2001 hybrid battery-individual cell replacement
Discussion in 'Newbie Forum' started by rebecca72882, Jan 9, 2010.
  1. rebecca72882
    rebecca72882 New Member
    Atlanta, Ga
    2001 Prius
    Help! Does anyone know of a mechanic in the Atlanta, GA area who will replace an individual cell in the hybrid battery on a 2001 prius. The dealership wants to replace the entire battery for $3,000. Thanks!
  2. Flying White Dutchman
    4,374
    313
    do not replace cells
    try to get a second hand 2004 and up battery from ebay or alike.
    replacing 1 or 2 cells wil only get you into trouble in the future
  3. tochatihu
    tochatihu Senior Member
    9,045
    3,528
    Kunming Yunnan China
    2001 Prius
    Replacing one or few modules may leave you with a battery that is poorly balanced, and that is bad for longevity. At least the rebuild should be with well-ballanced modules.
    FWD suggests using modules from the newer model Prius. Those are better, but the newer battery assembly is not directly compatible for you.
    There is at least one battery rebuilding business. Give us some time and someone will report where ti is. Meanwhile you could contact Toyata Customer Experience and see if they are having a great day. If so they might offer to help you with the cost of new. Hey it's worth a try.
  4. fuzzy1
    10,159
    No direct experience, but ...
    I seem to remember others pointing out that the G1 battery has more cells than G2 (2004-2009), so a direct swap is impossible. One needs to buy two used G2 battery packs, and select the best cells to swap into the G1 pack.
    Considering that OP's battery is already bad, swapping a few cells and possibly having some future problems is still an improvement over the current situation. The tradeoff will depend on OP's plans for this car.
  5. tochatihu
    9,045
    3,528
    2001 Prius
  6. Flying White Dutchman
    4,374
    313
    i am sorry always forget that
    you need 2 gen2 or gen 3 ( if i am correct the gen3 got the same shape and size of the gen 2 cells ) battery packs because the gen1 got more modules and so a higher voltage.
    you only swap the cells not the housing and the cells have the same size en shape.
  7. rebecca72882
    Atlanta, Ga
    2001 Prius
    Thanks for all the advice!
  8. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
  9. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Also the GEN2 cells are taller thus they won't fit in the GEN1's battery case correctly. I suggest getting a complete reconditioned battery pack from re-involt with GEN2 cells already in it, and the top of case is already properly modified. Don't forget to send in your old GEN1 pack as a core charge then the cost is $400 cheaper. With the new pack you will have more EV only time and it'll last longer than the original one did. They also don't have the "leakage" problems the older GEN1 cells had. The car will be better than new in operation. Either way, Best of Luck with it.
    Meg&Bear likes this.
