Back Up Camera on When Desired?
Discussion in 'Gen 2 Prius Technical Discussion' started by [email protected], Feb 1, 2010.
  1. harry@execpc.com
    [email protected] New Member
    Prince Edward Island, CA
    In browsing through the Toyota Shop Manual for our 2007 I noticed that the back up camera appears to be activated by battery voltage on Pin 8 of the Engine Room Relay Block (same as Pin 21 on the Multi-Display end of the cable). The inference is that if voltage is applied to that pin, the multi-display will switch to the camera screen.
    If so, a switch could be built to turn the camera on any time you wished to see behind you (get the license number of that #%#% tailgater, for example?:D).
    Has anyone explored this mod?
  2. Politburo
    Politburo Active Member
    971
    208
    There's a thread here that describes turning on the camera at will, using an MFD connector. I would presume that is the pin 21 you refer to.
  3. harry@execpc.com
    Found it! Actually, what I found was a link to Darrell's Electric Vehicle page, where the mod is described in well illustrated detail.
    Thanks for the info.
  4. Membrain
    Membrain Junior Member
    Anaheim Hills, CA
    can you show the link to that mod?
  5. harry@execpc.com
    I would like to post the URL, but I don't have high enough status on PriusChat to be allowed to do so. :( Here's the core of the link -- your browser should be able to complete it:
    evnut.com
    Click on "Prius Hybrid" on the left of the page, then on the next page click "mods" at the top of the page. This will give you a list of modifications. The "Anytime Camera View" is dated 04.02.06 and is almost half way down the page.
  6. DarrenG
    DarrenG Member
    138
    Hampshire, UK
    Here is the direct link.
