Severe Mileage Drop
Discussion in 'Gen 2 Prius Fuel Economy' started by txtabby, Feb 2, 2010.
  1. txtabby
    txtabby 2011 Prius 4
    139
    Austin, TX
    Well I looked over a couple of posts and found a connection to cold weather and mileage loss. But mine is ridiculous. I could go over 110 miles of city/hwy driving before the first square disappeared from the gas gauge after filling up. (FYI, when I gas up I lock the handle at the first notch then round off the nearest $.25 after it shuts off to be consistent)
    Now I can only go about 60 miles before it blinks out. But my 'AVG' display says 46, and I'm lucky if I can get it up to 48 again. And I have noticed I have more 'green bars' on the battery display. The tire press. is good... 42F/40R. Air filter looks good too. I am running the defroster, but the A/C is NOT on. And my oil level is good, tho a little high. It has been colder lately here (central Texas) but this is the first time I've noticed my mileage being this bad. It's out of warranty but I'll take it in the next time it's due service and ask them what's going on.
    Also, my parking brake 'chirping' is very noticeable now. Hopefully it's still in their records and they can do something about that as well.
    I'm doing a mileage test to see if there's something wrong with the gas gauge and will drive it 10 miles after the 'REFUEL ASAP' signal sounds and see how much it takes to fill up.
    Any comments on the mileage loss?
  2. PaulHS
    PaulHS Member
    200
    SE PA
    Cold weather is the major issue. Your other factors appear to be fine. You don't really say how low your temps are, but generally, cold weather will affect the rigidity of the bladder in the fuel tank, and decrease the amount of fuel that can be pumped into the tank. Do not try to judge mileage (or loss of mileage) by when the first pip disappears on the fuel gauge. If your "normal" mileage is 48mpg and now you're seeing 46mpg, that is not a severe mileage drop, and can be accounted for by the colder temps. The cold will also cause more green bars to be displayed.
    I'm not sure what the chirping parking brake is, but if the parking brake is misadjusted, it can reduce mileage as well.
  3. qbee42
    3,081
    If you want real help on an issue like this, fill out your profile so that we know where you drive, how long you have owned it, and information like that.
    What you describe sounds like normal winter operation: drop in mileage, more green bars, and reduced fuel tank capacity. This is all normal for a Gen II Prius.
  4. txtabby
    139
    Austin, TX
    We've had some pretty cold temps here. About a month ago is when this all started and the coldest it got was, at my house, 15F. Yes, 15 degrees! Set a record here. And didn't get much warmer than 32 for a few days. Then true to Texas, with in a week it was about 70! Then back down to the low 30's. Just seems odd that I could go for ever without using any gas, and now I feel like I'm driving my dad's old 1978 Buick station wagon, where you could actually SEE the gas gauge move!
    Maybe I should buy some 'quality' gas too, instead of the HEB supermarket fuel I normally buy. Valero okay, or should I move up to the 'Exxon/Chevron' level? I'm not going to buy Texaco... most expensive around. In Texas...go figure!
  5. Genoz World
    Genoz World ZEN-style living
    797
    22
    La Canada
    hey.........dont feel bad. I'm in the same situation and it's all weather related. Cold weather is really tabooooo with the prius and everyone is in the same boat.
    i can't get 100+ consistently, but on occasions, yes. now, i'm from 60-80 before the first pip goes away. if i'm not careful, i'm 170-180 as the FIFTH pip disappears. just practice a lot of P&G and drive frugally. I'm over that under certain situations and the mileage really drops!
    The way i look at it is when i want to, i can see awesome mileage once again.
  6. Membrain
    Membrain Junior Member
    Anaheim Hills, CA
    So i tried this technique and found that my battery after 1 year is as follows:
    Unload: 12.4V
    Load: 12.1-12.2V
    Charge/Start: 14.2 V
    I don't think my decrease in mpg is due to the battery or weather. Today I got 38mpg after 75miles going 80mph from SD to OC. I used to get a consisten 45-46mpg no matter how i drive. I really don't know what the problem is and I need to find out because the only reason i bought the car was for the mpg since my commute is 180 miles/day. So i may have the same problem as you, can anyone help?
  7. richard schumacher
    7,682
    1,063
    United States
    You were formerly able to get 45 MPG at 80 MPH? That's almost unreasonably good.
    Has it been a lot windier recently? More MPGs are lost in a headwind than can be gained from a tailwind, especially at those speeds.
    Even if you never get the fuel economy back up consider this: what other vehicle would give you 38 MPG at 80 MPH?
  8. ibmindless
    ibmindless Member
    206
    Check your tire pressures. COLD should probably be around 42F/40R. The coastal storms were blowing in from the west & northwest. If you were driving from SD to OC during any of the blustery weather, you'd be driving into headwinds.
    For what it's worth, I made the drive from SD to LA and back everyday - 125 miles one way. Driving at 80+ MPH gets old after awhile. Too much tension dodging around slow pokes. Get into the zen of the Prius and and save yourself gas money and lots of worthless stress, and join the crowd in the slow lanes.
    It might be a challenge at first, but soon you'll be enjoying the scenery, chillin' to some tunes, and actually relaxing on that big drive. Then you'll be racking up MPG's in the 50's.
  9. txtabby
    139
    Austin, TX
    Geez, 80 mph on the 5?? That's movin'! I'm with Mark, back off to at least 70. 65 is better and stay out of that far left lane. There's a post somewhere on here (a very long and very, very good explanation) on how to get the best mileage with the Prius. One tip says you get the best mileage between 50 and 60 mph. After that the wind resistance starts to effect performance. Unless there's a tail wind :) Head winds do too, but it wouldn't be too smart driving at 40 mph on the 5 with a 20 mph head wind. Too dangerous.
    I still don't know how you all get 55+ mpg! Maybe a regional thing, roads, I don't know. The very best I've ever gotten was right at 60 mpg, after filling up my tank, on the way home from work (21 miles one way), around 7 pm, in the spring, temps around 70's. And that was just as I turned onto my street. Next morning (between 5-5:30am) it went back down to 48-ish. I was a very happy camper that night. But the next morning, just eh, oh well. I'm still getting better mileage than 95% of Austin residents, I'm guessing. ;)
  10. txtabby
    139
    Austin, TX
    Oh, so you know what I'm talking about LOL You mean 170/180 when u just go below half a tank?? wow... More reason to keep up on the tire press, air filters, good fuel, ..... car washes...... waxes :p
  11. mk516
    mk516 New Member
    You seem to be doing everything fine, no worries.
    Heyy, I live in Buffalo & it's been way below freezing here and I'm almost scraping into the 30's as far as MPG. My car wants it to be spring soo bad!
  12. Ruby Quiver
    Ruby Quiver New Member
    Cleveland Ohio US
    Hey Tom, what MPG do YOU get with your '06 in those presumably frigid N Michigan winters? I'm in N Ohio and my '06 gets mid-to-low 30's driving around town, the only reason i can stretch into the 40's right now is because of my hwy commute.
    what year is your prius? By scraping into the 30's does that mean low 30's or high 30's? I'm in a similar climate in Cleveland.
  13. txtabby
    139
    Austin, TX
    Okay, temp back up to the 50's again (but going back down to the 40's-, soon) and filled up (8.5 gal, only one pip showing) and staying in the 49-51 range. Doing more P&G helps, driving a little slower too. I feel better now! :D Now I know what to expect in the cold weather.
  14. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Uhh.. About your oil level: how high is a little high?
    Anything over the top line is overfilled and CAN reduce mileage.
  15. Tom Banjo
    Tom Banjo New Member
    62
    South Florida
    One thing I have read, that may apply, is that the cold weather makes the gas bladder less flexible. Since I am a new florida owner, I cannot vouch for this, but it might be applicable to you.
  16. elcorazon
    elcorazon New Member
    74
    chicagoland
    I hate when people complain about this stuff. I often fail to get 30 miles in winter before losing a bar. And 30 is not out of the question in winter. Seriously, you get 48 mpg and complain????????????? ridiculous.
  17. crrice
    crrice New Member
    Georgia
    I've recently noticed a mpg drop in my 2006 Prius. I used to get 40-45 mpg now I'm only getting around 35 mpg. My driving habits haven't changed and I don't think it's the cold. I just had my oil done and my tire pressure is good.
    Any ideas?
    Thanks
  18. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Check that they didn't overfill your oil.
  19. ripvw
    ripvw New Member
    Austin, TX
    For almost a year my 2009 Prius got great gas mileage. Without even trying, I easily averaged 45-47 mpg per tank of gas, occasionally even higher. But in late December my gas mileage began going down significantly. It has gone down about 20%. Even with trying ‘hypermile’ techniques, I have a difficult time even getting 36 mpg now. About 6 weeks ago the ‘check engine’ light came on and stayed on for 2 days and then went off. In addition, the car often ‘shudders and shakes’ when I come to a stop. There have been no changes in driving habits or amounts of driving. Yes, we've had some cold weather, but I had no mileage problems last winter. I took it in to the dealer a couple of weeks ago, but after waiting for 4 hours they were unable to diagnose the problem and said to come back when I could leave it longer. Very frustrated.
  20. Genoz World
    797
    22
    La Canada
    "Oh, so you know what I'm talking about LOL You mean 170/180 when u just go below half a tank?? wow... More reason to keep up on the tire press, air filters, good fuel, ..... car washes...... waxes "
    TX TABBY - 42/40 - new air filter on every other oil change - OIL BY SHELL - car washes by none other, wax by meguiars, tech wax
