Got in an accident, where can i find these parts?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kbyrd, Jan 26, 2010.
  1. Kbyrd
    Kbyrd New Member
    VA
    So I have a 2010 prius and I hit a dog (this is not an ethical issue). surprisingly, its face did quite a lot of damage.
    I am able to fix it I just need to know somewhere i can get OEM parts other than the stealership. I need the passenger side wheel well liner and the windshield wiper fluid reservoir
    the dealership is charging me $100 each! :mad: i know the wheel well liner for one of my other cars was only $20
    Its been hard finding parts since nobody has 2010 spare parts..will any other years fit? Where can i get these parts?
    thanks
  2. Kbyrd
    Kbyrd New Member
    VA
    bump for help
  3. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    You could try car-part.com. I don't think there are too many 2010's in salvage yards across the US. You might get lucky.
    BTW look for a part like a hood, fender, door for example to see if they have a 2010 in the yard. A liner or washer reservoir probably will not come up on a 2010.
    If you get a hit on a 2010 then give them a call and see if they have the parts you need.
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Kbyrd, sorry to hear about your collision. Since you have part numbers try calling or e-mailing the dealers that sell parts over the internet. I don't know if your 2 parts carry over from the Gen2 but the two generations seem to have little in common. Good luck.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
  6. Kbyrd
    Kbyrd New Member
    VA
    Thanks for all your help..I found the parts on that auto parts link, but they only have parts for the 09..will the fender lining and washer reservoir fit in the 2010 model from an 09?
    thanks
  7. Kbyrd
    Kbyrd New Member
    VA
  8. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    Bumping a thread after less than an hour isn't going to make you get your answer faster.
  9. theprius
    theprius Junior Member
    34
    NY
    Hi all, i'm also looking for a wheel well liner for the 2010-2011 model. Some construction materials were on the road and my prius didn't clear them. Ripped the wheel well right off!
    Looking for a passenger side front wheel well liner. I'm in nyc and i'm willing to travel to find a yard that might have something I can pull off a car.
  10. JimN
    7,028
    1,116
    South Jersey
    My gut feeling is "I don't think so". Look up the part numbers for a 2009 & 2010.
