Energy Monitor Burning in !!!???
Discussion in 'Gen 3 Prius Main Forum' started by patandrich, Sep 27, 2009.
  1. patandrich
    patandrich Blizard Pearl... So spectacula
    Saylorsburg, PA
    I have a 2010 Gen III PRius, i was wondering if anyone had the same problem as i do when it comes to the energy monitor...
    I have had the car for about 2 months, it has 7000 miles on it (bought it with 12!).. I have started to notice the whole car energy screen has been burnt in. WHen i go to the graphs, i can see the windows and other parts of the car... Is anyone else having this problem??
  2. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Yep, I know exactly what your taking about. I normally keep my screen on the HSI - and in the other windows likes the 5 minute/1 minute consumption I can sometimes see the "eco" light still "on" the window if you see what I mean.. I guess we should switch every now and then to keep the burning in from occurring but, this is still really a pitty.
  3. patandrich
    Saylorsburg, PA
    Well the only thing is I keep my car on eco-mode, the go-no-go graph comes up, but i have a little habbit of looking at the car, do you think i should complain to the dealer.. I have a feeling i will get no where... like usual with dealers!:confused:
  4. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    patandrich, see the other thread on the subject: http://priuschat.com/forums/gen-iii...64058-anyone-else-notice-any-screen-burn.html
    HTMLSpinnr has noticed that the effect "seems to subside after 20-30 minutes". Do you observe the same?
  5. patandrich
    Saylorsburg, PA
    As far as the efects going away, that does not happen in mine, i even see the "car" when i start the prius and "welcome to prius" comes up, at first they did subside, but know they are officialy burnt!
  6. CivicQc
    233
    99
    Planet Carbon
    Ok - thanks for adding this. If we can find another member who has noticed it, I'll add it to the list of reported problems.
  7. LulzChicken
    791
    135
    Alabama
    I'm really not sure - as mine is not as bad as your seems to be. I would go drive to the dealer - what do you have to lose? I understand your frustration with no success from working out issues with dealers but, this isn't just a little issue - the screen is an important part of the car - you'll spend a great amount of time looking at it! It should work right and not be burnt with another image. Let me know how it goes - good luck!:cheer2:
  8. LeadingEdgeBoomer
    289
    29
    New Mexico
    Hmmmm, this is not old CRT technology when burn-in was a real deal--that's why screen savers were invented, to move stuff around when the screen was idle. They are completely irrelevant now. I wonder if this phenom is possible in current Prius dash display technology. I am speaking from ignorance here (always the best way to proceed ;->), since I don't even have my P yet. Is there something about the plastic cover that could be involved?
    Assuming it is real...then I would have designed the whole arrangement of displays with a few essential static elements (mph, etc) in the same place on every display; burn-in would not matter. I'd also provide a simple screen that displays little else.
    When I'm blasting through northern NM on I-25, it is too mind-numbing to watch an instantaneous MPG monitor. Neither are there enough antelope at play to be entertaining, nor are there even radio broadcasts that are reliable. Bring your iPod or some CDs. I hope to hear more whether others have observed this burn-in phenom.
  9. Tideland Prius
    16,684
    Mine has an ECO burn-in (given that I use HSI most of the time, that seems reasonable) but I was surprised that it was only visible in the consumption screen. The ECO burn-in wasn't visible in the SETTINGS screen (where it's mostly black).
  10. ceric
    ceric New Member
    1,114
    Fremont, CA
    LCD has so called "persistence" issue. It is not perminant. You can remove it by displaying all white image for a long time. However, this is difficult to perform on a MFD of Prius (easier for a computer's monitor). However, eventually the persistence will go away (unlike the plasma or CRT).
    High-end TFT LCD has a anti-burnin thin film built-in. I guess the one on Prius MFD isn't one of them.
  11. patandrich
    Saylorsburg, PA
    What i feel should be done is under the setting menu toyota should put a whiteout screen to try and rid the burn in... but we will see. the display i like alot better on this gen than the last one. but it still needs some improvments Thanks for the comments:)
  12. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I've also noticed this and was going to search this topic and just found this on the active thread list. My has burned in as well with only 4k miles. This is really unacceptable on a 2010 car. Love the car but disappointed in stuff like this.
  13. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    I was pointed to this thread after posting the same question. Has anyone tried to get this addressed through the warranty?
  14. patandrich
    Saylorsburg, PA
    Actually this week i am going to the dealer i got the car from and going to inquire about this and the new DVD map disc, SPending almost 30,000 on a car and things like this happening better be under warrenty.. Toyota / Prius are great products, but this must have been seldom thought of! I will keep everyone posted on the warrenty issue
  15. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    We're talking about the 2010 car's general-purpose Multi-Information Display in the dash, right? On which the Hybrid System Indicator is displayed?
    The display is a Vacuum Fluorescent Display type. These do suffer from fade with usage - the phosphors just get less bright. On my PVR at home, when you change channel, the channel name scrolls across several character positions, only some of which are used to display the time (and therefore always in use). The characters used to display the time are noticeably dimmer than the rest. I'm astonished that this would be happening on displays this new, though.
    Reading the other thread, it appears that HTMLSpinner's experience was that the phosphors continued to glow after the elements were switched off, or were brighter than surrounding pixels that should be the same intensity. That would suggest that maybe the brightness is too high.
  16. Omni-TaG
    Omni-TaG New Member
    37
    I
    Hi Patandrich
    This phenomenon you describe is totally normal "ghosts images" are remaining from one graphic-sketch to another. It's intrinsect to the display technology used here. I have the same display-technology on my 1985 audio-video amplifier and this one display is still working very well 24 years later. Nothing to worry about...
  17. CivicQc
    233
    99
    Planet Carbon
  18. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    The MID is not a LCD technology, it is fluorescent display, so burn-in is possible, but not in short time or low millage.
  19. Rhino
    Rhino New Member
    460
    U.S.A.
    Could you clarify this part of the sentence for me so I can learn.
    You mean after a while the burn in will go away?
    Or do you mean after long use, everything will be burned in equally so it will not be so noticeable? Sort of like a numeric display where you can see all the elements clearly even when they are not lit up? Like you can see 888888888 on a cheap calculator even when it is turned off.
    Or you mean something else?
  20. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    The message edited, not was missing :).
