Help choosing tire plus "maybe" wheels!!
Discussion in 'Gen 2 Prius Main Forum' started by alexilic, Jan 5, 2010.
What tire/wheel combination?
Poll closed Jan 19, 2010.
  1. New all seasons on stock wheels
    3 vote(s)
    33.3%
  2. New 15" wheels and snow tires
    3 vote(s)
    33.3%
  3. New snows on stock wheels. Buy new 17" wheels & tires for non winter
    0 vote(s)
    0.0%
  4. Nokian WR G2s
    3 vote(s)
    33.3%
  1. alexilic
    alexilic Member
    120
    Wauconda, IL
    I have 50k+ on my original tires on my '07 Touring. I need tires asap!! Living in the northern Illinois, we get a decent amount of snow. I've been researching tires for the past week and need help choosing!! Here are my options..
    1) Put new all season tires and deal with the snow. This is the most economical. The tires would be good for the first winter, but by the 2nd and possible 3rd, I would regret not getting snows.
    2) Purchase 15" wheels and snow tires from TireRack.com for less then $600 installed, balanced and delivered!! Sounds great, but I keep holding back as I think 15"s would look not as good(sorry standard owners :) I like my car to look good, but $$$ is a big factor
    3) Put snow tires on my current Touring rims for around $500. Then come springtime, purchase new 17" rims and tires :)))))) Big smile factor, but the $$$ add up!! I really do want 17"s, but the crapy roads in/around Chicago would beat them/me up!
    4) Install the famously good Nokian WR G2s. However, $798.23 installed seems too much.
    Yes, I know, I pretty much answered my own question, but I need to hear from othersk :)
  2. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    I'd get the hankook ones that everyone seems to be raving about (they scored very high in the recent consumer reports article thats been floating around here). They're rated very good for snow, and they're cheap, they're also all-season tires. Not sure if they come in 17 inches though.
    If they don't come in 17 inches, i'd probably go for really cheap 15 inch wheels that look decent... and get snow tires with it. No ones going to be looking at your car when they're trying to stay on the road without snow tires. Besides, all that road salt will make your "cool looking" 17 wheels look like encrusted salt speckled wheels in no time.
  3. 2Txns
    2Txns New Member
    Goodyear, AZ
    I would see if you can find another set of the factory rims (2 each) and mount the new snows on them. That way you can have a pair of snows in the front for winter and a pair of all season's when you swap them back.
  4. Bob64
    1,540
    93
    Virginia
    I don't think mixing and matching tires are a good idea, could make the vehicle more unpredictable to control... woudn't want to fishtail on snow.
  5. alexilic
    alexilic Member
    120
    Wauconda, IL
    @Bob64. If I did go with the Hankooks, they would be 16"s as the factory rims are 16". Hence the reason for holding back on getting 15"s for winter. And I agree, getting 2 snows would not be good. I've tried that on previous cars, and going down hill on snowy/icey conditions, braking with good snow tires on the front, the back end wanted to keep going and made for some :eek: moments!!
  6. jdenenberg
    jdenenberg EE Professor
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have used four different tires on my 2004 Prius (166k miles). The Nokian WRs were great but a little noisy. The WRg2s now on my car are just as good (slightly less traction in snow, just as good on ice/wet) and are quiet. Both achieve noticeably better MPG and ride quality than the OE Integrity tires.
    The Nokian WRs cost me just over $400 (2.5 years ago) and the WRg2s cost me about $500 9 months ago including installation. Both were 185/65HR15s. Either you are being over charged or the larger touring rims are not worth having.
    JeffD
  7. alexilic
    alexilic Member
    120
    Wauconda, IL
    Jeff, the 16" are more per tire. About $160-180 a tire. There is always a compromise with form vs. function. 15" would be less $$ wise, but I also value form. In my opinion, the 16" make the car look better. The per mile difference is so small. I actually love the way they look with 17"s on, but my common sense pushes me away from them mostly due to the extra costs involved and Chicago and area are notoriously bad with our road conditions. Hence why we only have 2 driving seasons.. winter then construction :censored: The other reason for wanting a separate set of winters is the fact that I can run my summer tires till they are almost bald. If I only use all season tires, and the tread is getting down towards the ends, I would have to change them before winter. Example, the tires on the car now have maybe another 5k left on them. I would have to change them now, if I got snows, I can leave them on, put them on in the springtime and drive them till I get full use out of them. I drive myself crazy with all the analyzing!!! :der:
    BTW, the price has steadily increased as the dollar has fallen!! If you can get that price now, that would be great!!
  8. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    In the Consumer Reports November 2009 issue tire tests, the all-season Hankook Optimo H727 scored higher than the Nokian WR g2 on snow and ice (and performed as well or better on snow and ice than most of the snow tires tested), and costs about 40% less than the Nokians.
    Note that the Hankooks do not come in the Touring's OEM 195/55R16 size (most of the tires made in that size are run-flats).
    But they do come in the next closest size of 205/55R16 which a lot of Touring owners opt for because of the much greater variety of tires available in that size.
    Unfortunately, you might have some trouble finding the Hankooks in the 205/55R16 tire size right now because:
    (1) it's a fairly new tire,
    (2) Consumer Reports' recommendation and ratings of the tire (second highest rated passenger all-season with S & T speed ratings, and highest rated performance in snow and ice of all all-season tires), and
    (3) it's winter (highest rated performance in snow and ice of all all-season tires).
    Gripston.com, which normally sells the Hankook in the 205/55R16 size for around $90-$95 with free shipping and no tax, is currently out of stock in that size.
    TireRack.com sells it for $103 plus shipping but no tax, however its current stock in that size is limited.
    But maybe you can find it at a Sears store or elsewhere for a reasonable price.
    In any event, check out the Consumer Reports November 2009 tire tests -- they're the most recent and comprehensive tire tests out there right now:
    [​IMG] Consumer_Reports_Nov._2009_Tire_Tests-1.doc
  9. alexilic
    alexilic Member
    120
    Wauconda, IL
    @Boo.. yes, I agree. That is while they are new. Once you start to get at 50% of tread life and lower, the snow/ice traction suffers considerably. And as stated above, I would have to change them prematurely due to going into the winter season.
  10. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    I think that one strong factor in deciding on your strategy is how long / how many more miles you expect to keep the car.
    I have an 09 Touring with about 5,000 miles. For me, new rims and dedicated snow tires make perfect sense. If I struggle through winter with the OEM's, it just means they'll wear out sooner. If I alternate with dedicated snow tires, generally, I'll get twice the miles from the OEM's.
    After looking at reviews + scarcity of the best rated tires, I opted for Michelin X-ice tires and am very, very impressed by their performance. It's actually hard to get the traction control or abs to come on.
    I drove the car on a parking lot with ~ 1 inch snow cover first with the OEM's, and did sharp turns, panic stops, etc. to see how they were. Later that day, I was back with the new Michelins, and the difference was night and day.
    So, my vote isn't to necessarily buy Michelins, but to buy dedicated snow tires and wheels. I bought 15" OEM wheels -- partly due to price and availability, and part because that has been said to be a better winter combination than 16" ers. Someone else would have to comment on this.
    As for 15" vs 16" vs 17", I guess I'm a throwback. I like the Touring, but don't myself see much difference in appearance between the 16" and 15" ...
    As to Consumer Reports, the Hankook recommendation is in a category designated as " These tires offer high levels of performance in most key categories including dry and wet grip, hydroplaning resistance, handling, and at least average or better grip on snow and ice." The way I read their recommendation is that the fully red circle is determined vs other tires in that category. I don't read it as saying they'd still get a full red circle if compared to dedicated snow tires.
    CR said: "Best for severe winter performance: These tires offer high levels of grip on snow and ice," and then rated the Michelin X-Ice first in category. I don't think they included any all seasons in that test group, which suggests to me that none of them can match good quality dedicated snows.
    I'm pretty familiar with the second listed tire in the all season category -- the Goodyear Assurance TripleTred. We chose those for a car and van of two family members (I'm the guy in the family who could afford to buy them tires...). They can get away without dedicated snows. Report from them on the tires is they're far better than whatever tire they were running before, but also said that ice and snow performance is very good but not great.
  11. 2Txns
    2Txns New Member
    Goodyear, AZ
    I would agree with you except for 2 small things - VSC & TC. The car should not get in to that type of situation with those features.
  12. alexilic
    alexilic Member
    120
    Wauconda, IL
    @ 2Txns.. Ha, you ever heard of the guy that bought his first car with ABS? He lived in the mountains and was so excited that his brakes would not lock up and give him full control that he wanted to show his friend how good the system worked. He started blazing down the side of the mountain and when the first turn approached, he waited to brake till the last second. He slammed on the brakes the ABS kicked in but the car was going to fast to turn and he went straight off the mountain!!!! His brakes never locked up tho.. LOL!!!!
    VSC & TC are great, but can't break the laws of physics. I've had my Prius start going sideways on icy down hills. Maybe you should come to the north here and check it out!! It's supposed to snow up to 15" by tomorrow :)))))) I love it and my snow tire/wheels are on the UPS truck and should be at my house in the next couple of hours :))))
  13. alexilic
    alexilic Member
    120
    Wauconda, IL
    Re: Help choosing tire plus "maybe" wheels!! I got'em!!
    I got my snow tires!! I ended up going with 15" rims, and general altimax snow tires.. all for under $600 delivered to my door :) Here are a couple of pics...
    Couple of observations. First, not enough snow on the roads, but the little I did find, the tires had great traction. Second, the "feel" is looser. Maybe it's the higher profile of the 15"s over the my tourings stock 16"s?? Could be the narrower width? It's not enough to make a difference on my daily drive, but when the winds pick up or I hit the on/off ramps hot, I notice they wander more?
  14. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    On my Touring's oem tires, I had a problem with wandering (which I found often corresponded to the presence of rain grooves), and found that the problem pretty much went away when I raised tire pressures from stock levels. So far, I'm not noticing it with my snows. By the way, your car looks great.
  15. alexilic
    alexilic Member
    120
    Wauconda, IL
    @Aegison: Thanks!! I do keep my pressure up.. on my stock tires and wheels, I was at 50/48 psi and on my snows, I'm at 44/42 psi. One thing I noticed about the stocks, they have over 50k and the wear is very even!! I think I'll get 5k more out of them. And no, I don't drive "like gramma".. far from it!!!
