Better speed measurement
Discussion in 'Gen 2 Prius Technical Discussion' started by kkayser, Jan 12, 2010.
  1. kkayser
    kkayser Junior Member
    49
    Does someone know a way I can determine if my '04 is accelerating or decelerating? This would be while I am coasting. It is easy with an analog speedometer, by just looking at the direction of needle movement. The digital speedometer is not sensitive enough. I do not need more accuracy; I need something that will tell me if my speed is increasing or decreasing by 0.1 mph or less.
  2. CharlesJ
    CharlesJ Member
    467
    29
    Monterey
    I don't have an answer for such capability but you are implying that you can tell such small changes 0.1 mph or less, on an analog speedometer? WOW.
  3. kkayser
    49
    It is not difficult; I just need to see the needle move in one direction or the other. I observe the position of the needle with respect to the position of the speed markings on the dial. Depending on the speedo, it might be .2, .3 MPH, whatever, but more sensitive than a digital.
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    There is the SPD signal (D-19) on the Hybrid ECU.
    You can measure its frequency using $10 digital multimeter with frequency measuring capability.
    The frequency at 60 km/h (37.3 mph) is 42.47 Hz.
    The ECU connector picture for RHD(JP) Prius is shown below.
    Maybe, the connector positions are upside down on the LHD(US) Prius. :)
    Ken@Japan
  5. kkayser
    49
    thanks you very much!:cheer2:
    I do have a multimeter which measures frequency. How can I access that point?
  6. Doc Willie
    1,717
    144
    Out there, somewhere
    I believe there are some ScanGuage X-guage settings that read some of teh accelerometers in the Prius.
  7. Patrick Wong
    18,210
    6,517
    Find the hybrid vehicle ECU which is behind the glove box. Then find pin 19 as cited by Ken. The wire should be violet.
    Splice into that wire and measure from that point to ground, using your frequency meter.
  8. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
  9. Oddest_raindrop
    Oddest_raindrop New Member
    75
    wisconsin
    well It's hard to believe that one could tell tenths of a mile per hour with an analog. But if someone must you could get a scangauge for which there is an x gauge that will update the mph very frequently with tenths of a mph. This passive gauge would work.
    GAUGE TXD RXF RXD MTH NAM Notes
    Miles per Hour 00BC 010042B40000 380C 08D80E930000 mph xx.xx mph
