2010 prius towing?
Discussion in 'Gen 3 Prius Main Forum' started by poodlemaster187, Apr 20, 2009.
  1. poodlemaster187
    poodlemaster187 New Member
    harrisburg, pa
    People have reported having no issues towing up to 1000lbs with no issues with current G2 prius. The 2010 prius has 2 more horsepower than corolla and corolla is rated at towing 1500lbs. The new prius in power mode should definitely not have any problems of course with no backseat passengers towing 1000-1500lbs. And, yes i know the cvt may not be able to handle it but i find that doubtful as other cvt's out there are able to tow. I would just like to tow a 1000lb jet ski and 200lb trailer, and don't want to step down from my current prius to a corolla. Any thoughts? Oh, and I'm well aware that toyota won't be giving the prius a towing capacity.
  2. patsparks
    10,664
    567
    Adelaide South Australia
    Check local law, in Australia it is illegal to tow any weight trailer with a Prius.
    Manufacturers rated towing capacity braked or unbraked = 0kg
  3. qbee42
    3,080
    You do realize that the Prius doesn't have a CVT in any conventional sense of the word, so stating that other cars with CVTs can tow is meaningless.
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Folks in the past have towed small utility trailers w/ the Prius. I'd be concerned more about stopping power and braking ability, but Motor/Generator "temps" should be monitored via Scangauge if extended hill climbing is expected.
  5. paulemus
    paulemus New Member
    93
    San Diego
    I don't understand why people want to defeat the aerodynamic drag coefficient with add ons like racks and trailers. I go camping, but want all my gear packed in a slip stream capsule for the trip down the highway.
  6. qbee42
    3,080
    The answer is simple: not everything will fit inside of a Prius. For example, it's pretty hard to fit a 17' canoe inside. I suppose you could cut it into pieces, or perhaps compact it into a block, but that might hurt the utility of it just a tiny bit, and certainly make it harder to paddle.
    Robert Holt and J5A like this.
  7. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    If it was possible to fit a Jetski in the back of an enclosed Prius your post would have made more sense. :)
  8. Much More Better
    Much More Better Active Member
    655
    163
    I actually LOL'ed. Thanks Tom :)
  9. bwilson4web
    16,369
    Agreed, especially with rear drum brakes like the NHW11 and NHW20s. The ZVW30 are much improved.
    If my vehicle display is limited, I would monitor the traction battery temperature before MG2 temperature. The traction battery can be 'heat pumped' to higher temperatures from the exothermic charging on the downgrades. For sure, use "B" at every opportunity when descending. When towing, the goal should be on reducing stress on the Prius by using lower speeds and "B" on the downgrades.
  10. Much More Better
    655
    163
    Are you serious? How much difference will a bike rack make? (shakes head) It's not on permanently anyway. How else do you travel with two mountain bikes?
  11. qbee42
    3,080
    It will make a huge difference, depending on the type of rack. The Prius has very good aerodynamics, unlike most cars. Sticking anything into the airflow will have a noticeable effect.
    As for not being on permanently, that is the key. It's all about priorities. If you want to go biking, you have to carry bicycles.
  12. garygid
    garygid Senior Member - Blizzard Pearl
    379
    Orange County, CA
    Assuming that one needs to tow something, how and where does one get and mount a good tow hitch?
    Thanks
  13. qbee42
    3,080
    Curt hitch is generally considered the best for the Prius. Mounting it is simple if you can use hand tools.
  14. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Keep in mind a trailer will add more rolling resistance from tires and aerodynamic drag. So, if you have 500 lb trailer/load and 325lb occupants, it's effectively more than the 825 payload limit of the car.
    I'm sure the new Prius would be pretty bad at towing 1,200 lbs.
  15. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    I think the GVWR is for what you put IN the car, so as not to exceed the axle ratings or the ability of the brakes to stop the car.
  16. bcy475
    bcy475 Junior Member
    Vermont
    Is one better off towing a trailer(400lbs) and putting most of the stuff one would take IN the Prius in the trailer instead?
    I load the Prius up to the top usually for a trip to PA and last year was just off balance enough that the gas guage was off by 2-3 bars. This year not need as much but still a bunch as left most there in a storage unit.
  17. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    HowStuffWorks "How Gross Vehicle Weight Rating (GVWR) Works" discusses GVWR. It's also important as it relates to how heavily loaded the tires are.
  18. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    I've towed a 560 pound teardrop size trailer behind a 2006. The mileage was about 32 mpg instead of the more usual 47. It all worked, but the legal speed limit is 55 with a trailer here in California. If it's all equipment that fits inside the car, then that would probably be better than towing the trailer. Another option would be a roof rack, although that has got to make a similar impact on mileage and wind sensitivity.
  19. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    ... or you could buy or rent a different vehicle if you want to tow something.:eek:
  20. frayz
    frayz Junior Member
    33
    Mobile, Al
    Hmm. Ok It seems everyone here is against this idea complete. I am a very avid prius owner. I plan on buying another prius in the next year or so for the wife. so she doesn't have to drive our other vehicle(07 dodge ram v8).
    I just purchased a curt hitch for my 08 prius after much reading. i have a <200lb jet ski trailer and a 400-500lb motorcycle I plan on hauling with it. I think it should be similar as to driving the car with 4-5 grown people in it(avg 150-200lb each) aside from the added wind drag.
    This all being said. I've seen people in the past pull small trailers and I would just like to save a little bit more money on long road trips getting 30-40mpg instead of 17-20mpg in my truck.
