Bad Gas Mileage (Intentional)
Discussion in 'Gen 3 Prius Fuel Economy' started by mainlin, Jan 25, 2010.
  1. mainlin
    mainlin Junior Member
    25
    Lower Marion, PA
    I was trying to see how low the gas mileage could go, so I kept the car (Gen. 3) in 'B' and 'Power', and drove up and down hills as fast as I could go without being stoped by the police. Started out @ 20 m.p.g. as expected after a few minutes, then it got up to 30 m.p.g. after about 15 min. After about 25 min, it got up to 35 m.p.g. I figured I must be slowing down, so I pushed the car harder, especially on the steep upgrades, and got the averge to drop to 30 m.p.g. again with much effort. When I returned to a more relaxed driving style, the m.p.g. returned to a more expected territory (40 m.p.g.) Very impressive!
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  3. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    It's very amazing how the attempts to get poor gas mileage, still result in higher numbers than most other vehicles. It really speaks volumes about how good the car really is!
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    the lowest i've seen is between 25 and 30... but you have to be towing something. once you stop towing, it jumps back up. (for me it jumps up to high 30's)
    the good thing is... it's really easy to tow someone. i've towed a vw bug about 15 miles on mountain road.. a 74 (not sure of exact year) corolla about 35miles (city then mountain road)...
    for tank, the lowest i've seen is 29mpg.. really cold outside, high speed transport with a lot of weight.. all freeway.
    (oh yeah.. towing burns oil... ) (duh?)
  5. TonyWilkey
    TonyWilkey Member
    99
    25
    Kansas
    RE:Bad Gas Mileage
    I don't get it. I must have a lemon. I am averaging 33mpg (calculated) I wonder if they used the indicator?
  6. Tom183
    Tom183 New Member
    652
    65
    Maine
    Well, cold temps cause a pretty substantial hit also - nobody really knows exactly why, maybe the inverter temp is too low for efficiency or something. It's more pronounced at higher speeds, so for your next "worst mileage" test, wait for below-zero temps and gun it all the way to 70mph.
  7. bwilson4web
    16,366
    A better technique:
    • stomp accelerator
    • at 30 mph, shift into "N" while accelerator held down, takes about 1 second
    • when acceleration stops, stomp brake so ABS engages
    • when stopped, engage a forward gear selection, "D" or "B"
    • repeat (if traction battery gets too low, just stomp brake at 30 mph)
    You should be able to achieve less than 15 MPG.
  8. F512M
    F512M Member
    415
    Laguna
    Re: Bad Gas Mileage
    Ha, ha, ha maybe you should complain to Toyota:p
  9. sumguy
    sumguy Junior Member
    93
    Ohio
    Mine is pretty bad right now too. 25-30mpg. Most trips are less than 5 miles at 35-45mph. Every week or 2, do 20-40mi trip. Temps have been mostly in the teens. Security at work warms everybody's car up, turns on defrosters, cleans off windows, etc.. I'm thinking the car is idling 10-20 min before I leave. Could this be why its so low?
  10. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    The more time the engine spends running without the vehicle moving, the more fuel is consumed over 0 distance, causing the fuel economy to drop.
    Short answer: yes.
