2007 Prius engine ticking noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aktam, Jun 27, 2007.
  1. aktam
    aktam New Member
    Hello,
    I'm noticing a ticking noise from the engine during normal acceleration proabably at around 25-35 mph. Wondering if this is normal. Thanks!
  2. qbee42
    3,076
    Are you sure it's engine noise and not the brake accumulator pump?
  3. aktam
    aktam New Member
    <div class='quotetop'>QUOTE(qbee42 @ Jun 27 2007, 07:58 PM) [snapback]469179[/snapback]</div>
    Yes, it's coming from the engine. It sounds like valves or the lifters making the noise.
  4. qbee42
    3,076
    <div class='quotetop'>QUOTE(aktam @ Jun 28 2007, 12:07 PM) [snapback]469443[/snapback]</div>
    Hmmm...hard to say when you are talking about noises. The Atkinson cycle engine on the Prius does make some funny noises, almost like a small diesel. Does it sound a bit like a diesel?
  5. aktam
    aktam New Member
    <div class='quotetop'>QUOTE(qbee42 @ Jun 28 2007, 11:41 AM) [snapback]469553[/snapback]</div>
    You're right...it does sound a little like a disel engine. So that's normal?
  6. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    All sorts of weird noises are normal. Don't sweat it unless it breaks down :D
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    My Prius never makes any sort of clatter or ticking noise, except idling and you have to open the hood to really listen for it. Even running 0W-20, the motor sounds happy at idle.
    The FJ makes more of a rattle at idle, apparently there is a check valve in the PWM purge valve. An easy fix for that is to unbolt the PWM valve and isolate it from the intake manifold. I did that with mine and the annoying ticking/tapping sound disappeared.
  8. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    In the last week or so I've noticed a distinct tick sound when the car is idling, which has been at the start of driving when it's too cold to stop the ICE at the light. It gets louder once I accelerate, but is lost in the road noise soon after.
    I googled a bit and manifold leaks are supposed to sound like that, but I'm not sure at what point I'll see some drop in power or MPGs as the sign the dealer should look at it. 63,500 or so as of this week.
    And while I did only notice it once the radio was accidentally left off, I doubt I missed it all this time just because I usually have the volume up rather high. Is there anything the might have been muffling the noise that might have worked its way loose?...
  9. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    any chance you've put premium gas in it?
  10. mikepaul
    1,763
    Columbia, SC
    <div class='quotetop'>QUOTE(galaxee @ Jul 3 2007, 11:39 PM) [snapback]472729[/snapback]</div>
    Not intentionally. Last fill-up was 87 from (I think) Texaco, and today was generic 87 from Racetrack.
    I did add some Lucas Oil gas additive well over two weeks ago, but I expect that to be long gone.
    I guess when something bad happens I'll be primed for it. Not today: 49.9MPG on the 16-mile drive back from getting gas after seeing "Transformers"...
  11. new2meprius
    new2meprius New Member
    I am a new owner of a 2007 Prius - 11,000 miles
    My question is, when the car is slowing down to stop or driving between 0 - 20 it frequently makes a noise that sounds like an egg timer. It has a ticking sound as if you were to reverse the knob on a timer. Does anyone know if this is normal. The dealership told me it was the generator kicking on, but I really don't recall having heard it before. Thanks.
  12. isalacki@earthlink.net
    [email protected] New Member
    NC
    I also have a 2007 Prius with about that mileage and having the same issue. I also hear it sometimes when I'm taking my foot off the brakes and start to accelerate. I plan on going to the dealer in the next few days to have it checked out. I also don't recall it happening in the past.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Yes as stated earlier thats the brake accumulator pump. Its providing vacuum for the master cyl/brakes. It comes on all the time.It gets louder as the car gets older too. You'll get used to it. Its normal.
  14. qbee42
    3,076
    It's the brake accumulator pump, which is an electric pump for the power brakes.
  15. edperera
    edperera New Member
    london, England
    Hi Mike Paul,
    Did you ever find out what the problem was with the ticking noise from your engine on acceleration. I ask because i have exactly this problem and the dealer cannot fix it. They've checked the tappets and replaced two of them, fixed an engine mount. But the noise is still there. Did you fix your problem?
    Thanks
    Ed Perera
    Mistah Ya likes this.
  16. Patrick Wong
    18,200
    6,493
    Hi Ed,
    Pls note that the Prius valvetrain does not include tappets. The camshaft contacts a solid valve lifter (which is produced in various thicknesses, this is how the valves are adjusted). The lifter rests on top of the valve spring retainer. The valve spring retainer is attached to the end of the valve.
    Did your dealer tech measure valve clearances on all of the 16 valves? If the clearances are all OK, maybe one of the valve guide bushings is a bit loose, allowing the valve to wobble slightly and make the sound you are hearing. Unfortunately there's no way to ascertain this without removing the cylinder head and disassembling the valvetrain.
    How many miles on your engine?
    What oil viscosity are you using?
    SteveLee likes this.
  17. edperera
    edperera New Member
    london, England
    Hi Patrick,
    Thanks very much for your quick response.
    You're completely right, the dealer tech said he checked the valve clearances on the 16 valves and two were out slightly which they adjusted.
    The car's covered 100,000 miles, with full dealer servicing and oil changes every 5k (Mobil 1 ESP 5/30 oil) in between Toyota servicing (which is every a service every 10k here in England, not the 5k you guys appear to have in the States).
    Fortunately i have a warranty that will cover all the costs, which i think is lucky, but i would have still preferred a simple fix!
    I hear what you're saying about the valve guide bushings and i will suggest this to the dealer and see what they say.
    Thanks again for your help.
    Ed Perera
  18. ejsasem
    ejsasem New Member
    Poughquag, New York
    My name is Eric and I also have a 2007 Prius making ticking noise . When its very cold-20-30 degrees, it makes a loud tapping noise like a bad lifter for about a minute or so. Then after it warms up, it still makes ticking noise at idle and is noisier than it used to be on acceleration. I took it to the dealer and they couldn't hear the initial tapping noise when its cold and say the engine sounds normal when driving.
    How did you get them to even check the valve clearance? Ive got the 100k mile Toyota warranty but my cars got 93k on it already.Ive changed the oil with GTX 5w30 and toyota filters every 4-5k miles since new. Anyone know of a good Dealer in NY area that will has good hearing? Newburgh Toyota certainly does't!
    Thanks, Eric
  19. Patrick Wong
    18,200
    6,493
    It's not clear to me whether valve adjustment would be included in the extended warranty, as that is a maintenance item (valve clearance is inspected based upon the presence or absence of excess valvetrain noise, at 60K mile intervals.)
    It will be pretty expensive to measure the valve clearance since the valve cover has to be removed. If any valve lifters need to be replaced, then that will be even more expensive as the camshafts have to be removed.
    Also note that upon initial startup of the cold engine, ignition timing is retarded for a short period of time. That might be part or all of the reason for the noise which goes away after a short while.
  20. kyrkbymannen
    kyrkbymannen Junior Member
    Uppsala
    Is there kinda of a guide with pictures or good text description anyware how this is done?
    My 2006 does some ticking noice too.. did since it was new.
