Side marker lights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by DeanFL, Jun 16, 2009.
  1. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    I really wanted signal mirrors on my '10, but not so in the U.S.
    Checked out Pepboys for stuff and looked thru the lighting aisle. Found the perfect mod. LED side marker set. Amber lights, great size, $25.
    I put similar side lights (not LED though) on my Lexus RX; a relatively easy job. Toughest part is when that drill starts a hole in a perfectly good fender.... Will remove the front wheel well plastic cover to make sure of back fender clearance and wire route to connect to front signal.
    Plan to locate under the Hybrid emblem. Will upload pics when done.
  2. Tideland Prius
    16,540
    Areometer has a set for the Gen II. Granted, it's more than $25 but it's an OEM part and it's a four bulb LED set. No idea if the wiring will match the Gen III's wiring.
  3. Manksgloob
    Manksgloob Member
    243
    Are the side "hybrid" badges still aligned to holes in the panels (like in the gen II 2007-2009 models)? If so, and you don't mind removing those badges, you could attach your side signalers there and route the wiring through the existing holes.
  4. Jabber
    Jabber Chicagoland Prius Guy
    703
    215
    Chicago
    Make sure after drilling the holes that you use some type of paint to cover the bare metal. I'm sure you already knew that, but I thougt I would mention it in case someone else wanted to follow in your footsteps.
  5. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Do you realize the amber lights just above the headlights server as your side marker lights? Turn your headlights on after dark and walk to the side of the car and see. They're quite bright.
  6. DeanFL
    1,015
    355
    Actually, side marker lights - actually mean -turn signals. ie only flash synchronous with the turn signals. Primary function, such as signal mirrors - to alert other drivers / pedestrians your intention to merge or turn.
    And Jeff - Prius rusts???? The hole required is about 1/4" and includes a rubber grommet to cover the hole and insulate the wire. Dab of silicone before the grommet is installed - should do.
  7. Jabber
    703
    215
    Chicago
    Yeah, that should do the trick Dean.
  8. Tideland Prius
    16,540
    Depends if the HYBRID emblems are attached with one or two holes and they're of the right size.
  9. paulemus
    paulemus New Member
    93
    San Diego
    Those Pep Boys LED's may not last too long. Better buy a backup replacement.
  10. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Looks like he "Hybrid" fender emblem requires two mount holes.
    Tideland Prius likes this.
  11. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    yep, & they are for whatever reason not symmetrical from left fender to right fender /
  12. Eugene Hong
    Eugene Hong Member
    114
    30
    Bay Area, CA
  13. StarCaller
    1,277
    729
    that's what I did/
    the stock bulbs are kind of dim, so I replaced them with some from vleds; pretty good visibility even in bright sunlight/
  14. Boston Jim
    Boston Jim Active Member
    202
    148
    Did this cut off the parking lights as well though?
    Below- I posted this a couple weeks ago, where IMeanGreen kept the parking lights, but also made them blink when the signal started.
    Do you know off hand if the wire coloring was the same in your 2014 as in the original post from 2010? Thanks.
  15. StarCaller
    1,277
    729
    the parking lights are ABOVE the main lights; they're not affected/
    if you mean the side marker, yep, they're off now. it just works like an additional signal light/
    the wire colors I don't know, I checked with a multimeter for 'juice' while the signal switch was on/
    the whole thing is very easy to do!
    Boston Jim likes this.
  16. Boston Jim
    202
    148
    Thanks @StarCaller,
    I did mean the marker lights not he parking lights.
