvandrew Junior Member
    Manhattan, Illinois
    The code P0111: Air Intake Air Temperature Sensor 1 CircuitRange Performance.
    The other code I have no clue.
    Pete
