oil change and tire rotation
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by joeuser, Jan 7, 2010.
  1. joeuser
    joeuser Prius Junkie
    78
    NYC
    I need to get my 10000 mile rotation and oil change performed pretty soon. I live in the Queens area of New York City and commute to work to Long Island. Unfortunately I didn't purchase my vehicle from the city (E Rochester) so I cant go to the dealership.
    What are some good places to get this service done without being ripped off.
    There's a JiffyLube around, should I give them a try? Also, I'd prefer to load it with some Mobil 1 0W-30 instead of the Toyota 5W-30 that was put in in my last oil change (was included as a free oil change).
    Any ideas/suggestions/tips?
    Joe
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  3. joeuser
    78
    NYC
    I have a another question.
    Last time I had my service done (oil & filter change, at westbury toyota), I requested the tech to add exactly 3.5 quarts.
    They had a problem with that saying that they need to fill it to 3.8 quarts. I tried convincing them but they started telling me that this is what the spec says and we're going to do it just what the specs say. So I went along with it considering that i was already waiting for 20 minutes.
    So is this a proven thing that 3.5 quarts is just the right amount of oil for the model I own (2009 prius)?
  4. Patrick Wong
    18,210
    6,517
    You have two sources of information to consider:
    1. Oil level as measured with the engine oil dipstick
    2. The Toyota repair manual that says to add 3.9 US quarts when doing an oil change with a new oil filter
    If you think the engine dipstick should govern, then you will add ~3.7 US quarts to reach the full mark.
    If you think the repair manual should govern, then you will add 3.9 US quarts and not worry that the oil level is above the top dimple on the dipstick
    If you think the engine will realize better mpg with a slightly lower oil level, then you will use 3.5 US quarts.
    You decide which is best for your car and your situation. Good luck.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Since you said you want to use Mobil 1, one strategy suggested by one of the members here is to bring in 3 quarts to be added by the dealer and tell them that you will fill in the rest yourself. Good luck!
  6. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    My 07 Prius was over full by the dip stick with about 3.7 qts, I also noticed a drop in fuel economy afterward. I changed the oil myself and was shooting for 3.7 qt. I sold the car butif i still had it i would go for 3.5 qts.
  7. richard schumacher
    7,683
    1,065
    United States
    I take the give-them-3-quarts approach. That way I also know what kind of oil is going in. In five years adding 3 exactly has always left the level halfway up on the dipstick, which should be perfect.
    Dealer service may be less of a crapshoot than the QuickyLoob places. At least a dealer has no valid excuses about not knowing how to drive the car, and should be more likely to notice otehr problems. But everyone can make a mistake, so no matter who does it, always check the oil level yourself before you drive away from an oil change.
    Finally, you don't actually have to rotate the tires, so paying someone to do it is a waste of money. Rotate, and buy four tires at a time less often; don't rotate, and buy two at a time more often.
  8. joeuser
    78
    NYC
    I took a 5 quart container of mobil 1 0w-30 to the service center and told them to take only 3.5 from it. They seem to have taken the right amount however my economy just dipped like crazy. My previous to tanks averaged 49 and 47 (this is more recent, probly due to cold weather).
    i just fueled up after the oil change and around having driven 28 miles only my oil gauge dropped a pip already. It has never dropped so early. In the summer i remember having gone for 160 miles before the first pip dropped. and recently, I've been able to eek out 50-70 miles before dropping a pip. But this first pip at 28 miles is really freaking me out. Any advice where to start looking. My driving habits are pretty much the same as they used to be between summer and winter (only thing changed is that the FE has gone down from about 55 to 47~49 due to heating in the car.
  9. richard schumacher
    7,683
    1,065
    United States
    In the immortal words of Douglas Adams, Don't Panic. Simple things first:
    Check the oil level. You should always do this before driving away from every oil change.
    Check the tire pressures. Do this with the tires "cold", that is, the car has not been driven more than one mile in the previous hour. The factory setting of 32 PSI is a compromise for comfort. You can get noticeably better MPGs with 42/40 front/rear. Techs love to re-set tires to the factory values, and during winter if the car sat for hours in a warm shop they can take too much out.
    If these are normal then the car may have been sitting ON and burning gas for some time while in the shop. See what it does on the next tank.
  10. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    joeuser,
    I wouldn't be so worried right now. I think what Richard just said about being ON in the shop has no bearing (because you said you fueled up AFTER the shop visit & that's when you got your one pip drop in only 28 miles), but his tips about the oil level & the tire pressures are great. Your earlier fuel economy (55 MPG---undoubtedly in the summer) & more recently (47-49 MPG) are exactly what should be expected in your climate area with the original Goodyear Integrity tires [close to what I used to get here in CT (48-52 summer/42-45 winter in mixed driving & 54-56 on long trips) until I replaced my original tires with another brand & took about a 4-5 MPG hit].
    You've got to consider that you're in your first winter with your car & your '09 still has the rubber bladder inside the fuel tank (present in all '04 thru '09's, but now gone from the 2010 models). In the cold temperatures that we're presently experiencing your car's bladder gets very stiff & will not fully expand inside the tank walls preventing you from filling your gas tank as much in the winter as you fit into it in the summer. Therefore, it's normal to have the first pip disappear in far fewer miles in the winter. In the summer I often get from 150-180 miles before the 1st pip goes out, but in the winter maybe only 50-60 miles [& I'm only getting about 33 MPG average now with short trips & this cold snap we're in (by Thurs & Fri with temps finally getting into the 40's, I expect that to improve some)]. Don't worry.
    Ken (in Bolton,Ct)
  11. joeuser
    78
    NYC
    Yeah both of you have been spot on with your diagnosis where one left off. I have seen the economy get back up to 47.? so far.
    So the don't panic also applies.
    Now I need to call the service shop because the ended up misplacing the air valve cap from one of my tyres.
    J
  12. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    Hi folks,it's been a while since i've posted,[last June to be precise]hope those of you who got your 2010 Prius are motoring well.
    Just went through 270,000km in my 06 Prius Taxi......and no...no probs!
    Something came to my attention this afternoon in relation to oil changes.
    I started servicing my car this time last year and used 5w/30 oil as recommended in the manual and here on PC but as i was getting prices from my local Toyota dealer [who serviced my car from August 2006 until December 2008]he asked if i wanted a price for oil...5 litres of 10w/40!!....and my reply was "you mean 5w/30,the recommended oil"
    So it appears that for the 2.5 years that they were servicing my car they were using 10w/40....and my question is...could this have caused any damage yet to come to the fore?
  13. richard schumacher
    7,683
    1,065
    United States
    It reduced fuel economy, and maybe caused some extra engine wear when starting much below 0'C.
    Buy four litres of 5W-30 and give *three* of them to the servicer to use. Tell them you will check the oil level yourself before driving away, and then do it. Anywhere between the top and bottom dots on the dipstick is fine; in no case should the level be above the top dot. In 68 months and 41000 miles three US quarts has always been enough for mine.
  14. KCobby
    KCobby Member
    229
    74
    NYC area
    Hey Joeuser-
    Where did you end up taking your car? I am also in need of getting the tires done and the oil changed. I have a local place that I don't mind using, but just wondering if you found a place you liked. I'm in the Bronx where sometimes people are a little... :spy:
    :thumb:
  15. joeuser
    78
    NYC
    so i got a calculated mpg of 42 where my MFD showed 48.5 MPG. I dont know what happened but I can bet this is due to the cold weather and not really certain how one pip disappeared after 28 miles of driving.
    I've refueled about 8 gallons on my last refill. I've driven about 135 miles after refueling. The first pip dropped after 94 miles of driving and I didn't realize when the 2nd pip dropped but i'll keep a close tab on this. So apparently it seems like things are looking good now but I'm trying to explain how i only averaged 42 when the MFD is showing 48.5.
    The tank bladder expanded due to the temperature improving?
    More gas utilization because of extremely cold temps?
    Any ideas?
    And the avg has also gone up since the refueling. I'm at 49.5 MPG now.
  16. richard schumacher
    7,683
    1,065
    United States
    Summarizing twelve thousand posts on the subject: the amount of fuel you put in at the last fillup does not necessarily equal the amount of fuel you burned since the previous fillup, therefore the MPGs calculated over a single tankfull are not reliable. The MFD value is always close to the actual MPGs because it is calculated in real time by counting the well-calibrated actuations of the fuel injectors.
  17. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    There's a reason it's called a "Guess Gauge". The difference between MFD & calculated ranges from 0% to 20%. Situation normal. If you alternate between high & low tanks, in reality you have 2 average tanks. Don't get too bummed on a low tank, nor too ecstatic on a high one.
  18. joeuser
    78
    NYC
    Alright, I downed my 2nd tank post the oil change and the estimate of driven miles is about 54.5MPG (single tank) while the MFD shows 50 on a combine average from the two tanks.
    Things looking good. I will blame cold @ss temps to the low MPG.
